Go to Post When we went to Wonderland people were like "So are you guys part of a rugby team or something?" and i was like "No...FIRST robotics! It beats rugby anyday" - Laura 1547 [more]
Unread 25-02-2007, 20:00
popnbrown's Avatar
popnbrown popnbrown is offline
FIRST 5125 HOTH Lead Mentor
AKA: Sravan S
FRC #5125 (Hawks on the Horizon)
Rookie Year: 2007
popnbrown has a reputation beyond reputepopnbrown has a reputation beyond reputepopnbrown has a reputation beyond reputepopnbrown has a reputation beyond reputepopnbrown has a reputation beyond reputepopnbrown has a reputation beyond reputepopnbrown has a reputation beyond reputepopnbrown has a reputation beyond reputepopnbrown has a reputation beyond reputepopnbrown has a reputation beyond reputepopnbrown has a reputation beyond repute
Trouble with Autonomous
Well the title of the thread actually isnt exactly my problem. Autonomous works however one of my functions doesn't work. We are trying to get our robot to rotate (a 0 degree turn). I'm using WPILib so we have to write totally new code.
Well anways here is the function Rotate():
Code:
void Rotate(char direction, int degrees, char speed)
	int time = (1000 * (degrees/ 300));
	char RightMotor = NEUTRAL + (speed * direction * (SPEED_TO_PWM));
	char LeftMotor = NEUTRAL + (speed * direction * (SPEED_TO_PWM));
        //the SPEED_TO_PWM = 127/10 which converts the speed to PWM value
	printf("Rotate()\r");
	SetPWM(LEFT_WHEEL, LeftMotor);
	SetPWM(LEFT_FRONT_WHEEL, LeftMotor);
	SetPWM(RIGHT_WHEEL, RightMotor);
	SetPWM(RIGHT_FRONT_WHEEL, RightMotor);
	printf("time: %d\r", time);
	Wait(time);
	SetPWM(LEFT_WHEEL, NEUTRAL);
	SetPWM(LEFT_FRONT_WHEEL, NEUTRAL);
	SetPWM(RIGHT_WHEEL, NEUTRAL);
	SetPWM(RIGHT_FRONT_WHEEL, NEUTRAL);
       //NEUTRAL = 127
now the main problem is the time. When I pass for example:
Code:
Rotate(-1, 30, 10)
the time displays as 0. I find it really odd. However I ran time as a constant:
Code:
time = 300;
and the function worked perfectly. So the real problem here is one of the variables involved in the time equation and I dont know which one or what is wrong.
Any help would be appreciated
Trouble with the GTS Bomberofdoom Programming 1 04-02-2007 10:13
Has anyone else had trouble staying within the 10 second limit in autonomous? lkdjm Programming 18 12-02-2006 18:10
Autonomous Code trouble The yellowdart Programming 16 21-01-2006 10:36
My trouble with fund raising. BaldwinNYRookie Fundraising 5 03-04-2005 13:34
Trouble with pwm outputs misterikkit Programming 16 17-01-2004 10:56
