Go to Post A well-designed shifting transmission, controlled by an experienced driver (or a clever bit of software), is an advantage. - Alan Anderson [more]
Unread 01-03-2007, 19:39
Jake M Jake M is offline
void* Jake;
FRC #1178 (DURT)
Jake M has a spectacular aura aboutJake M has a spectacular aura about
pic: Team 1178 Robot - Ramp and Deck open
Ramp deploys within a second or two, is very sturdy, and can support a lot of weight. There is a flat piece of diamond plate that sticks straight up during normal play, but can be pushed flat by another robot, driving up. It is supported underneath by triangular brackets, and makes the final deck size about 3' x 4', at 13" off the ground. We can also get another robot 4" off the ground, if it doesn't roll back down the ramp, when the robot is disabled.
Also, note the large majority of this robot was built and designed by the students, although the mentors play a very active roll.
Code:
void function(void)
  function();
pic: Tem 1178 Robot - Hand Mechanism Jake M Extra Discussion 1 01-03-2007 20:31
pic: Team 1178 Ramp and Deck Open Jake M Extra Discussion 0 01-03-2007 19:30
Team 1345's ramp deploy and robot on top. Arefin Bari Robot Showcase 7 07-02-2007 17:17
pic: Team 668 Robot Ramp 3 burkechrs1 Extra Discussion 6 06-02-2007 21:29
pic: 1270's Ramp unfolded and 2005 robot on top redbarron Extra Discussion 1 05-02-2007 17:05
