Go to Post Iteration is a necessary but not sufficient criteria to being a powerhouse team. - Chris is me [more]
Unread 11-03-2007, 15:26
magical hands magical hands is offline
Jigar Patel
AKA: Jigar Patel
FRC #2185 (Etobicoke CI)
magical hands is on a distinguished road
Need help with gyro turn
I have gyro onto the robot. As soon as i get the angle from the cam. I want my gyro to turn exactly at that angle. so for e.g. my pan angle is 34 degrees than i want my robot to turn 34 degree. However, my Gyro just can't do that. Can someone help me how can i code it so it turns the angle i want it to turn? this is what i have.
/********VARIABLE*******/
int unit_speed = 50;
angle = ((((int)PAN_SERVO - 124) * 65)/124); /* +/- 65 degree [0 to 148] */
error_angle = (angle - (int)temp_gyro_angle); /*Check the angle difference between camera and Gyro*/
printf("Error_angle=%d\r\n", error_angle); /*Print Error Angle*/
if (error_angle < -5) /*If Error angle is less than 5 degrees*/
speed = ((error_angle * unit_speed)/100); /*PID Forumula to control the speed as we move close to target*/
printf("Target is to the left\r\n"); /*Prints if target is to left*/
while(speed > 5)
pwm13 = pwm14= 127; /*Turning Left and the turn is controlled, see below comment*/
pwm15 = pwm16 = 127 + speed; /*The motor movements are controlled by the PID Speed Calculated*/
printf("PWM 13=%d pwm14=%d pwm14=%d pwm15=%d\r\n", (int)pwm13, (int) pwm14, (int) pwm15, (int) pwm15); /*Printing motor values for Debugging*/
printf("Speed=%d\r\n", speed); /*Tells us what is the value of speed according to PID Calculation*/
if (error_angle > 5) /*If Error angle is greater than 5 degrees*/
speed = ((error_angle * unit_speed)/100); /*PID Formula to control the speed as we move close to the target*/
printf("Target is to the right\n"); /*Prints that the target is to right*/
while(speed > 5)
pwm13 = pwm14 = 127 + speed; /*Turning Right and the turn is controlled, see below comment*/
pwm15 = pwm16 = 127; /*The motor movements are controlled by the PID Speed Calculated*/
if (error_angle > -5 && error_angle < 5) /*If the error angle is between -5 degree and + 5 degree*/
printf("Target is straight on"); /*Prints that we are right on target*/
pwm13 = pwm14= pwm15 = pwm16 = 127; /*Stops our motor for a while*/
printf("PWM 13=%d pwm14=%d pwm15=%d pwm16=%d \r\n", (int)pwm13, (int) pwm14, (int) pwm15, (int) pwm16); /*Printing motor values for Debugging*/
printf("Speed=%d \r\n", speed); /*Tells us what is the value of speed according to PID Calculation*/
KOP Gyro seems to run-on after turn stops PhilBot Control System 8 05-03-2007 12:43
Need help with Gyro = Analog Devices ADXRS150EB Jack Jones Technical Discussion 9 18-07-2005 07:00
With gyro need to access ADC for poteniometer mrozek Programming 0 21-02-2005 13:39
hey need some help with writing a code please help me here magical hands Programming 9 01-01-2004 21:46
Help with the gyro chip Team852 Electrical 1 10-01-2003 22:31
