Go to Post I'd rather have a bot in front of me than a frontal lobotomy. - Neal Probert [more]
Unread 01-03-2007, 18:54
edthegeek's Avatar
edthegeek edthegeek is offline
AMHS/Case Western Reserve Universit
AKA: Eduardo Arellano
no team (TKO)
edthegeek has a spectacular aura aboutedthegeek has a spectacular aura aboutedthegeek has a spectacular aura about
Send a message via AIM to edthegeek
wire size on the motors
The wire on the CIM motors is 14 guage, but regulations require 12 guage wire for anything connected to a 40 amp breaker? What should I do if I want to use these motors on a 40 amp breaker? Currently I'm just connecting the wire that came with the motors to the victor.
"You do realize that most of the substances that you are inhaling right now are considered toxic in the state of California"
-Paolo to me while I am covered in Teflon and soldering.
"Stupid Chinese 6011 Alloy is stronger than we thought."
"Comrade, your sacrifice brings honor to the motherbot."
Unread 01-03-2007, 18:57
bjimster1's Avatar
bjimster1 bjimster1 is offline
AKA: Jimmy Bourne
FRC #1029 (Wolvcats)
bjimster1 is just really nicebjimster1 is just really nicebjimster1 is just really nicebjimster1 is just really nice
Send a message via AIM to bjimster1
Re: wire size on the motors
thats fine. but if you need to "make an extension" then you're gonna have to use the 12 gauge wire.
-2006 UCF Quarterfinalists w/ 1345 & 21
-2005 Peachtree Quarterfinalists w/ 1180 & 462
-2005 UCF Quarterfinalists w/ 1694 & 348
CMU '11
Unread 01-03-2007, 19:25
Arille's Avatar
Arille Arille is offline
FRC #2135
Team Role: Leadership
Rookie Year: 2007
Arille is a splendid one to beholdArille is a splendid one to beholdArille is a splendid one to beholdArille is a splendid one to beholdArille is a splendid one to beholdArille is a splendid one to beholdArille is a splendid one to beholdArille is a splendid one to behold
Send a message via AIM to Arille
so you would use the given 14 gauge wire from the CIMS to the victors .. would that mean 14 or 12 gauge going from power +/- to power distribution block/circuit breaker?
Also, is that the same for other motors (e.g. keyang window)?
we kind of used what we had around (14 awg). hopefully theres enough time for us to make corrections in the morning of competition......
Team 2135: Presentation Invasion
Silicon Valley Regional 2007 Rookie Inspiration Award!
Unread 01-03-2007, 20:32
Arille's Avatar
FRC #2135
Rookie Year: 2007
Sorry, I think I just found an answer to one of my questions:
<R87> 12 AWG or larger diameter wire must be used for all circuits protected by a 40A circuit breaker.
.. Looks like someone's going to be working morning of competition
Or maybe the CIMS can work off the 30A circuit breakers?? So much for the Maxi style breakers then.. Hmm.. we'll see.
(there was no prior electronics knowledge on our team .. almost everything was trial and error, mostly with some reasoning behind it , dont worry, we were being safe!)
Unread 01-03-2007, 21:41
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Team Role: Teacher
In most situations you will want to run the CIMs with the 40 amp breakers.
Unread 01-03-2007, 21:44
Arille's Avatar
FRC #2135
Rookie Year: 2007
Yeah, that's what I thought, but I wasn't so sure of myself .. thanks for confirming it!
Unread 02-03-2007, 08:05
Unsung FIRST Hero
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Rookie Year: 1996
Although the Chalupa motors come with #14 wire, they are relatively short and so have little series resistance to cause heating. It is a good idea to move the Victors feeding your Chalupas (both the large and small) close enough to the motor so you can use the supplied motor leads without additional wire. As pointed out, if you are using these motors for drive they are best fed with a 40 amp breaker. I would go further and make the wiring to the Victor with #10 following the suggestions found in the Tips and Guidelines for wiring.
If you must add wire, then use approved splicing technique or add smaller connectors to the wire. We use the smaller Anderson Power Products connectors. They are polarized and do not require additional insulation.
Al
WB9UVJ
www.wildstang.org
________________________
Wire Size Limit? (InsrtNameHere) Electrical 2 15-02-2006 20:20
pic: Why the mechanical team shouldnt wire the robot late at night. Andrew Rudolph Robot Showcase 4 15-02-2005 01:15
Converting to Metric Wire Size or yaniv Electrical 1 18-01-2005 10:52
schematics or wire diagrams for van door motors tml240 Technical Discussion 9 04-02-2004 18:23
Can We Wire Two Motors to a Victor? archiver 2001 4 24-06-2002 00:07
