Go to Post FIRST competitions ARE holidays, or they should be at least. - Kel D [more]
Unread 25-02-2007, 16:21
thefro526's Avatar
thefro526 thefro526 is offline
Mentor for Hire.
AKA: Dustin Benedict
no team (EWCP, MAR, FRC 708)
thefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond repute
Send a message via AIM to thefro526 Send a message via MSN to thefro526
Motor that acts like a servo
How exactly would I make a motor act like a servo in EasyC? I know I would need to use some kind of sensor like a potentiometer or an encoder. Also does anyone know how to wire a potentiometer to a PWM?
-Dustin
-Dustin Benedict
2005-2012 - Student & Mentor FRC 816
2012-2014 - Technical Mentor, 2014 Drive Coach FRC 341
Current - Mentor FRC 2729, FRC 708
Unread 25-02-2007, 16:31
Bharat Nain's Avatar
Bharat Nain Bharat Nain is offline
Bharat Nain has a reputation beyond reputeBharat Nain has a reputation beyond reputeBharat Nain has a reputation beyond reputeBharat Nain has a reputation beyond reputeBharat Nain has a reputation beyond reputeBharat Nain has a reputation beyond reputeBharat Nain has a reputation beyond reputeBharat Nain has a reputation beyond reputeBharat Nain has a reputation beyond reputeBharat Nain has a reputation beyond reputeBharat Nain has a reputation beyond repute
Send a message via AIM to Bharat Nain Send a message via MSN to Bharat Nain
Re: Motor that acts like a servo
You would need to use a potentiometer or encoder depending on your use.
A potentiometer can only go so many turns and are good for arms and such.
An encoder is for continuous rotation, like drives.
Hopefully someone else can help you with the wiring.
-= Bharat Nain =-
Whatever you do, you need courage. Whatever course you decide upon, there is always someone to tell you that you are wrong. There are always difficulties arising that tempt you to believe your critics are right. To map out a course of action and follow it to an end requires some of the same courage that a soldier needs. Peace has its victories, but it takes brave men and women to win them. - Ralph Waldo Emerson
Unread 25-02-2007, 17:44
Kingofl337's Avatar
Kingofl337 Kingofl337 is offline
You didn't see anything....
AKA: Adam
FRC #0501 (Power Knights)
Rookie Year: 1998
Kingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond repute
Send a message via Yahoo to Kingofl337
Plug a Motor into a PWM Port.
Connect a Potentiometer between 10-100k to a Analog Input.
Wiring doesn't matter as long as the wiper goes to the White Wire (signal)
and you connect power and ground to the other remaining pins.
Then you have to link them mechanically and write in easyC a P.I.D. loop to control the whole deal. Check the White papers in CD Media under P.I.D. .
FIRST Team 501 PowerKnights - Mentor
FIRST Team 40 Checkmate - Mentor Alum
FIRST Team 146 Blue Lightning - Alumni
Unread 25-02-2007, 18:02
NeedMoreEngines's Avatar
NeedMoreEngines NeedMoreEngines is offline
AKA: Mike
FRC #1279 (Cold Fusion)
Team Role: Driver
NeedMoreEngines has a spectacular aura aboutNeedMoreEngines has a spectacular aura about
Send a message via AIM to NeedMoreEngines
yeah we did the same thing and it works SO WELL. it's really awesome.
i remember talking about the programming with the team mentor and you have to use a potentiometer to input the values that you want the motor to move to. i'm pretty sure you can do it with any motor. we did it with a globe first and then a window.
"There is only one solution to this problem- We need more engines."
The good thing about the YMCA is if you can spell, you can dance.
Proud Eagle Scout
[FVC]: Servo motor fix norfsprang FIRST Tech Challenge 3 23-02-2007 23:10
Motor to Servo itzrobz Programming 8 02-02-2006 16:11
Defective clutch on motor/servo? jeffmorris FIRST Tech Challenge 3 04-10-2005 14:49
looking for motor or servo tips Dbell5555 Technical Discussion 7 22-05-2005 18:28
Team 701 Balancing Acts Doug G Robot Showcase 2 19-02-2005 14:14
