Go to Post 4 is kind of like 5 - Jaine Perotti [more]
Unread 26-02-2007, 18:03
Andrew Blair's Avatar
Andrew Blair Andrew Blair is offline
SAE Formula is FIRST with Gasoline.
FRC #0306 (CRT)
Andrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond repute
Send a message via AIM to Andrew Blair Send a message via Yahoo to Andrew Blair
Re: Lowering the voltage on a spike
Originally Posted by fsayre View Post
Can you not send a series of on/off pulses through the spike? I am sure its probably a bit harsh on the motor.
Both this idea and the victor technically wouldn't limit the actual voltage, just the duty cycle of the signal.
I'm pretty sure that the Spike cannot operate at high frequencies like a Victor. If I remember right, the max cycling is like 20hz for just a few seconds. The Victors are solid state, but the spikes are actually a mechanical relay- thats the clicking noise. This limits the frequency as well as the life cycles that the unit can handle. Otherwise, I think your idea is right, just not with our hardware.
Reading makes a full man, conference a ready man, and writing an exact man.
-Sir Francis Bacon
"Any intelligent fool can make things bigger, more complex, and more violent. It takes a touch of genius -- and a lot of courage -- to move in the opposite direction."
-Albert Einstein
Unread 26-02-2007, 18:37
DonRotolo's Avatar
Back to humble
FRC #0832
And even harder on the Spike. Solid state or not, switching an inductive load isn't pretty.
But you definitely have the theory right!
Plus what Andrew said ^^
Don
What is best for lowering the middle wheel? Jeff K. Technical Discussion 9 28-01-2006 12:49
Lowering the Bar? Aignam Regional Competitions 4 07-03-2004 23:13
Raising the bar...or lowering it? Ben Mitchell General Forum 29 13-01-2004 03:30
Problem with Lowering the Bar Kevin Kolodziej General Forum 14 12-01-2004 21:58
Voltage Byte -> True Voltage Ulibrium Technical Discussion 11 01-03-2002 08:55
