Go to Post I was very concerned about this thread. Then I realized you were talking about a computer. - Taylor [more]
Go Back   Chief Delphi > Technical > IT / Communications > 3D Animation and Competition
Unread 05-03-2007, 10:40
Kevin Thorp's Avatar
Kevin Thorp Kevin Thorp is offline
AKA: Kevin Thorp
FRC #3489 (Category 5)
Rookie Year: 1998
Kevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond repute
Autodesk has posted all AVA Entries on FIRSTbase
Autodesk has made all AVA entries available for viewing:
http://firstbase.autodesk.com/?nd=m_...ion_vis_viewer
You can sort by Regional Event and view low-resolution versions or download high-resolution versions of each entry. Cool!
Unread 05-03-2007, 15:32
Unsung FIRST Hero
mrs. p mrs. p is offline
FRC #0233 (roccobot)
Team Role: Teacher
Rookie Year: 1999
mrs. p has much to be proud ofmrs. p has much to be proud ofmrs. p has much to be proud ofmrs. p has much to be proud ofmrs. p has much to be proud ofmrs. p has much to be proud ofmrs. p has much to be proud ofmrs. p has much to be proud ofmrs. p has much to be proud of
Re: Autodesk has posted all AVA Entries on FIRSTbase
i'm confused. doesn't the animation get judged at the same place you entered the chairman's award and/or web page? we're listed in firstawards.org as las vegas but our animation shows up on the florida regional.
Attended:
Regionals KSC, UCF, UTC, Philadelphia, Colorado(2), Toronto, Seattle, Boston(2), NYC, Las Vegas, Hawaii, Los Angeles, Washington D.C., Bayou, Silicon Valley, Chesapeake
Championships: Disney, Texas, Atlanta, St. Louis
Off-Season: IRI, Mayhem, Robot Rodeo, TNT, Panther Prowl
Real Men Wear Pink
Check out www.roccobotics.com
Please visit www.thepinkteam.org
Unread 05-03-2007, 15:36
Nuttyman54's Avatar
Nuttyman54 Nuttyman54 is offline
Mentor, Tactician
AKA: Evan "Numbers" Morrison
FRC #5803 (Apex Robotics) and FRC #0971 (Spartan Robotics)
Nuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond repute
Send a message via AIM to Nuttyman54
No, unlike the CA and webpage, your Animation is submitted at every regional you attend.
Unread 05-03-2007, 15:41
Unsung FIRST Hero
Team Role: Teacher
Rookie Year: 1999
thanks for the reply but then why doesn't it show up at the las vegas one as well?
Attended:
Real Men Wear Pink
Unread 05-03-2007, 15:53
Morgan Gillespie's Avatar
Morgan Gillespie Morgan Gillespie is offline
I haven't any bullets
AKA: NPC / Mercury Rising
FRC #0025 (Raider Robotix)
Team Role: Driver
Morgan Gillespie has a reputation beyond reputeMorgan Gillespie has a reputation beyond reputeMorgan Gillespie has a reputation beyond reputeMorgan Gillespie has a reputation beyond reputeMorgan Gillespie has a reputation beyond reputeMorgan Gillespie has a reputation beyond reputeMorgan Gillespie has a reputation beyond reputeMorgan Gillespie has a reputation beyond reputeMorgan Gillespie has a reputation beyond reputeMorgan Gillespie has a reputation beyond reputeMorgan Gillespie has a reputation beyond repute
Send a message via AIM to Morgan Gillespie
Because it is not entered in every regional you attend. If you actually read the rules it stated you had to select one regional you are attending to enter your animation.
Even though for some teams it appears under all regionals you will attend it will only be judged at the regional you specify
Bristol-Myers Squibb Company
Events Competed:
-Duel on Delaware 05, 06, 07, 08 - Ramp Riot 05, 06, 07 08 - Brunswick Eruption 05, 06, 07 08 - PARC 06, 07, 08 - Monty Madness 0608 - Battle O' Baltimore 07 08 - Pascack Panda-monium - 08
__________________________________________________ _________________________
NJ 06, 07, 08 09 - UTC 07 -LV 06 - HI 08 - ATL CMP 06, 07, 08
Koko Ed's Avatar
Koko Ed Koko Ed is offline
Serial Volunteer
AKA: Ed Patterson
FRC #0191 (X-Cats)
Awwww man!
Or sound file is all screwed up!
We're doomed!
Unread 05-03-2007, 16:21
Nuttyman54's Avatar
Mentor, Tactician
Did they change that for this year? I know last year 114 won at all three regionals they attended (with a mighty good animation I might add)
Unread 05-03-2007, 16:22
AKA: Kevin Thorp
Rookie Year: 1998
Originally Posted by Koko Ed View Post
Awwww man!
We're doomed!
Have you downloaded & checked your original (large) file? Maybe that one sounds okay. I'm sure Autodesk will be using the high-resolution versions for judging.
Unread 05-03-2007, 16:25
Koko Ed's Avatar
Serial Volunteer
AKA: Ed Patterson
FRC #0191 (X-Cats)
They called us last Friday before we left for BAE to send another sound file.
I didn't realize it was this bad.
Our Youtube file is perfectly fine.
I can't understand what happened.
Unread 05-03-2007, 20:35
fireball3004's Avatar
fireball3004 fireball3004 is offline
James Davis
AKA: James Davis
FRC #2090 (Punahou Robotics)
Team Role: Animator
Rookie Year: 2007
fireball3004 is an unknown quantity at this point
Send a message via AIM to fireball3004
wow! our quality dropped down to like a single pixel! I thought it was bad before I sent it in but man is it bad now. Sigh I suppose there's nothing to bedonw about it now.
Newbies away
Unread 05-03-2007, 20:38
CraigHickman
Posts: n/a
Yeah, since Autodesk is limiting the regional awards, you only enter it in your "primary regional." We decided to enter in Silicon Valley, as that's where we saw the best animations last year. We hope to beat the best in order to ensure our chances at Nationals this year.
(I'm glad you liked ours last year, our animator slaved over it.)
Unread 06-03-2007, 12:43
AKA: Kevin Thorp
Rookie Year: 1998
All the animations had their quality degraded somewhat for streaming playback. I assume Autodesk will have the original high-resolution versions on DVD at the regional judging.
Did you render your original .MOV at 720 x 480 resolution in DV-NTSC format? It looks like 320 x 240. And the file size of your original is only 7.5Mb vs. 50-200Mb for most of the other animations.
P.S. Very creative idea & animation. I'm glad we're not competing in your Regional!
Unread 06-03-2007, 13:58
Onward through the fog.
I'm like a kid in a candy store with all of these animations. They are wonderful.
Congratulations to all the teams.
~ Helen Keller
(1880-1968)
Unread 09-03-2007, 11:27
BuddyB309's Avatar
BuddyB309 BuddyB309 is offline
I freaking love animating!!
AKA: Peter Casey
FRC #1625 (Winnovation)
Team Role: Animator
BuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond repute
Send a message via AIM to BuddyB309
can anyone answer this question. In the original rules that they came out with this year they said that at nationals they will have judges pick five animations that they thought were good then have every team vote on one of the five.
Are the professional judges at Atlanta still going to look through every AVA entry or are they now only going to look at the reigional winners?
A.K.A Llama
check out my latest animations Appliance Night Out, Infant Intolerable, Fishing Like a Loony Tune, VVV Roadside Assistance
Life? I have a life. It is sitting at my computer and Animating. AND DRAWING!!! WEEEEEEE!!!!
  #15   Spotlight this post!
Unread 09-03-2007, 12:10
AKA: Kevin Thorp
Rookie Year: 1998
The judges will pick the top 5 from the entire group of submissions. So you can still be picked even if you don't win a Regional AVA.
After the top 5 are selected (approx. 2 weeks before the Championship in Atlanta) voting wil be open. ALL FIRST Robotics students can vote, but they must be registered on FIRSTbase. Then the winner is announced in Atlanta!
Operation Inspiration 2006: Who wants to read all the WFA entries? Rich Kressly Thanks and/or Congrats 24 23-11-2007 16:46
Autodesk FIRSTbase Problems!! Help!! ThatIndianKid89 3D Animation and Competition 4 08-01-2007 09:44
**FIRST EMAIL**/Autodesk Software Now Available on FIRSTbase! Pat Fairbank FIRST E-Mail Blast Archive 11 05-01-2007 11:09
**FIRST EMAIL**/Reminder - Autodesk FIRSTbase now open/FIRST Safety Animation Contes Rich Wong FIRST E-Mail Blast Archive 4 06-12-2006 22:20
The Autodesk Design Awards 2003 – Call for Entries Brandon Martus 3D Animation and Competition 1 26-12-2003 18:40
