Go to Post I began to see myself as an independent person who was not only being inspired, but able to inspire others and strengthen the FIRST program as a whole. - Jaine Perotti [more]
  #16   Spotlight this post!
Unread 08-03-2007, 10:26
Bob22341 Bob22341 is offline
FRC #1870
Bob22341 will become famous soon enough
Re: Mechanical Question about project Urgent!
If you are looking to recover energy lost by a car, you would be better off trying to recover heat from the engine and brakes.
  #17   Spotlight this post!
Unread 09-03-2007, 01:18
brennerator brennerator is offline
brennerator is an unknown quantity at this point
Thanks a lot guys; this is really informative.
I understand your arguments, and I too believe that I will not recoup enough. But I think it is a useful experiment. At the ver yleast I can learn more on this subject.
So I just basically stacked the PAPST large CPU fans on the hood of the car, perpendicular to the ground. I have 3 of these large fans. They are wired in series and connected to a resistor. I will use hte multimeter to read voltages when driving hte car at a variety of speeds. After this I will calculate the power and then I can see how much I generate. Unfortuantely I will not be able to see the increase of my drag coefficient with this assembly.
Any thoughts?
Once again; I cant thank you guys enough for your input.
  #18   Spotlight this post!
Unread 09-03-2007, 07:24
Unsung FIRST Hero
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Rookie Year: 1996
Brenn,
What is the part number of your fans. Most of the Pabst line is brushless.
Al
WB9UVJ
www.wildstang.org
________________________
  #19   Spotlight this post!
Unread 09-03-2007, 22:11
I was able to use my fan as a generator.
I used a 1 k-ohm resistor and read the voltage across the two leads.
My data as follows:
15 mph = 1.20 V
20 mph = 2.06 V
25 mph = 2.68 V
30 mph = 2.83 V
35 mph = 2.77 V
40 mph = 2.82 V
45 mph = 2.70 V
50 mph = 2.52 V
55 mph = 2.26 V
65 mph = 2.21 V
The fan probably was not designed to handle such high rpm's past 40 mph.
Can I make any conclusions from this data taht will allow me to test the efficacy of using fans. Please note that I was not able to calculate how much the overall drag coefficient increased on my car.
Thanks so much for all your help.
  #20   Spotlight this post!
Unread 09-03-2007, 23:23
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
You are making about one hundredth of one watt of power...that's not much!
P = E^2 / R
  #21   Spotlight this post!
Unread 10-03-2007, 00:16
hmm...is htere any practical usage for one hundredth of one watt of power? Remember that I have 5 of these fans. So its more like one twentieth of one watt of power.
  #22   Spotlight this post!
Unread 11-03-2007, 14:54
TubaMorg TubaMorg is offline
Programmermechanicalelect ricalcoach
AKA: Dan
FRC #1480 (Robatos Locos)
TubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond repute
Hey Bren, try wiring the fans in parallel and see what happens.
Urgent help with a project; brennerator Technical Discussion 3 05-03-2007 13:40
Urgent CMUCAM question silliewillie Programming 2 21-02-2005 15:09
Urgent!! (programming question) anupalsingh Programming 6 25-02-2004 10:53
How Do You Best Learn About Mechanical Stuff? sanddrag General Forum 51 02-09-2003 01:18
Urgent motor question Brett W Motors 2 13-02-2003 15:14
