Go to Post Inventing rocks. I think we've all learned that through FIRST. - Billfred [more]
Unread 15-03-2007, 15:03
Joe P Joe P is offline
Joe P will become famous soon enoughJoe P will become famous soon enough
Fisher-Price 00968-9012 motor pinion
Does anybody have information on the 19T pinion gear that comes on the Fisher Price motor in the kit?
I think it has a 32 PD and a 20 degree pressure angle???
Thanks in advance
Joe P
Unread 15-03-2007, 15:06
Veselin Kolev's Avatar
Veselin Kolev Veselin Kolev is offline
X51 Production Company PGM (TM)
Veselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond repute
Re: Fisher-Price 00968-9012 motor pinion
Yes, in the history of the FP motors, they've generally been 32 pitch 20* pressure angle. The only variance has been no. of teeth.
Unread 03-04-2007, 19:25
Superstitions's Avatar
Superstitions Superstitions is offline
Gadget Wizard
FRC #0039
Superstitions is an unknown quantity at this point
Hi. The FP gearboxes are metric ie Module. The small pinion on the F-P motor itself is 0.8 Module and it is a 20 degree pressure angle. These calculate out to american 31.75dp. Meshing the F-P motor and native 0.8module pinion with a standard 32dp off the shelf gear from the good 'ol USA is ok for our robot applications. We have done it for two years now and even under a high load they always held up for arms, turrets, transmissions, etc. We cut the gears ourselves. However if you were designing a transmission that will go several billion revs and needed to be ultra-quiet you would obviously mate the pinion with a true Metric gear.
Jeff- team gearcutter
Unread 03-04-2007, 19:31
AdamHeard's Avatar
Lead Mentor
FRC #0973 (Greybots)
For reference; If you need a true 32DP gear for the FP motor, the sun gear for the AM planetary is a nice fit. It is ready to press onto a FP shaft and is 15T 32DP.
Fisher Price Motor 9003 vs 9012 Mike Norton Motors 5 07-02-2007 19:27
Fisher Price Motor Andrew Y. Motors 2 20-11-2006 07:52
fisher-price pinion gear bill mc gowan Motors 6 06-03-2006 11:14
Fisher Price Pinion Pressure Angle alphastryk Motors 1 04-02-2006 21:06
Fisher Price Motor .. Important! Paul Copioli Motors 7 22-01-2003 13:55
