Go to Post Can you describe how you utilized your human head device on your intake? - Kevin Ainsworth [more]
Unread 10-03-2007, 20:21
magical hands magical hands is offline
Jigar Patel
AKA: Jigar Patel
FRC #2185 (Etobicoke CI)
magical hands is on a distinguished road
Question execute.h
I am currently working on the structure of the autonomous mode. I created an autonomous code structure in execute.c Is it possible so that i can call Do_execute(); in autonomous mode and it will work? In execute.c I am using many of gyro and encoder functions. So when I move them to autonomous in useroutines_fast.c. will all those gyro and encoder functions will work?
Unread 10-03-2007, 20:28
JamesBrown JamesBrown is offline
Back after 4 years off
FRC #5279
JamesBrown has a reputation beyond reputeJamesBrown has a reputation beyond reputeJamesBrown has a reputation beyond reputeJamesBrown has a reputation beyond reputeJamesBrown has a reputation beyond reputeJamesBrown has a reputation beyond reputeJamesBrown has a reputation beyond reputeJamesBrown has a reputation beyond reputeJamesBrown has a reputation beyond reputeJamesBrown has a reputation beyond reputeJamesBrown has a reputation beyond repute
Re: execute.h
You should be able to, there is no difference (ok this isn't completely true but close enough so you can assume it is) between calling a function and just copying and pasting it into the code.
I'm Back
5279 (2015-Present)
3594 (2011)
3280 (2010)
1665 (2009)
1350 (2008-2009)
1493 (2007-2008)
1568 (2005-2007)
Unread 10-03-2007, 21:02
Jigar Patel
AKA: Jigar Patel
Re: execute.h
here in the attachment is my execute. c
and i want to call the function in userroutines_fast.c, so this is what i am doing:
while (autonomous_mode) /* DO NOT CHANGE! */
// new ADC data available?
if(Get_ADC_Result_Count())
Process_Gyro_Data();
Reset_ADC_Result_Count();
if (statusflag.NEW_SPI_DATA) /* 26.2ms loop area */
Getdata(&rxdata); /* DO NOT DELETE, or you will be stuck here forever! */
/* Add your own autonomous code here. */
/******* 1219 Autonomous Code Starts Here*********************/
i++;
j++; // this will rollover every ~1000 seconds
if(j == 60)
// start a gyro bias calculation
Start_Gyro_Bias_Calc();
if(j == 300)
// terminate the gyro bias calculation
Stop_Gyro_Bias_Calc();
// reset the gyro heading angle
Reset_Gyro_Angle();
printf("Done\r");
if(i >= 30 && j >= 300)
temp_gyro_bias = Get_Gyro_Bias();
temp_gyro_rate = Get_Gyro_Rate();
temp_gyro_angle = (Get_Gyro_Angle()/100);
printf(" Gyro Bias=%d\r\n", temp_gyro_bias);
printf(" Gyro Rate=%d\r\n", temp_gyro_rate);
printf("Gyro Angle=%d\r\n\r\n", (int)temp_gyro_angle);
i = 0;
/*************GYRO CODES ENDS HERE ***************/
/************Processing Camera Information************/
Tracking_Info_Terminal();
Camera_Handler();
Servo_Track();
/********Camera Processing Ends Here********/
if(Get_Tracking_State() == CAMERA_ON_TARGET)
Do_executive(); // Runs the function from execute.c
PWM(pwm13,pwm14,pwm15,pwm16);
Putdata(&txdata); /* DO NOT DELETE, or you will get no PWM outputs! */
EasyC: Execute code before autonomous Greg Marra Programming 7 07-01-2007 21:30
How I can execute Javascript into Perl? TomS Programming 3 22-08-2006 16:35
