Go to Post Karthik is afraid of the day he can't agasabapathy. - DesignComp [more]
Unread 03-03-2007, 10:20
Demothesis's Avatar
Demothesis Demothesis is offline
Team Leader/Programmer
FRC #2169 (KING TeC)
Team Role: Leadership
Rookie Year: 2007
Demothesis is on a distinguished road
Pre-Game rules
Do you get to choose where you place your robot, and do the referees move your robot prior to the start of the game? This is important for our team's autonomous section, if you hadn't guessed.
Demothesis
Unread 03-03-2007, 10:58
Joe J.'s Avatar
Joe J. Joe J. is offline
My Gaming Is FIRST!
AKA: Joey
FRC #0862 (Lightning Robotics)
Team Role: Coach
Joe J. has a reputation beyond reputeJoe J. has a reputation beyond reputeJoe J. has a reputation beyond reputeJoe J. has a reputation beyond reputeJoe J. has a reputation beyond reputeJoe J. has a reputation beyond reputeJoe J. has a reputation beyond reputeJoe J. has a reputation beyond reputeJoe J. has a reputation beyond reputeJoe J. has a reputation beyond reputeJoe J. has a reputation beyond repute
Send a message via AIM to Joe J.
Re: Pre-Game rules
You place your robot, but after all the robots are placed the refs move the rack.
Joe Jagadics
Lead Mentor / Coach
Lightning Robotics FRC Team 862
Unread 03-03-2007, 11:08
Swampdude's Avatar
Swampdude Swampdude is offline
AKA: Dan Quiggle
FRC #0179 (Children of the Swamp)
Rookie Year: 1999
Swampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond repute
Re: Pre-Game rules
Are you allowed to touch your controls after they move the rack?
www.179swampthing.org
Unread 03-03-2007, 11:20
Joe J.'s Avatar
My Gaming Is FIRST!
AKA: Joey
Team Role: Coach
Re: Pre-Game rules
I'm not sure on that but I'm guessing that will depend on how soon the match will start but most likely not.
Also to update my last post If you use an alignment device to position your robot then the refs will move your robot
Joe Jagadics
Lead Mentor / Coach
Unread 03-03-2007, 22:11
BorisTheBlade's Avatar
BorisTheBlade BorisTheBlade is offline
lead programmer 2004
AKA: Dane
FRC #1351 (TKO)
BorisTheBlade has a spectacular aura aboutBorisTheBlade has a spectacular aura aboutBorisTheBlade has a spectacular aura about
Send a message via AIM to BorisTheBlade
Re: Pre-Game rules
I would have to say no seeing as the whole idea behind moving the rack is to get teams to work on autonomous and not just use dead reckoning. anyone can make a robot dead reckon with next to no thought or work. but its more of a challenge and a learning experience to build code to make a robot think on its own and adjust to the surroundings in order to score points.
Team 1351 TKO Robotics (click for our website)
2007 sacramento regional Johnson & Johnson Sportsmanship Award winners
2007 CAL Games Finalists
Unread 03-03-2007, 11:49
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
Rookie Year: 1999
Re: Pre-Game rules
If you use an external alignment device (e.g. a tape measure not part of the robot), the head referee may arbitrarily reposition your robot. Otherwise, yes, you may choose any position in the home zone with the long dimension upward and the orange indicator light visible from the front (i.e. pointed downfield, toward the rack).
In elimination rounds, the higher-seeded alliance will be allowed to have the last opportunity to orient their robots (according to <T16>). There's a little bit of confusion as to how this is supposed to apply in qualification matches. Per this Q&A response, FIRST says that teams are not seeded until the qualifying round is complete, and therefore <T16> doesn't apply to qualifying matches. However, section 9.3.3 says that "[t]he scoring system will use the combination of qualifying score and ranking score to continuously determine the seeding of teams during the qualification matches." Furthermore, 9.3.10 supports this by describing the seeding algorithm and stating that "[a]ll teams in attendance will be seeded during the qualification matches." These portions of the rules imply that seeding varies continuously during the qualifying matches (i.e. <T16> must be applied in all matches, because the rule doesn't specify different procedures for qualifying and elimination matches). Note also that the rules don't specify a procedure for determining the higher-seeded alliance during qualifying (highest-seeded alliance member, sum of alliance members' seedings, or some other method), probably because whoever wrote this rule intended it to apply in the eliminations only (where alliance captains are defined), but did not specify that condition in the rule itself.
As a practical matter, the list of rankings wasn't conveniently available to the head referee in the past (it would require changing screens on the scoring system, which wasn't always feasible in the Hatch system, especially if the big-screen A/V feed was connected to the second monitor). If that situation continues, it won't be easy for the referees and field supervisor to find out who is higher-ranked, and inform the alliances.
Unread 03-03-2007, 12:31
akshar's Avatar
akshar akshar is offline
FIRST=life
AKA: Fro
FRC #1568 (Mechanicatz)
akshar is a name known to allakshar is a name known to allakshar is a name known to allakshar is a name known to allakshar is a name known to allakshar is a name known to all
Send a message via AIM to akshar
Re: Pre-Game rules
for elims, highest seed would just go by who is seeded in the beginning....however....
if 1 v 8 and wins....does this make 8 the highest seeded team?
Think Bot, Dream Bot, Be Bot
Dream Big Reach High
2005: UTC Judges Award (We'll be Back Award)
2006: Boston Regional Winners with 121 and 233
2007: Boston Regional Finalists with 1626 and 121
Unread 05-03-2007, 10:18
Demothesis's Avatar
Rookie Year: 2007
Re: Pre-Game rules
Thanks. Come to think of it, it seems I remember a rule something like this from the Kick-Off - especially the part about the tape measure and the rack.
Other than that, is there any guarantee that the referee will not reposition your robot if you DO NOT use an external alignment device?
Demothesis
Unread 05-03-2007, 10:50
Spider-Man's Avatar
Spider-Man Spider-Man is offline
Curling Rocks
AKA: Adam Jacobson
FRC #0467 (DTB/Shrewsbury Colonials); #0034 (Rocket City Robotics)
Rookie Year: 2000
Spider-Man has a spectacular aura aboutSpider-Man has a spectacular aura about
Re: Pre-Game rules
Yes, the refs have no authority to move your robot if it is legally placed in the home zone without external alignment devices. The rack will be shifted and rotated after all team members from each alliance are behind the tape for autonomous.
Unread 05-03-2007, 16:21
Demothesis's Avatar
Rookie Year: 2007
Re: Pre-Game rules
All right ... Thanks a lot for the definitive answer.
Demothesis
End Game Rules Nappster16 Rules/Strategy 2 17-02-2007 11:59
Pre Game ritual aaron341 General Forum 32 22-09-2005 18:21
We are hosting a pre-regional practice game! Interested? archiver 2001 2 23-06-2002 23:30
