Go to Post We built an ineffective machine, all by ourselves! Yay for us! - Alan Anderson [more]
Unread 02-03-2007, 17:02
Tri_Lam's Avatar
Tri_Lam Tri_Lam is offline
Jeff
FRC #1372 (Lambda Cubed)
Tri_Lam will become famous soon enough
Send a message via AIM to Tri_Lam
Non Frc: Electrical question series and parallel
To whom it may concern:
My name is Jeffrey Villar. My fellow class mates and I are doing a project on Solar Cars. Few questions have arrisen to our project.
First is When you wire cells into two diffrent series which endup producing two different voltage out puts, then connect those two series into a parallel connection. what happens to the voltage?
ex
arrange 7 cells w/ .5 voltage with 6 amps into two series one with 4 cells the other with 3 you get 4 cells withg a voltage of 2 volts and 6 amps while the other is 3 cells producing 1.5 volts with 6 amps. then putting both series into a parallel connection in theory gives us 12 amps but what is the voltage output? is it average?
also if you split a cell w/ .5 voltage with 6 amps what happens to the amps and volts????????????
Jeff Villar
Mira Mesa High - Lambda Cubed
2004 - ???
2005 - LA Regional
2006 - Las Vegas Regional - 7th place
2007 - SAN DIEGO regional
2008 - MMHS's Advisor is too cheap -_- 1372 may be no more.....
non frc question: electrical series to a parallel??? HELP Tri_Lam Math and Science 0 02-03-2007 16:56
Question about 3rd Tutorial ETA and FRC Modeler Motor Config Ted155 LabView and Data Acquisition 2 21-01-2007 19:45
FRC Electrical schematic Demothesis Control System 2 07-01-2007 13:31
[TBA] Episode 1 - FRC Electrical System Greg Marra General Forum 30 28-12-2006 23:53
Electrical tape as a non-functional decoration Cody Carey General Forum 14 03-04-2006 00:07
