Go to Post Beware of the following: boredom intelligence = ??? <- could be anything... - JBotAlan [more]
Go Back   Chief Delphi > Technical > CAD > Inventor
Unread 28-02-2007, 21:37
negfrequency's Avatar
negfrequency negfrequency is offline
the guy with the drawings
AKA: Willomatic
FRC #1559 (Devil Tech)
negfrequency is just really nicenegfrequency is just really nicenegfrequency is just really nicenegfrequency is just really nicenegfrequency is just really nice
Send a message via AIM to negfrequency
DWF?
Can anyone explain to me what this DWF thing is that we must submit? I have never encountered this file type before, from research it looks like its something similar to a pdf. help?
www.evolved-ideas.net
-KOP CAD parts available for download
You know your me if.....
5) your 91 honda civic dx drives @ warp .000005376, not 60 mph
4) You know what "Bi-directional parametric associativity" is
3) Playing Diabolo does NOT mean you are a level 24 mage.
2) You've discovered you can rearrange the letters in William to spell "I am Will".
1) Your bicycle is 3 times more expensive than your car.
Unread 28-02-2007, 22:10
rohit's Avatar
rohit rohit is offline
Inventor Person
FRC #0617 (The Springers)
rohit has a spectacular aura aboutrohit has a spectacular aura about
Send a message via AIM to rohit
Re: DWF?
Basically, its a autocad file, but you can't make any changes on it. So.. its kinda a autocad pdf.
Unread 28-02-2007, 22:14
AKA: Willomatic
Re: DWF?
thanks.
i read the help file and realized all you have to do is just save the format in inventor. It's just like the java applet on the Autodesk manufacturing community website.
Unread 01-03-2007, 09:38
JD Mather's Avatar
JD Mather JD Mather is offline
JD Mather is a jewel in the roughJD Mather is a jewel in the roughJD Mather is a jewel in the roughJD Mather is a jewel in the rough
Re: DWF?
DWF stands for Design Web Format. The format is a vector format that allows viewing at any size on the internet without the loss of resolution like a bitmap image. In addition you can rotate, shade, turn parts in an assembly on/off, section. All of this with the DWF Viewer that is installed with all Autodesk Products.
Here is an example that includes embedded bitmap image on first page, then a combination of 3D and 2D pages. I think the 3D assembly is on page 3 or 4 and unfortunately when I saved it I was zoomed in but you can easily zoom out and rotate the model. The file is quite large (30 meg if I remember correctly). Takes a couple minutes to download. http://home.pct.edu/~jmather/stapler...d%20mather.dwf
Our server seems to be really slow today so if it doesn't download try again later.
With Design Review now free a lot more functionality can be had like measure and markup and easier combining of different pages.
http://dwf.blogs.com/beyond_the_pape...new_in_au.html
http://usa.autodesk.com/adsk/servlet...&siteID=123112
