Go to Post I have photos of students working the lathe dressed for a concert! Makes me wish for a formal dress night at robotics. - Mark McLeod [more]
Unread 25-02-2007, 16:50
Dave K.'s Avatar
Dave K. Dave K. is offline
Engineer/Mentor
FRC #0930
Dave K. is a splendid one to beholdDave K. is a splendid one to beholdDave K. is a splendid one to beholdDave K. is a splendid one to beholdDave K. is a splendid one to beholdDave K. is a splendid one to beholdDave K. is a splendid one to behold
Re: Real time clocks, out of the question?
Originally Posted by evan_wilson View Post
Alright. I have another question about how the timer variables work in all of these. I've used storage classes/qualifiers occasionally but I don't understand the significance of using, say, extern and volatile to store the timer variables. Could anyone shed some light on this?
'extern' is much like a function prototype, meaning that it is allowing you declare the variable within the local scope such that the compiler will know what the variable type is and can generate the appropriate code. When the linker pulls all of the object files together, it will resolve the external dependancies of each of the object files, and if you haven't declared the variable itself anywhere within the program, will generate an error and abort.
'volatile' tells the compiler that the variable may change on its own and to generate code as appropriate. For optimization purposes, a compiler may read a variable from memory into a temporary register, and subsequent read/write operations to that variable _may_ only occur to the register without updating the memory location. Telling the compiler that the variable is volatile causes the compiler to re-read the variable's memory location each time it is used, and to write it back to memory each time it is updated.
'volatile' would be used for things like hardware periphial registers, as well as things like variables that might change inside of an interrupt routine.
Since the compiler can't know why you are telling it that the variable is volatile, it wouldn't generate additional instructions to disable interrupts during critical regions to ensure that a multi-byte variable read/write operation is performed without the potential for another interrupt routine corrupting the operation. Pre-emptive multi-tasking operating systems generally pose the same potential for corruption that an interrupt routine does.
The 'static' qualifier allows variables to be declared within a local, rather than global, scope and simply tells the compiler to declare the variable in a memory location that is static, rather than allocating it on the stack frame (or emulated equivilent thereof) of the local function.
Any variable declared outside of a function is normally considered a global variable, but unless other source files provide an 'extern' reference, the variable's use will remain limited to that source file, and is sometimes referred to as a 'local global'. The caveat here is that if you were to declare another 'local global' in another source file, the linker will (usually) have a problem with the duplicate declarations, and generate an error.
Recognizing that Microchips documentation already presumes a certain familiarity with the "C" language and doesn't really get into all of the specifics, for those that already have a general grasp on the "C" language, two books that I would recommend are:
The C Programming Language by Brian Kernighan and Dennis Ritchie, who are the origional authors of "C".
A book on C by Al Kelly and Ira Pohl.
K&R's book is very terse with minimal examples, but is the bible. The 2nd one is also a bit terse, and goes into depth more than K&R's book.
I've included links to Amazon's website as a convienent reference, but retailers such as Barnes & Noble also generally carry these and other good reference books where you can browse before you buy.
--Dave
Unread 25-02-2007, 20:41
evan_wilson's Avatar
evan_wilson evan_wilson is offline
QUARK
AKA: Evan Wilson
FRC #2172 (Street Legal)
Rookie Year: 2007
evan_wilson is an unknown quantity at this point
Send a message via AIM to evan_wilson Send a message via Yahoo to evan_wilson
Red face Re: Real time clocks, out of the question?
Strangely enough, K&R is sitting right here on my bookshelf. Somehow I hadn't remembered "volatile". I'll go reread through the data types/variables stuff again.
Not to seem pestery... but I've once again confused myself in this code. I read through the PIC's datasheet (timer section) and studied up on the registers. On the good side, I now completely understand all the scalers, clocks, and flags, but I could not seem to understand how the high and low byte registers worked/were needed. I don't see how an integer could go past 65,535, so why does the high byte happen to be able to have a value over that?
I also could not find an equivalent for the PR2 register for Timer1. Is that simply not present and do I have to use conventional math to downscale further?
Thanks again for the help.
Unread 25-02-2007, 22:58
Dave K.'s Avatar
Engineer/Mentor
FRC #0930
Timer's 2 & 4 are 8 bit wide timers and have the "PR" registers, the other timers are 16 bit.
Timer 1 is a bit special and can be used for a low power, real time clock function.
Without a specific reference, I'm not sure what you mean about the high byte having a value greater than 65535. My only guess would be that by setting a value to zero, you'll get an effective divide rate of 65536, but I don't immediately see that in the documentation.
The reason that the 16 bit counter is split into two 8 bit registers is that the CPU only operates on data 8 bits at a time. So a 16 bit read/write operation requires two data bus operations to manipulate the 16 bit value.
Does that help or did I miss one or more of the questions?
--Dave
Unread 25-02-2007, 23:10
QUARK
AKA: Evan Wilson
Rookie Year: 2007
Question Re: Real time clocks, out of the question?
Ahhh, that explains things a bit. I should have thought about that. RD16 two bytes wide, duh.
Thanks for that tidbit.
And the high and low bytes. In the wallclock code (http://www.chiefdelphi.com/forums/sh...t=wallclock.c), the high byte value is.... NEVER MIND
Someone can't count their zeros.
I still don't exactly understand what the purpose of the high and low bytes are. Is it like an loop condition? Above the max value for a 16bit number counts as an overflow and it resets, setting the flag with it?
THANK YOU
Unread 24-02-2007, 13:23
Kevin Watson's Avatar
Kevin Watson Kevin Watson is offline
La Caņada High School
FRC #2429
Kevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond repute
Is it humanly possible to create such a program?
I wrote some real-time clock code for the EDU-RC a few years ago. Here's a link: http://kevin.org/frc/2005/edu_clock2.zip.
-Kevin
Kevin Watson
Engineer at stealth-mode startup
http://kevin.org
Unread 24-02-2007, 13:41
QUARK
AKA: Evan Wilson
Rookie Year: 2007
Okay. Thanks very much Kevin and Mark. The last thing I need to make sure of is the value for the system clock. In the edu_clock code, it's specified as 10MHz. Does anyone know if there would be a difference in the PIC18F8722? I seem to remember reading something about 32.blablabla MHz somewhere. Or maybe it's changeable...
After this, I deserve to be put back into grade school if I can't do the math.
THANKS
Unread 24-02-2007, 16:28
Mark McLeod's Avatar
Mark McLeod Mark McLeod is online now
Just Itinerant
AKA: Hey dad...Father...MARK
FRC #0358 (Robotic Eagles)
It's the same 10MHz for the PIC18F8722 we use.
Networkable real-time game simulation for 'Aim High'! test it out now Bongle General Forum 11 19-03-2006 23:10
Real time photos from the buckeye regional Greg Needel Regional Competitions 4 25-03-2004 12:46
Robot motion after the time has run out. Randy Ai Rules/Strategy 1 06-01-2003 17:17
Real Time Scoring archiver 2000 2 24-06-2002 00:09
real time chat SharkBite CD Forum Support 4 07-02-2002 21:22
