Go to Post Seeing a bunch of teams from Indiana and probably Michagin competing at the same time.... If I wanted to see that, I'd just go to the Championship in Atlanta. :yikes: - Barry Bonzack [more]
Unread 09-03-2007, 13:26
RickErmer RickErmer is offline
FRC #0073
RickErmer is an unknown quantity at this point
How to copy a project in MPLAB IDE
I want to copy an existing project / workspace that has our working code to a new project so I can write some test code but still be able to keep the working code intact. I tried just copying the folder the workspace was in and renaming the folder, but it still thought the source files were in the original folder.
If I use the new project wizard, it doesn't come with the proper options as a default and I seem to have missed something because now the code doesn't compile.
Thanks,
Rick
MPLAB IDE rholokleolke Programming 13 08-12-2006 18:32
MPLAB IDE Problem amateurrobotguy Programming 10 26-02-2005 09:29
MPLAB IDE 6.60 Error mchan1111 Programming 8 08-11-2004 20:17
MPLAB IDE Project Specs Raven_Writer Programming 18 19-01-2004 15:53
using the MPLAB IDE MPLAB SIM simulator WizardOfAz Programming 1 03-11-2003 01:24
