Go to Post You mean to tell me there's a weight limit this year?!?!?!!? - Carlo [more]
Unread 19-03-2007, 17:17
cbale2000's Avatar
cbale2000 cbale2000 is offline
AKA: Chris Bale
FRC #0703 (Phoenix)
Team Role: Leadership
cbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond repute
pic: The 2007 Team 703 Phoenix Robot
Unread 19-03-2007, 17:18
cbale2000's Avatar
AKA: Chris Bale
FRC #0703 (Phoenix)
Re: pic: The 2007 Team 703 Phoenix Robot
Better late then never I suppose. Here is our 2007 Robot.
The image in the top left shows a view of our 14 wheel drive and our Carbon Fiber "Riser".
In the top right is an image of our arm mock-up (I didn't have any good shots of our finished arm but it's basically the same only made out of lexan and aluminum).
The bottom left image shows our robot with ramps in the starting configuration just before we shipped the robot.
And finally the image on the bottom right shows our ramps fully deployed (Not all of the side rails were installed when the picture was taken).
Unread 19-03-2007, 17:22
Nikhil Bajaj Nikhil Bajaj is offline
MATLAB Fan
FRC #0461 (Westside Boiler Invasion)
Nikhil Bajaj has a reputation beyond reputeNikhil Bajaj has a reputation beyond reputeNikhil Bajaj has a reputation beyond reputeNikhil Bajaj has a reputation beyond reputeNikhil Bajaj has a reputation beyond reputeNikhil Bajaj has a reputation beyond reputeNikhil Bajaj has a reputation beyond reputeNikhil Bajaj has a reputation beyond reputeNikhil Bajaj has a reputation beyond reputeNikhil Bajaj has a reputation beyond reputeNikhil Bajaj has a reputation beyond repute
Send a message via AIM to Nikhil Bajaj
I have always liked 703's drive train and design sensibilities in general...keep up the good work! I was trying to get 461 to use carbon fiber/nomex panel for the ramps but it didn't work out.
What is the "sandwiched" material in your panels? Nomex? Aluminum? Something else?
Unread 19-03-2007, 17:28
cbale2000's Avatar
AKA: Chris Bale
FRC #0703 (Phoenix)
Thanks, we're very proud of our drive train this year. Our goal was to fix the issues we had had with our tracks breaking in previous years robots, so instead of dealing with all the belts, we just came up with this. It simulates many of the advantages of a tread system and adds the reliability of gears and wheels.
We used Divinycell foam for the sandwiched material as it had much more compression strength than typical Styrofoam but was still very lightweight.
Unread 19-03-2007, 18:09
EricH's Avatar
EricH EricH is offline
New year, new team
FRC #1197 (Torbots)
That bottom left one better have the ramps slightly out of starting position, or you've got some work at your first event. (If the ramp on the right is in the box, that's an awfully small robot.)
How do you deploy the ramps? Did you keep the arm (I can't see it in the bottom two pictures)?
Past teams:
2003-2007: FRC0330 BeachBots
2008: FRC1135 Shmoebotics
Unread 19-03-2007, 18:15
ChrisMcK2186's Avatar
ChrisMcK2186 ChrisMcK2186 is offline
Typer of doom
AKA: Chris McKenzie
FRC #2186 (Westfield Robotics)
Rookie Year: 2007
ChrisMcK2186 is a glorious beacon of lightChrisMcK2186 is a glorious beacon of lightChrisMcK2186 is a glorious beacon of lightChrisMcK2186 is a glorious beacon of lightChrisMcK2186 is a glorious beacon of lightChrisMcK2186 is a glorious beacon of light
Send a message via AIM to ChrisMcK2186
Are your wheels in a gentle "U" shape? My team is trying to perfect our drive train for next year so we are looking around. Would you recomend this?
Chris
Working on Robotic Eagles group(PM for info)
Stephen Colbert-"Please tell me this leads to robot
battles."
Dean Kamen-"It does lead to kids building robots, and they do compete in the sport but we also teach the kids gracious proffesionalism, so while the robots are competing, they do it in a very, very gracious way."
Darn, I got into this for the battles!
Unread 19-03-2007, 18:19
Grant Cox's Avatar
Grant Cox Grant Cox is offline
Back for more.
FRC #0148 (Robowranglers)
Team Role: Tactician
Rookie Year: 2007
Grant Cox has a reputation beyond reputeGrant Cox has a reputation beyond reputeGrant Cox has a reputation beyond reputeGrant Cox has a reputation beyond reputeGrant Cox has a reputation beyond reputeGrant Cox has a reputation beyond reputeGrant Cox has a reputation beyond reputeGrant Cox has a reputation beyond reputeGrant Cox has a reputation beyond reputeGrant Cox has a reputation beyond reputeGrant Cox has a reputation beyond repute
sup defensive POWERHOUSE haha. I really enojoyed getting pushed around the rack by that at Detroit
VEX Robotics Marketing Manager
ThunderChicken driver '07-'08
Robowrangler '13-present
FIRST in Michigan, VEX Worlds, and FIRST in Texas MC/Game Announcer '08-present
Unread 19-03-2007, 18:22
cbale2000's Avatar
AKA: Chris Bale
FRC #0703 (Phoenix)
Yeh, we solved that problem by pulling the ramps in so they fit square inside the starting configuration, We just didn't have the cables attached in that picture.
The ramps get deployed by being retracted up and to the center of the robot by our winch system to a point where they are no longer restricted by the bumpers, our spring hinges then take care of popping them out and we then reverse the winch to allow them to slide out.
It isn't the fastest process (takes about 5-7 seconds to deploy fully) and we had a few issues with it in Detroit which we believe we have addressed (deploying early, getting stuck, ect.).
We did not attach the arm in Detroit, we knew we had to make an new mast for it after we shipped it in order to make weight at the regionals and because the gearing needed to be ajusted, we just never got the time to attach the new mast in Detroit due to all the troubleshooting we did with the ramps.
I'm hoping we can get it on for West Michigan, if not, expect to see it at least once or twice at Nationals.
Chris
Yes, the whole thing is actually in a huge ark. I couldn't tell you the angle right off hand, but its REALLY big. The best part is that the whole thing turns smoothly on a dime!
Kati_Kat's Avatar
Kati_Kat Kati_Kat is offline
Public Relations Girl
AKA: Kati
FRC #0703 (Phoenix)
Team Role: Communications
Kati_Kat is on a distinguished road
Send a message via AIM to Kati_Kat Send a message via MSN to Kati_Kat
God, I love our robot. It was amazing in action at Detroit.
Phoenix 703
* 2005 Kettering Kickoff Champions
* 2006 Kettering Kickoff Champions
* 2007 Detroit Regional Sportsmanship Award Winners
* 2007 West Michigan Regional Champions
Unread 19-03-2007, 19:16
rachal's Avatar
rachal rachal is offline
multipurpose tool
AKA: Rachel
FRC #1072 (Harker Robotics)
rachal is just really nicerachal is just really nicerachal is just really nicerachal is just really nicerachal is just really nice
Send a message via AIM to rachal
That drivetrain is a beast.
2005 Sacramento Winners with 245 and 766
2005 SVR Semi-Finalists with 840 and 668
2005 SVR Judges Award
Unread 05-04-2007, 13:52
Greg Ross's Avatar
Greg Ross Greg Ross is offline
Grammar Curmudgeon
AKA: gwross
FRC #0330 (Beach 'Bots)
Rookie Year: 1998
Greg Ross has a reputation beyond reputeGreg Ross has a reputation beyond reputeGreg Ross has a reputation beyond reputeGreg Ross has a reputation beyond reputeGreg Ross has a reputation beyond reputeGreg Ross has a reputation beyond reputeGreg Ross has a reputation beyond reputeGreg Ross has a reputation beyond reputeGreg Ross has a reputation beyond reputeGreg Ross has a reputation beyond reputeGreg Ross has a reputation beyond repute
Send a message via AIM to Greg Ross Send a message via Yahoo to Greg Ross
Careful! I think Beatty has that trademarked.
Greg Ross (The Grammar Curmudgeon formerly known as gwross)
S/W Engineer, Team 330, the Beach 'Bots
<--The Grammar Curmudgeon loves this cartoon.
“Life should not be a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside in a cloud of smoke, thoroughly used up, totally worn out, and loudly proclaiming "Wow! What a Ride!" Hunter S. Thompson
"Playing a practical joke means doing something mean and calling it funny." Me
Unread 05-04-2007, 14:17
Rich Ross Rich Ross is offline
Let's get Desperate!!!
AKA: 830 Alumni
FRC #1504 (The Desperate Penguins)
Rich Ross has a reputation beyond reputeRich Ross has a reputation beyond reputeRich Ross has a reputation beyond reputeRich Ross has a reputation beyond reputeRich Ross has a reputation beyond reputeRich Ross has a reputation beyond reputeRich Ross has a reputation beyond reputeRich Ross has a reputation beyond reputeRich Ross has a reputation beyond reputeRich Ross has a reputation beyond reputeRich Ross has a reputation beyond repute
Send a message via AIM to Rich Ross
Watch out for this robot. Galileo, time to learn about defense the Saginaw way! These guys will push you 90% of the time.
1504, finalists WMR and judges award GLR
Let's get Desperate.
Unread 19-03-2007, 19:17
Alex Cormier's Avatar
Alex Cormier Alex Cormier is offline
www.TwoPencilDesigns.com
AKA: Grizz, Twinkletoes, PitBull1126
FRC #1405
Team Role: Coach
Alex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond repute
about time i see a picture of this robot! Now let's see some video!
Two Pencil Designs - Vinyl Graphics, Bumper Numbers, and Strategy Items!
Like us on Facebook & follow us on Twitter
Facebook.com/TwoPencilDesigns & TwoPencilDesign
Unread 19-03-2007, 19:19
cbale2000's Avatar
AKA: Chris Bale
FRC #0703 (Phoenix)
I didn't have a video camera there and our team videographer couldn't make it, though I think a few members did take some video so I'll have to ask around a bit to find some.
  #15   Spotlight this post!
Unread 19-03-2007, 19:54
POLISH703's Avatar
POLISH703 POLISH703 is offline
The special mentor on the team.
AKA: Joe
FRC #0703 (Phoenix)
POLISH703 has a spectacular aura aboutPOLISH703 has a spectacular aura about
Send a message via AIM to POLISH703
Wow, a picture of us. Glad you posted it. Nice work Chris.
Fear the Fro!
pic: Team 968 - 2007 Robot Travis Covington Extra Discussion 16 06-03-2007 20:10
pic: Team 1345's 2007 Robot, The Condor. Arefin Bari Robot Showcase 22 23-02-2007 20:18
pic: Team Phoenix - 703 at Buckeye MattB703 Extra Discussion 1 03-04-2006 15:57
pic: Team 703 Phoenix POLISH703 Robot Showcase 6 07-03-2005 12:39
pic: Phoenix 703 "almost done" MattB703 Robot Showcase 13 16-02-2005 14:34
