Go to Post The only way you can be undermined is if you let yourself be undermined. - DUCKIE [more]
Unread 02-03-2007, 18:23
nmihailidis nmihailidis is offline
nmihailidis is an unknown quantity at this point
Grab Frame - Help Help Help...
Hi everybody.
I am trying to develop an application that will grab a frame from CMUcam2 and will appear it on the screen..
I would like to ask you if anybody has done something like that and what was the serial connection properties such as Buffer Size, Read TimeOut etc.
It would be highly appreciated if you could send me an example code of reading the data stream and seeing the serial settings...
I would really appreciate any help of you. Thank you in advance.
NM
Unread 02-03-2007, 22:23
bear24rw's Avatar
bear24rw bear24rw is offline
Team 11 Programming Captain
AKA: Max T
FRC #0011 (MORT)
bear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to behold
Send a message via AIM to bear24rw
Re: Grab Frame - Help Help Help...
As far as the serial settings..
http://kevin.org/frc/CMUcam2_commands.pdf
Tells you all the settings
Unread 04-03-2007, 14:44
theycallhimtom theycallhimtom is offline
AKA: Tom Conerly
FRC #1540 (The Flaming Chickens)
theycallhimtom has a spectacular aura abouttheycallhimtom has a spectacular aura abouttheycallhimtom has a spectacular aura about
Send a message via AIM to theycallhimtom Send a message via MSN to theycallhimtom
There is a version of this that IFI use to give out. http://www.ifirobotics.com/docs/lega...-software1.zip If you unzip that there is a version in java with full source code. That program is also very useful in getting the correct color values for the camera.
rankmaniac
2007 San Diego Motorola Quality Award
2007 Pacific Northwest Chairmans Award
2007 Pacific Northwest Finalist (2nd Seeded Team)
section 'InterruptVectorLow' type is non-overlay (was: HELP HELP HELP!!!!!) naor52 Programming 14 24-02-2007 01:19
Help: How do we get a teacher to help? (was: Help) ChaosAlchimey General Forum 13 21-01-2007 11:57
Need help identifying things that the robot's not allowed to grab on Randy_Ai Rules/Strategy 1 10-01-2002 16:07
