Go to Post In order to change the world and make it a better place we must start with ourselves. - wendymom [more]
Unread 03-03-2007, 15:33
Adama's Avatar
Adama Adama is offline
AKA: Matthew Eastman
FRC #2199 (Robo-Lions)
Adama is a name known to allAdama is a name known to allAdama is a name known to allAdama is a name known to allAdama is a name known to allAdama is a name known to all
Send a message via AIM to Adama
Team 25 elevator
Any one watching the webcast of the new jersey regional has probably noticed the astounding speed with which the elevator of team 25 moves up and down. I was wondering what motor they are using and how it works so quickly compared to many of the other ones ive seen
Unread 03-03-2007, 22:06
nparikh's Avatar
nparikh nparikh is offline
i heart infrared
AKA: Neil Parikh
FRC #0025 (Raider Robotix)
nparikh has a reputation beyond reputenparikh has a reputation beyond reputenparikh has a reputation beyond reputenparikh has a reputation beyond reputenparikh has a reputation beyond reputenparikh has a reputation beyond reputenparikh has a reputation beyond reputenparikh has a reputation beyond reputenparikh has a reputation beyond reputenparikh has a reputation beyond reputenparikh has a reputation beyond repute
Send a message via AIM to nparikh Send a message via MSN to nparikh
Re: Team 25 elevator
We use a CIM minibike motor with direct drive (ie no gearing on it). Our pulley system uses one long (about 30ft) belt with needle-bearing pulleys to reduce the friction. It's really simple; if you get a chance to see it in person, it's much easier to understand.
Doing the right thing is always better than doing the easy thing.
Team 25 Alumnus
Attending: NJ Regional, Boston Regional, the Championship Event
Unread 03-03-2007, 22:10
Starke Starke is offline
Producer at The RoboSportsNetwork
AKA: Matt Starke
FRC #0174 (Arctic Warriors); (Alumni: 340 (GRR), 1126 (SparX))
Team Role: Leadership
Starke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond repute
Any chance of video of your robot from the regional?
Team 340 | G.R.R. | Alumni/Mentor | 2003-2007, 2010
Team 1126 | SparX | Engineer | 2008-2009
FRCDesigns.com | Engineer | 2011 - Present
Team 174 | Arctic Warriors | Advisor | 2012 - Present
Unread 04-03-2007, 01:02
Ben Piecuch Ben Piecuch is offline
Bengineer
Rookie Year: 2000
Ben Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond repute
Well, you may be using the Big CIM motor without an actual gearbox, but the size of the pulleys give you an "effective gear ratio" Much like using a direct drive transmission for your drive train, the size of the wheel makes a dramatic difference in overall speed. Do you know the size of your pulleys in your belt system? Are they all the same size?
I'll make an assumption to give some example numbers. If you use a 2" pulley, the elevator stage will move 3.14" per rotation. So, at 1/2 of the free speed (or at max power) the elevator will be moving at about 5ft per second. [20rps x 3.14"/rotation] That's VERY fast. However, you need to balance that speed with the available torque. Again, at max power (1/2 of stall torque) the motor provides ~18 lbs-in of torque. Since the pulley has a 1" radius, the motor can effectively lift 18lbs, at a rate of 5ft / sec.
A larger pulley provides more speed, but less torque. A smaller pulley does the opposite. As you can see, that Big CIM is a VERY powerful motor to use on an elevator. If you can keep the weight down, you can move it vertically very quickly. We tried to use a couple Globe motors to lift our elevator, but eventually switched them out to use the Big CIM as well. It's a GREAT motor for this application.
I'm interested in seeing some video as well. Although, I can't say I'm looking forward to competiting against them in Hartford! Another great robot from Team 25. Congrats on another victory!
BEN
Unread 23-03-2007, 01:12
Arefin Bari's Avatar
Arefin Bari Arefin Bari is offline
AKA: Ari
FRC #0108 (SigmaC@T)
Arefin Bari has a reputation beyond reputeArefin Bari has a reputation beyond reputeArefin Bari has a reputation beyond reputeArefin Bari has a reputation beyond reputeArefin Bari has a reputation beyond reputeArefin Bari has a reputation beyond reputeArefin Bari has a reputation beyond reputeArefin Bari has a reputation beyond reputeArefin Bari has a reputation beyond reputeArefin Bari has a reputation beyond reputeArefin Bari has a reputation beyond repute
Send a message via ICQ to Arefin Bari Send a message via AIM to Arefin Bari Send a message via MSN to Arefin Bari Send a message via Yahoo to Arefin Bari
www.thebluealliance.net ... go to match archives... type in 25 in search, you willl get matches from NJ and UTC.
Unread 04-03-2007, 01:16
Sgraff_SRHS06's Avatar
Sgraff_SRHS06 Sgraff_SRHS06 is offline
Kappa != 1/(4Pi-Epsilon-Naut)
AKA: Steve Graff
FRC #1111 (The Power Hawks)
Sgraff_SRHS06 is a jewel in the roughSgraff_SRHS06 is a jewel in the roughSgraff_SRHS06 is a jewel in the roughSgraff_SRHS06 is a jewel in the rough
Send a message via AIM to Sgraff_SRHS06 Send a message via Yahoo to Sgraff_SRHS06
Based on what I've seen, wow! Props to simplicity and recycling the 2006 robot effectively!
POWERHAWKS FORUM
2006 Chesapeake Regional Semifinalists (Thank you 614 and 339!)
UM Class of 2010!!
Unread 04-03-2007, 13:08
Mrpalmere Mrpalmere is offline
Chief 1/2 bot builder
#1089 (Team Mercury)
Mrpalmere will become famous soon enoughMrpalmere will become famous soon enough
This is no recycle. There robot this year has 4 wheels on each side vs. 3 last year. They use all gears in their drive system and get the most out of the 4 CIM's for both speed and power. If I remember corectly they are using 1 1/2" xl sprockets and belt on their arm and are usin g a 10 turn pot and programming to maintain position. I was told that they use 9 1/2 of the 10 turns for this elevator. Ano0ther awesome machine. Congratulations.
Unread 04-03-2007, 22:09
d.courtney's Avatar
d.courtney d.courtney is offline
AKA: David
FRC #0781 (Kinetic Knights)
d.courtney has much to be proud ofd.courtney has much to be proud ofd.courtney has much to be proud ofd.courtney has much to be proud ofd.courtney has much to be proud ofd.courtney has much to be proud ofd.courtney has much to be proud ofd.courtney has much to be proud ofd.courtney has much to be proud ofd.courtney has much to be proud of
our elevator will go about the same speed (for general use it is massively slowed down) we have our elevator with a gear ratio of 12:1 off a big CIM... don't worry this motor does more then just our elevator up and down, it has a servo clutch that switches between that operation and lifting the 2 robots (we have two platforms that they drive onto and we lift them up using that) the final gear reduction for that is 144:1. This ended up saving us a tonne of weight and we have a super quick elevator... reliably the quickest I as a programmer could get it to the top without overextending and possibly ripping off our tube manipulator was 1/2 sec... but our mentors wanted that toned down a bit
Unread 05-03-2007, 23:02
Calvin_1631's Avatar
Calvin_1631 Calvin_1631 is offline
AKA: Calvin
FRC #1631 (Cybernetic Cougars)
Team Role: Electrical
Calvin_1631 is an unknown quantity at this point
Now, are you using a timing belt, or just a regular belt. And is there any advantage of using a belt over a cable? Also, how you do achieve a fast descent of the elevator, if the motor only pulls it up? Surgical tubing?
Unread 22-03-2007, 22:47
zander_108's Avatar
zander_108 zander_108 is offline
AKA: Zander Guerra
FRC #0108 (Sigmac@t)
Team Role: Mechanical
zander_108 will become famous soon enoughzander_108 will become famous soon enough
Send a message via ICQ to zander_108 Send a message via AIM to zander_108
I'm going to guess that gravity does this one for them
Unread 22-03-2007, 23:07
Bharat Nain's Avatar
Bharat Nain Bharat Nain is offline
Bharat Nain has a reputation beyond reputeBharat Nain has a reputation beyond reputeBharat Nain has a reputation beyond reputeBharat Nain has a reputation beyond reputeBharat Nain has a reputation beyond reputeBharat Nain has a reputation beyond reputeBharat Nain has a reputation beyond reputeBharat Nain has a reputation beyond reputeBharat Nain has a reputation beyond reputeBharat Nain has a reputation beyond reputeBharat Nain has a reputation beyond repute
Send a message via AIM to Bharat Nain Send a message via MSN to Bharat Nain
We are using a timing belt. I don't know about the advantages of disadvantages of going with timing belt over cable, but we felt like trying a timing belt system because we made a cable system in 2005. The timing belt system is designed such that the motor can pull it down also. Because of needle-bearing pulleys and precise machining of the mast there is very less friction involved so gravity does do some of our work in bringing the elevator down. Surgical tubing was used to keep the gripper from swaying left and right violently during a match.
-= Bharat Nain =-
Whatever you do, you need courage. Whatever course you decide upon, there is always someone to tell you that you are wrong. There are always difficulties arising that tempt you to believe your critics are right. To map out a course of action and follow it to an end requires some of the same courage that a soldier needs. Peace has its victories, but it takes brave men and women to win them. - Ralph Waldo Emerson
Wiring an Elevator Joe G. Technical Discussion 8 16-02-2007 00:15
Elevator Trouble: The Marta Ben Lauer Championship Event 26 29-04-2004 20:06
1418's Elevator Party? phrontist Chit-Chat 0 26-04-2004 03:03
Space Elevator Ian W. Chit-Chat 28 31-07-2002 14:04
Combined Pneumatic Wonderpaloozistic SeeThrough Elevator archiver 2001 0 23-06-2002 22:18
