Go to Post To me, my mentors are the Father figures. They guide me through each and everything (even if its not robot related), and try to make it as fun as possible. - RoboMadi [more]
Unread 05-03-2007, 11:07
jewbilee jewbilee is offline
jewbilee is an unknown quantity at this point
How to type my code
My school just recently recieved our vex kits. Were trying to program the code now and we don't like the drag and drop functions. I prefer to type out the code as practice for programming. If anyone knows how to achieve this or any other program that we can use, please suggest. Thanks very much
And did search before asking
Unread 05-03-2007, 11:08
thegathering's Avatar
thegathering thegathering is offline
Angry Troll Lurking in the MUD
AKA: Ben
FRC #1885 (Robocats)
thegathering is a splendid one to beholdthegathering is a splendid one to beholdthegathering is a splendid one to beholdthegathering is a splendid one to beholdthegathering is a splendid one to beholdthegathering is a splendid one to behold
Send a message via AIM to thegathering
Re: How to type my code
You can actually use MPLabs (like the FRC teams) instead of EasyC for your vex code.
I remember that the option to manually type code in EasyC was very difficult to find.
*2006 Champion Rookie All Star Award.
*2 x 2006 Regional Rookie All Star Awards.
Unread 05-03-2007, 11:19
could you tell me how to use MPLabs. I keep hearing that you need the C compiler or whatever but I can't find any information about setting it up. Were using the basic Vex Programming kit that you can buy, weve never been to an event so we dont have this cd i keep reading about.
Unread 05-03-2007, 11:47
Mark McLeod's Avatar
Just Itinerant
AKA: Hey dad...Father...MARK
FRC #0358 (Robotic Eagles)
If you aren't on an FRC team and want to use MPLAB/C on your Vex robot you can purchase the C-BOT-COMPILER here:
http://www.vexlabs.com/vex-robotics-downloads.shtml
Unread 07-03-2007, 08:45
popnbrown's Avatar
popnbrown popnbrown is offline
FIRST 5125 HOTH Lead Mentor
AKA: Sravan S
FRC #5125 (Hawks on the Horizon)
Rookie Year: 2007
popnbrown has a reputation beyond reputepopnbrown has a reputation beyond reputepopnbrown has a reputation beyond reputepopnbrown has a reputation beyond reputepopnbrown has a reputation beyond reputepopnbrown has a reputation beyond reputepopnbrown has a reputation beyond reputepopnbrown has a reputation beyond reputepopnbrown has a reputation beyond reputepopnbrown has a reputation beyond reputepopnbrown has a reputation beyond repute
Don't you just need MP LAB to write code? I believe thats the only program that we use, unless the vex kits use different files (not .hex) to run.
And to use MP LAB, u have to first create a Project. Then you have to add some kind of Library (I dont know what they use for Vex). Then you add your own source files which is the actual stuff that is going to run.
Sry for using all those pronouns and undescriptive words, its easier to just show someone than tell them.
Unread 07-03-2007, 10:36
Just Itinerant
MPLAB handles the compiler for you, but you must have it if you are programming in C on either the big or the small robots. The C compiler is installed as a separate software package, but is integrated seamlessly into the MPLAB environment. The compiler is necessary to produce the .hex file we download.
MPLAB by itself only comes with PIC Assembly.
Unread 07-03-2007, 19:49
Nathan's Avatar
Nathan Nathan is offline
FRC #1501 (Team T.H.R.U.S.T.)
Rookie Year: 2007
Nathan has a spectacular aura aboutNathan has a spectacular aura aboutNathan has a spectacular aura about
All I did was install EasyC that came with the Vex Programming Kit, and then linked MPLAB to the EasyC compiler. Just read the two following threads in order and you should be fine. You don't have to buy anything either...
http://www.vexfan.com/viewtopic.php?t=4
http://www.vexfan.com/viewtopic.php?t=31
I hope that helps,
Nathan
Unread 07-03-2007, 21:51
Just Itinerant
Good catch.
I overlooked that they already have the C compiler with EasyC.
How do you manage code changes? ericand Programming 22 01-03-2006 03:56
Can I "type" code in EasyC? scottmso Programming 1 04-02-2006 07:22
how to convert Easy C code into real code? TheHolyLancer Programming 1 29-01-2006 09:09
Field Location of Type-0 and Type-1 IR Signals Travis Hoffman General Forum 3 27-02-2004 07:58
How much code can an IFI controller handle? Larry Barello Programming 7 10-02-2002 19:06
