Go to Post And I have to say, those days where you are just beating yourself, and smacking your head against the wall, and you just wish the robot would catch fire so you could go home, make the top of the mountain that much sweeter. - Gboehm [more]
Unread 08-03-2007, 15:39
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
Rookie Year: 1999
Tom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond repute
Using two motors in the tandem
We are considering using the Denso Window Motor and the globe motor together on the same chain. One has a free RPM of 85 and the other 82.
Will this cause problems? With the close RPM, I don't think it should create a huge issue. Of course we were worried about one trying to drive the other - but we're going to use a y-PWM cable with victors for each.
I suspect it won't have a problem with the match lengths we're talking about.
Has anyone out there done something similar?
The globe says it has a 150 in-lb of torque which is 16.9 Nm. The window motor has 12 Nm.
We are only going to turn them through 1/2 a rotation.
[FVC]: MPLab using two transmitters emmell FIRST Tech Challenge 2 24-02-2007 00:33
Using two CIMs in the Banebots Transmission Justin M. Technical Discussion 15 09-01-2007 09:41
Problem using two transmitters jamesgecko FIRST Tech Challenge 9 12-05-2005 09:30
Is Anyone Using Motors to Hoist themselves off the platform on the bar? xxlshortys Motors 36 25-02-2004 01:06
Using two Large PAPST Fans? SuperDave Electrical 9 17-02-2003 15:11
