Go to Post There is something to be learned (sometimes hard to find) from everyone you meet. - wireties [more]
Unread 06-03-2007, 13:43
bcieslak
Posts: n/a
Team 1675' s AutoFlex automous Program
Team 1675 is making their Autoflex autonomous programming tool available for the first time to any team who is finding they ran out of time to develop an autonomous feature.
It can be added to your existing program.
Basically it records 10 seconds of driver/operator commands that can be replayed during the automonous portion of a competiton. It has been used succesfully for the Triple Play and Aim High games the last two years.
Anyone interested in the code and instructions should contact team 1675 via k9wis@yahoo.com.
If you plan to be at the Wi regional look us up.
Brian
Unread 06-03-2007, 14:10
EHaskins EHaskins is offline
Needs to change his user title.
AKA: Eric Haskins
no team (CARD #6 (SCOE))
EHaskins has a reputation beyond reputeEHaskins has a reputation beyond reputeEHaskins has a reputation beyond reputeEHaskins has a reputation beyond reputeEHaskins has a reputation beyond reputeEHaskins has a reputation beyond reputeEHaskins has a reputation beyond reputeEHaskins has a reputation beyond reputeEHaskins has a reputation beyond reputeEHaskins has a reputation beyond reputeEHaskins has a reputation beyond repute
Send a message via MSN to EHaskins
Re: Team 1675' s AutoFlex automous Program
I assume you use EEPROM to store the data, but would you still have enough room after camera/tracking data?
You might want to consider posting a white paper on AutoFlex.
Eric Haskins KC9JVH
Unread 06-03-2007, 14:56
bcieslak
Posts: n/a
During the recording process the data is sent out the programmng port. Use hyperterm to capture the data. paste it into a command table, recompile the program and yoru set to go.
the draw back is that you have to follow the robot around with a laptop and serial cable during the programming process.
This is program is an emergency measure if you run out of time to develop a auto mode. It is not a substitute for real engineering.
Brian - K9WIS
Unread 06-03-2007, 16:34
meatmanek meatmanek is offline
Programmer/physicist/mathematician
FRC #0868 (TechHounds)
meatmanek is a splendid one to beholdmeatmanek is a splendid one to beholdmeatmanek is a splendid one to beholdmeatmanek is a splendid one to beholdmeatmanek is a splendid one to beholdmeatmanek is a splendid one to beholdmeatmanek is a splendid one to behold
Several years ago I wrote something similar. It's a really neat idea, but we had to scrap it because of the limited program space (pre-2006 controllers). Recording an autonomous mode is really nice, especially when you're in a pinch to make your robot go somewhere. I'm thinking we may even use recording as part of our autonomous this year.
What I'd really like to see is a program which can record from the OI's dashboard port.
Real programmers use vim.
Unread 06-03-2007, 21:13
Joe Ross Joe Ross is offline
FRC #0330 (Beachbots)
Rookie Year: 1997
The Labview dashboard will record and playback.
Unread 09-03-2007, 01:32
JohnC's Avatar
JohnC JohnC is offline
my other name is nigel
FRC #0360 (360 Revolution)
JohnC is a jewel in the roughJohnC is a jewel in the roughJohnC is a jewel in the roughJohnC is a jewel in the rough
Send a message via AIM to JohnC
Team 360 will soon be putting significant human resources into either:
1 using the EEPROM to record an autonomous routine
2 using another, larger EEPROM connected to the TTL->RS232 (as used in the CMU2 setup) to record an autonomous routine
Because as many of us know, "forever chasing the 'bot around" with a laptop and a serial cable becomes annoying.
What place are we at? ... TODAI!
Unread 13-03-2007, 22:28
seanwitte seanwitte is offline
None #0116
seanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant future
Send a message via AIM to seanwitte
This application includes a view that records PWM outputs and converts it to C source code to replay the recording. It requires a compile/download cycle to use it since it generates the code.
http://www.chiefdelphi.com/media/papers/1765
Unread 14-03-2007, 19:27
114Klutz 114Klutz is offline
AKA: Li Pi
FRC #2984 (Viking Robotics)
114Klutz is a jewel in the rough114Klutz is a jewel in the rough114Klutz is a jewel in the rough
Send a message via AIM to 114Klutz
114 has a similar system, although we sample the joystick inputs 10 times a second and store it in EEPROM.
Unread 14-03-2007, 20:29
DonRotolo's Avatar
Back to humble
FRC #0832
Please think to bring a copy to Buckeye, team 1676 will have jumpdrives ready for a copy...
Don
Automous Code? Raikon Programming 5 29-01-2007 01:13
pic: 1675 Thingamajig Kevin Kolodziej Extra Discussion 6 01-02-2006 17:51
so lost we need help with automous evilhunter Programming 2 21-02-2005 13:54
pic: 1675 Teaser #2 Kevin Kolodziej Robot Showcase 6 17-02-2005 09:27
2001 2002 in Automous SpaceOsc Control System 12 17-05-2004 01:52
