Go to Post Analysis is a tool. Like any other tool you need to figure out where and when to use it. That's the tricky part. - ChrisH [more]
Go Back   Chief Delphi > Other > VEX
Thread Tools Rating: Thread Rating: 8 votes, 5.00 average. Display Modes
Unread 19-03-2007, 22:27
akaria akaria is offline
AKA: Erica Young
None #0587
Rookie Year: 2000
akaria has a spectacular aura aboutakaria has a spectacular aura about
Send a message via AIM to akaria
Using a VEX Receiver with Non-Vex Equipment
I just bought a vex transmitter/receiver "add-on" kit (It was cheap, os I figured it'd be useful ). Is there a way to modify the Vex receiver so that it has outputs like a standard multi-channel receiver module? (several connections, one for each channel, instead of a single serial line for all channels that goes to a vex controller)
I don't have a vex controller and I'd like to control normal servos and perhaps ESC'd motors off of the vex receiver.
Formerly: FIRST Team 587 Captain
Presently: NASA co-op
Unread 20-03-2007, 07:50
Gdeaver Gdeaver is offline
FRC #1640
Gdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond repute
Re: Using a VEX Receiver with Non-Vex Equipment
I believe that the Vex reciever needs a microcontroller to decode the pulse stream. You might want to look at this link. They have done most of the work for you. http://kronosrobotics.com/Projects/vexradio.shtml I've used these chips for many things and like the whole system. There is more than enough sample code on the site to get going.
Unread 20-03-2007, 10:33
SuperBK's Avatar
SuperBK SuperBK is offline
AKA: BrianK
FRC #1225 (Amperage Robotics)
SuperBK is just really niceSuperBK is just really niceSuperBK is just really niceSuperBK is just really nice
Did you buy it from allectronics.com? There is a spec sheet there that has a circuit and code:
http://www.allelectronics.com/cgi-bi...RECEIVER_.html
Brian K
Team 1225 Robotics Mentor
Unread 20-03-2007, 21:55
Devo1098 Devo1098 is offline
FRC #1098
Devo1098 is just really niceDevo1098 is just really niceDevo1098 is just really niceDevo1098 is just really niceDevo1098 is just really nice
hey, just get a standard hobby reciver, and plug in the vex crystal and it works, the hobby reciver already has the chips in it to output pwm for servos
super simple
Devo
Unread 22-03-2007, 02:16
AKA: Erica Young
None #0587
Rookie Year: 2000
super simple
I've tried that with a JR R610M 6-ch FM receiver from an old RC airplane, popped the vex rx crystal into it and nothing works. The transmitter and receiver are connected though, as when I turn on the transmitter, servos attached to the receiver will twitch. Just none of the controls on the vex transmitter do anything.
Any ideas? Should I find myself another 6-ch receiver?
EDIT: The JR receiver has an "ABC&W" circuit in it, perhaps this has something to do with why it doesn't talk to the vex transmitter?
JR Radio describes the ABC&W circuit as:
"JR has a unique signal processing system called ABC&W. ABC&W stands for Automatic Blocking Circuit with Window. ABC&W systems have distinct advantages over single or dual conversion receivers. ABC&W systems create a very small electronic window that looks for the specific frequency that the receivers crystal is on. Any signal that is off spec for this window is rejected, and then the allowed signal is cleaned up, amplified, and re-routed through the window many, many times till all that is left is the pure signal on the channel that is coming from your transmitter and then sent on to the servos. This all takes place without any noticeable delay of response from your stick movement to the servo. This technology is the reason that JR can produce single conversion receivers that have fewer components and weigh less than other single and dual conversion receivers without the worry about outside interference."
Unread 06-05-2007, 10:25
boyntonstu boyntonstu is offline
boyntonstu is an unknown quantity at this point
Question Re: Using a VEX Receiver with Non-Vex Equipment
super simple
Devo
Devo,
Does the 'standard hobby receiver' have to be PCM or just FM?
Does it have to be a 6 channel?
Have you tried any other brands besides Futaba?
Does the VEX transmitter have the same range as a Futaba?
Thanks,
BoyntonStu
Unread 06-05-2007, 15:40
gblake's Avatar
gblake gblake is offline
6th Gear Developer; Mentor
AKA: Blake Ross
no team (6th Gear)
gblake has a reputation beyond reputegblake has a reputation beyond reputegblake has a reputation beyond reputegblake has a reputation beyond reputegblake has a reputation beyond reputegblake has a reputation beyond reputegblake has a reputation beyond reputegblake has a reputation beyond reputegblake has a reputation beyond reputegblake has a reputation beyond reputegblake has a reputation beyond repute
hey, just get a standard hobby receiver, and plug in the vex crystal and it works, the hobby receiver already has the chips in it to output PWM for servos
super simple
Devo
Devo - Sorry to need to disappoint you, but I'm pretty sure that there is no such thing as a "standard" hobby receiver.
Originally Posted by boyntonstu View Post
Devo,
Have you tried any other brands besides Futuba?
Does the VEX transmitter have the same range as a Futuba?
Thanks,
BoyntonStu
Like I mentioned in my other reply (in the other thread), part of what you are asking is easily found on the VexLabs Parts and Accessories web pages. Here are a few things that might not be there. The Vex transmitter emits pulses of two different frequencies. When one frequency is on, the other is off. In this way a train of pulses is modulated into/onto the frequency of the transmitted signal (i.e. it uses FM)
The width of these pulses (from which you can derive their position (in time) in the periodic emissions of the transmitter), is used to encode the state of the operator controls that are part of the transmitter. While some folks like to call this Pulse Position Modulation (PPM), I think that they are confused and that it is more properly called Pulse Width Modulation (PWM).
The current Vex Transmitter/Receiver (Tx/Rx) do not use PCM.
There are a few other Tx/Rx characteristics (like the polarity of the transmitted PWM signals and each channel's location in the pulse train) that need to match before you can say that a non-Vex receiver will work with a Vex Transmitter. Sorry, but I forget if the idle state (what is output between pulse trains) of the Vex transmitter is its high freq (crystal freq plus ___ Hz) or its low (crystal freq minus ___ Hz) freq.
About the range question. You might have more luck asking "How long is a piece of string?" Without knowing anything about which of the many Futaba transmitters you have in mind, and without knowing (because I haven't found anywhere where they tell us) the output power of the Vex transmitter, and without knowing if the receiver you have in mind is truly well suited for use with the Vex transmitter; there is no way to answer your question.
Even if "we" knew all these things, without extensive or sophisticated investigation the answer would still be a guess.
One thing that might interest you is that all RC transmitters operating in the band Vex uses are limited (by the FCC) to supplying a maximum of 0.75W to their antenna. This will tend to give similar Tx/Rx parts a similar maximum range, if the transmitter is designed to emit the max wattage. For this reason I think that many people will gues "Yes" if they answer your question about ranges without having actually tested a Vex and at Futaba transmitter side-by-side in the field, or having opened them up to see if their circuitry is identical/similar.
Blake
Blake Ross, For emailing me, in the verizon.net domain, I am blake
VRC Team Mentor, FTC volunteer, 5th Gear Developer, Husband, Father, Triangle Fraternity Alumnus (ky 76), U Ky BSEE, Tau Beta Pi, Eta Kappa Nu, Kentucky Colonel
Words/phrases I avoid: basis, mitigate, leveraging, transitioning, impact (instead of affect/effect), facilitate, programmatic, problematic, issue (instead of problem), latency (instead of delay), dependency (instead of prerequisite), connectivity, usage & utilize (instead of use), downed, functionality, functional, power on, descore, alumni (instead of alumnus/alumna), the enterprise, methodology, nomenclature, form factor (instead of size or shape), competency, modality, provided(with), provision(ing), irregardless/irrespective, signage, colorized, pulsating, ideate
Unread 06-05-2007, 20:32
Blake
Blake,
I have read on several forums that Futaba receivers equipped with the VEX RX crystals worked well with the VEX TX.
The add-on VEX comes with 89, and I would imagine that any 'hobby' PWM receiver receiving on 89 would work.
Is my assumption accurate?
Unread 06-05-2007, 21:04
gblake's Avatar
AKA: Blake Ross
no team (6th Gear)
Maybe.
You say you are only considering PWM receivers. That is one correct criterion. Good.
But there are at least the other three criteria that I mentioned.
  • The transmitter's change in frequency around the center freq as it switches states during it's FM broadcasting needs to match what the receiver expects (this is probably the least of your worries, but it could theoretically bite you)
  • The polarity of the FM signals needs to match what the receiver expects (Is the high freq a "pulse" or is it a "rest"?).
  • The ordering of the channels will be an annoyance , but not fatal if that is the only incompatability with a non-vex receiver.
These are the thngs that come to mind as a result of studying this sort of Tx/Rx system for the last few days. There may be others.
Then you need to move to determining whether the receiver's output wiring/signals matches the wiring/signals of the equipment you want to connect to it....
The subject is a bit tangled, but research and/or careful trial and error testing can get you the answer. Without specifics, you are stuck in the land of "Maybe".
Blake
Unread 06-05-2007, 22:30
Maybe.
Blake
Blake,
Maybe is better than not possible.
Crystal: The channel 89 VEX RX crystal which comes with the add-on kit, is 'standard' sized and it apparantly fits Futabas, Bergs, and others. (Not so the TX crystal). (3 sets of VEX crystals (6) available for $10 on Ebay)
That leaves the polarity issue. TBD.
The TX takes 8 AA cells. Rechargeable NiCads in my fridge.
BoyntonStu
Unread 07-05-2007, 07:16
From: http://www.allelectronics.com/cgi-bi...tem=JS-6&type=
Works fine with Futaba receivers 02/05/2007
Reviewer: Larry Gitchell from Northlake, IL USA I have tried this radio with 2 different types of Futaba receiver. Works with both just by plugging the Vex crystal into the receiver. Unfortunately, the transmitter crystal has a non-typical spacing on the pins, so you can't change channels on the transmitter so easily.
and:
A very good 75 mhz transmitter 01/28/2007
Reviewer: A viewer from BROOKLYN, NY US
It's very hard to find a transmitter in 75 mhz, with 6 channels with mixing and at this price. I tested with my all 3 types of 75 mhz synthesized receiver (no crystal needed) all work with the transmitter. But the channel 1 to 4 are in reverse order is a easy fix, 5 and 6 ok. the receiver come with the kit was a loss.
Interesting.
Would have been better had he described the specific receivers.
If you were to pick one to try, which one?
BoyntonStu
Unread 07-05-2007, 07:58
gblake's Avatar
AKA: Blake Ross
no team (6th Gear)
Boyn - The choice is yours to make. You are right that specifics are needed. The receiver that doesn't need a crystal is intriguing. - Blake
Unread 02-01-2008, 21:57
FRC #1098
Very clever...
Unread 06-09-2008, 00:55
keen101's Avatar
keen101 keen101 is offline
Ubuntu Linux User
keen101 is a jewel in the roughkeen101 is a jewel in the roughkeen101 is a jewel in the roughkeen101 is a jewel in the rough
http://www.idleloop.com/robotics/3ksumo/
there have also been some circuits in Nuts and Volts magazine.
You do not need a VEX module to use the VEX tranmitter, you probably need a microcontroller though. I recommend an arduino or the Atmel AVR family. They are cross platform, and easy for beginners.
Trouble using Kevin Watson's Serial Code with Vex user API StargateFan Programming 3 13-01-2007 15:42
Non-FVC-specific Vex forum? Billfred CD Forum Support 6 15-08-2006 08:53
Using WPILib on a Vex robot koenig3456 Programming 2 02-05-2006 14:56
using non-vex motors MarkH Motors 3 23-04-2006 21:04
Using non joystick controls with Operator Interface (Hacking Various Controllers) Astronouth7303 Control System 58 02-02-2005 15:56
