Go to Post ...It's two years old, but GP is GP. - Brandon Martus [more]
Unread 07-03-2007, 14:05
magical hands magical hands is offline
Jigar Patel
AKA: Jigar Patel
FRC #2185 (Etobicoke CI)
magical hands is on a distinguished road
LCD Doesn't work :(
I tried hooking up my LCD to TTL but it doesn't work Could it be that the TTL is not functioning properly or is it the wiring. I took the LCD and it has this backpack on it. http://www.sparkfun.com/commerce/images/SerLCDv2-3.jpg
In the picture there are two but our backpac has the female end to it. and it has GND, 5V and RX so I took at pwm cable and placed it inside those three holes make sure that the black goes to GND, red goes to RX and white goes to 5V. Than I took that pwm cable and attached it to a TTL chip, the one that came with camera. Then mounted that TTL chip on the TTL port. After all that I took kevin's code and downloaded, because according to the code the LCD is suppose to work automatically I assume. I see nothing all blank no power nothing in LCD. Can someone please tell me where I possibly went wrong?
this is the LCD we are using:
http://www.sparkfun.com/commerce/ima...n-16x2-New.jpg
Unread 07-03-2007, 14:50
EHaskins EHaskins is offline
Needs to change his user title.
AKA: Eric Haskins
no team (CARD #6 (SCOE))
EHaskins has a reputation beyond reputeEHaskins has a reputation beyond reputeEHaskins has a reputation beyond reputeEHaskins has a reputation beyond reputeEHaskins has a reputation beyond reputeEHaskins has a reputation beyond reputeEHaskins has a reputation beyond reputeEHaskins has a reputation beyond reputeEHaskins has a reputation beyond reputeEHaskins has a reputation beyond reputeEHaskins has a reputation beyond repute
Send a message via MSN to EHaskins
Re: LCD Doesn't work :(
EDIT: YOU DO NOT WANT THE CONVERTER CHIP!!!!!!
The chip is converting from TTL to rs232. The backback uses TTL.
The wires on the TTL converter chip do not have power. They are rx/tx/gnd( I don't know the order). Get power from a digital IO, and then try it with just the rx pin of the backback to the TX of the RC.
Do what i said below, and if it still doesn't work you may have damaged the backback.
/EDIT
Get power from a digital io. Don't connect the LCD to the serial port, just power. You should get:
SparkFun
SerLcd 1.0
or somthing similar. If you backback has been configured differentially it may not show the message, but its backlight should come on.
If you get light or message then connect just the rx pin to the tx pin of the TTL port.
Other than that I have used that device on an EDU and Vex without any issues.
Eric Haskins KC9JVH
Unread 07-03-2007, 15:02
Mark McLeod's Avatar
Just Itinerant
AKA: Hey dad...Father...MARK
FRC #0358 (Robotic Eagles)
I imagine you just have your wires crossed somehow.
Describe the connections you made on the FRC TTL port end.
Here's a quick reference chart we use. The FRC TTL port is on the lower left... http://team358.org/files/programming...erialPorts.jpg
Traditionally, we use red for 5v power and white for signal, but as long as you're careful...
Are you doing this on the Full-Sized Robot Controller, Vex, or EDU?
P.S. Rereading this I forgot to make it clear that I agree with Eric about removing the TTL converter chip.
Unread 07-03-2007, 15:12
ay2b's Avatar
ay2b ay2b is offline
AKA: Andy
FRC #2928
Rookie Year: 1994
ay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant future
Originally Posted by magical hands View Post
... it has GND, 5V and RX so I took at pwm cable and placed it inside those three holes make sure that the black goes to GND, red goes to RX and white goes to 5V. ...
Typically on the IFI PWM wires, red is +5V and white is "signal". You might try reversing those in your setup. Of course, what really matters is what's connected at the other end. Make sure that the RX of the LCD panel is connected to the TX on the RC.
2011 - SD Quarterfinalists (980), LA Quarterfinalists (980)
2010 - LA (2404) Finalists (980), AZ Motorola Quality (980)
2009 - LA Semifinalists (980); Las Vegas Quarterfinalists (980); SD (2404); IRI #1 Seed, Finalist (980)
2008 - SD Quarterfinalists (980), LA Champions (980), LA Rookie Inspiration Award (2404); CalGames Finalists
2007 - So.Cal Finalists (980), SD Quarterfinalists (980); CalGames Finalists
2006 - So.Cal Regional Champion (4), Toronto Judge's Award Day 1 (4)
2005 - SVR Champions, Delphi "Driving Tomorrow's Technology" (980); AZ Xerox Creativity (980); So.Cal Finalists, RadioShack Innovation in Control (980); Championship Archimedes Division Semifinalists; IRI Finalists (980)
2004 - So.Cal Regional Champions, Leadership in Controls (980); AZ GM Industrial Design (980); Championship Galileo Division #2 Seed; IRI Champions
2003 - PNW Semi-finalists (488)
2002 - PNW Finalists (488)
2000 - X-bot / 488 - Mentor / Founder
1994 - Sunny Delight - Driver - champion
Unread 07-03-2007, 15:26
karlcswanson's Avatar
karlcswanson karlcswanson is offline
FRC #0111 (WildStang)
karlcswanson is just really nicekarlcswanson is just really nicekarlcswanson is just really nicekarlcswanson is just really nicekarlcswanson is just really nice
Make sure you have the correct baud rate.
Unread 07-03-2007, 23:46
Jigar Patel
AKA: Jigar Patel
i did connect LCD to digital Input and it didn't work. I used digital input 6 and nothing powered up. So what should my next step be?
Unread 08-03-2007, 20:37
AKA: Eric Haskins
If it didn't work off the digital input I wouldn't be surprised if the rs232 signal damaged the board.
Check the solder at each of the connections between the backpack and the LCD.
If you can't find any problems I would suggest contacting SparkFun support spark@sparkfun.com.
Eric Haskins KC9JVH
My Chicklet doesn't work r_is_for_ROSER Control System 6 26-02-2007 11:20
Why doesn't this work??!??!!?!!!?!? HuskieRobotics Programming 13 05-03-2004 00:20
Arrrrrrrg... PM alert doesn't work DanL CD Forum Support 9 08-05-2003 14:32
Robot reset on OI doesn't work Carl Owenby General Forum 1 07-02-2003 07:23
sensor doesn't work PBoss Programming 7 29-01-2003 18:39
