Go to Post If Will uses the word "dope", doesn't wear a larger FIRST logo, takes up half of the St. Louis arena, if there was not enough seating in the pits, if the music was killed during finals, it was all justified tonight. - Barry Bonzack [more]
Unread 26-02-2007, 13:42
Uberbots's Avatar
Uberbots Uberbots is offline
Mad Programmer
AKA: Billy Sisson
FRC #1124 (ÜberBots)
Uberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond repute
Generic PID control code
I was asked by Adamdb of team #1583 to post a code example of what we did to execute a PID loop. The two files, pid.c and pid.h are attached below.
in order to use a pid loop, you must do a couple of things. first, you create the data structure, for example:
PHP Code:
DT_PID arm
in some initialization code later, you need to initialize the constants
PHP Code:
init_pid(&arm10010101005);
(see the included file for the argument list)
then finally, you can execute the loop by doing this
PHP Code:
pwm03 pid_control(&armerrorValue);
It really isnt that bad, and if you notice a lack of comments/explanation, please make a note of it. Also, this code doesnt go into the theory behind it, it only executes the theory. so if you dont know what a proportional coefficient is, then i suggest that you read this: PID without a PhD
happy control-loop-ing.
Edit: i added the default code plus the PID code for those of you who are having trouble getting started.
A few of my favorite numbers:
175 176 177 195 230 558 716 1024 1071 1592 1784 1816
RPI 2012
BREAKAWAY
Last edited by Uberbots : 26-02-2007 at 22:30. Reason: added default code + pid code
Unread 26-02-2007, 14:06
Tom Bottiglieri Tom Bottiglieri is offline
FRC #0254 (The Cheesy Poofs)
Tom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond repute
Re: Generic PID control code
I was going to post mine, but beside for some minor syntax differences, the drivers are identical.
Good work.
PS. It looks like the uberbots' programmers have come a long way since I last talked to you before eliminations at UTC last year.
Unread 26-02-2007, 16:32
Mike's Avatar
Mike Mike is offline
has common ground with Matt Krass
AKA: Mike Sorrenti
FRC #0237 (Sie-H2O-Bots (See-Hoe-Bots) [T.R.I.B.E.])
Mike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond repute
Again, nearly identical PID code. I constructed mine from the PID without a PhD article as well.
http://www.mikesorrenti.com/
Unread 26-02-2007, 16:59
meatmanek meatmanek is offline
Programmer/physicist/mathematician
FRC #0868 (TechHounds)
meatmanek is a splendid one to beholdmeatmanek is a splendid one to beholdmeatmanek is a splendid one to beholdmeatmanek is a splendid one to beholdmeatmanek is a splendid one to beholdmeatmanek is a splendid one to beholdmeatmanek is a splendid one to behold
I was about to make code from PID without a PhD, but then I saw this. It's always great to see teams post code for others to use.
Real programmers use vim.
Integral Window for PID Control phrontist Programming 2 16-02-2008 17:32
PID Control Chris Bright Programming 9 26-03-2005 19:44
(Experimental) PID Control System jdong Programming 14 18-06-2004 15:55
PID control loop/Encoder question Zee Programming 18 30-01-2004 23:14
PID Control Loops ttedrow Programming 7 05-12-2002 12:03
