Indications from the controller
Is there a way to give some sort of indication, through the controller, when a limit switch has been pressed?
Re: Indications from the controller
is there a specific reason you want an indication because if a limit switch has been closed and setup correctly, the applicable motor/motion should just stop
As far as I am aware the Vex command module is entirely incapable of transmitting signals and the Vex Controller is entirely incapable of receiving signals. For both of these reasons I believe it is not possible. However you could do something in programming to react to a limit switch being pressed down.
You can also get a reading on the switch using the Online Window (from the Build and Download menu). However, if you're trying to see whether a specific action of your program triggered the switch, nonother's suggestion is the way to go.
| Programming Analog Input from 2004 Controller | Danny Diaz | Programming | 8 | 30-01-2007 22:44 |
| No PWM from controller | ctshirk7 | Control System | 10 | 27-01-2006 18:55 |
| jumper cabling from sensors to controller | Gary Dillard | Electrical | 4 | 23-12-2005 07:42 |
| Missing Xbox controller from San Diego lock-in... | chaoticprout | Off-Season Events | 0 | 22-05-2005 20:38 |
