Go to Post The season ended. Not cool. - Koko Ed [more]
Go Back   Chief Delphi > Technical > CAD > Inventor
Unread 06-03-2007, 21:07
rohit's Avatar
rohit rohit is offline
Inventor Person
FRC #0617 (The Springers)
rohit has a spectacular aura aboutrohit has a spectacular aura about
Send a message via AIM to rohit
Few questions
I have a few questions before submitting:
Do I have to do all the tubing on inventor? :
http://img329.imageshack.us/img329/4...ture019uy9.jpg
Secondly,
Should I turn in the main picture (one that represents the robot the most) as folded up or unfolded?
http://www.chiefdelphi.com/media/img...96f8f2be_l.jpg
http://img260.imageshack.us/img260/2...enderedpd6.jpg
They aren't the final stuff.. I added more stuff and do materials and improve lighetning and stuff..
Unread 06-03-2007, 21:24
Robert Thacker-'s Avatar
Robert Thacker- Robert Thacker- is offline
2007 Autodesk Inventor Winner
FRC #0836 (RoboBees)
Robert Thacker- is a jewel in the roughRobert Thacker- is a jewel in the roughRobert Thacker- is a jewel in the roughRobert Thacker- is a jewel in the rough
Re: Few questions
Absolutely, doing anything outside of Inventor willl significantly impact your team score.
I am not sure what you mean by your final picture, but it should be a jpeg, and it should be a rendered image of your robot (not in a zip file).
Remember to put all your Inventor files in a zip folder and that THEY OPEN W/O ANY PROBLEMS.
and look at the submission criteria before you submit it to be sure that you have everything. Rmember that the deadline is 5:00 PT (8:00 Eastern).
Good luck this year!
Mentor on FIRST Team 836: The RoboBees
Alumni Team 103:
2005, 2006, 2007, & 2009 National Autodesk Inventor Award Winner
Unread 06-03-2007, 21:27
rohit's Avatar
Inventor Person
Re: Few questions
the final picture as in.. does it look better unfolded or folded?
And should if I don't make the tubes and wires on inventor, is it going to be a big deal?
Unread 06-03-2007, 21:32
Re: Few questions
tubes are one of those unnecessary things that you do only if you have the time. I don't think that you need them, or could finish them, in time for the entry deadline.
Personally, I think you see the whole robot image mre clearly when your robot is unfolded.
Looks Good!
Alumni Team 103:
Unread 06-03-2007, 21:57
rohit's Avatar
Inventor Person
Re: Few questions
Alrighty, thanks for the help! I'll spend the rest of the time left rendering
Unread 07-03-2007, 09:07
JD Mather's Avatar
JD Mather JD Mather is offline
JD Mather is a jewel in the roughJD Mather is a jewel in the roughJD Mather is a jewel in the roughJD Mather is a jewel in the rough
Re: Few questions
If you find the time to model the tubes I would first go through the document titled something like Getting Started with Routed Systems.pdf that you can find in the Inventor folder on your hard drive (I can't remember the exact name of the file but if you search on *.pdf you should find it.) There is an example of routing stainless steel tubing that would be appropriate for your design - just change the color to match your tubing.
A few questions Chase General Forum 15 14-08-2005 13:29
A few questions... Ryan Dognaux 3D Animation and Competition 3 19-02-2005 22:48
[OCCRA]:a few questions.. Jimmy Holmes OCCRA Q&A 1 28-09-2004 18:47
A few questions cheezewiz Programming 7 31-01-2004 00:02
A few questions goegan31 Regional Competitions 1 09-03-2003 20:32
