**FIRST**FVC Team Update**
Hello Teams:
We have just a few things to cover with you today. Software Template Update A note from the director of FVC regarding the most current software template information - this information was sent in February, but it's important so we're resending it in case some teams may have missed it: Dear Teams, FIRST is still hearing about small issues with the template and master code. To the best of our determination, these problems have been related to incorrect versions of the template or master code. In a few other cases, the cause has been problems with the teams own code. FIRST is committed to trying to reduce the confusion and help teams have the proper foundation for their own code. The attached document is an updated version of the guidance on the template and master code. The changes are related to the problem described below. Recently it has noticed that if the Master code for MPLAB is used with EasyC, the robot will work correctly with the jumpers during testing and the autonomous portion of the match will work correctly. The robot will not transition to operator controlled mode making it useless during that portion of the competition. Please make sure that you are using the correct master code. For Easy C use the master code included in EasyC v.2.8.0.1 or download it from http://www.intelitekdownloads.com/FVC2006/ or http://www.vexrobotics.com/programming. FIRST cannot confirm the correctness of master code obtained from other sources. Thank you, George Marchant <><><><><><><><><><><><><><><><><><><><><><><><><> <><><><><><> Batteries and Battery Chargers Because of the similarities in the equipment each team uses, we strongly recommend that you put your team number on your batteries and your battery chargers so you don't leave them behind! Go Teams! FVC Support <Same attachment as in previous emails> |
| **FIRST** **FVC Team Info** **Important Template Info** | Mark McLeod | FIRST Tech Challenge | 0 | 21-02-2007 12:41 |
| **FIRST EMAIL**/Important Team Update Posted - could affect your build | Damian Manda | FIRST E-Mail Blast Archive | 0 | 12-01-2007 22:54 |
| FIRST releases Team Update #18 | Aidan F. Browne | General Forum | 25 | 29-03-2005 21:14 |
| *UPDATED* Compiled 2005 FIRST Manual (Includes Team Update #3) | Michael Hill | General Forum | 0 | 18-01-2005 22:54 |
| Official FIRST Team Update | Jake Lewis | Rules/Strategy | 1 | 13-01-2004 20:03 |
