pic: Buckeye Regional Pits
Re: pic: Buckeye Regional Pits
Those look pretty spacious compared to say GLR's pit setup...
lots more room there then at NJ this year.
I am ot happy with how FIRS set up the pits this year with the high/low number setup. It's very hard to find teams. If they do this at the championship it will be near impossible to find teams and make scouting very very difficult.
I must also say Buckeye's pits were more spread out than FLR's pits which were for some reason all squished together even though there was like 50 feet of empty space to the south towards the shop. |
Before I say anything too much about pits I must say that I truely enjoyed the Buckeye venue. I like this Regional. It is well run and the town has some great things going for it. I also like the fact that there is a Team Social for all to enjoy! Kudos to the planning committee and all those that helped.
About pit size, dimensions and room (or lack of): At Buckeye we had a corner pit and had more room (or so it seemed) than we did at GLR. I don't know if FIRST has a "standard" for pit dimensions, but I'd like to see it increased if they do. If we preach so much about safety...then to insure that we are not tripping over everything (safety hazard) we need to come up with a solution to allow easy movement in our pits (both inside the pit as well as the isles). After GLR I went out this past week and purchased some shelving and a new tool box to help consolidate pit "clutter" which drives me absolutely crazy! I will continue to try to maximize on the minimum that we get for our pits. We are working on solutions to make the compact size of pits work to our advantage. As you look around and see the vast amount of stuff we drag in to support our robots it truly becomes necessary to give some thought to this subject.As far as team number placement, yes it becomes very difficult to locate teams BUT I understand that we need to mix low number teams (older teams with experience) with those high number teams (newer team still learning) so as to be able to offer help and guidance. Just think if we had such a rigid system that place teams in the same numeric order at every Regional. We could easily find each other but then we'd never have new pit neighbors to meet and become friends with. My 2 cents |
I agree, though, it does make it hard to find teams sometimes. At NJ, they stuck with just doing highest->lowest. |
It may look like there was more room, but compared to GLR there is about half of the room..... It was very cramped, but due to having all of the pits in the actual stadium the ventilation was much better, and you could at least breathe, and not have your goggles fog up. I think that overall this was an amazing, and I know that our team will definitely be back.
#10
Man I wish there was room like this at every regional. Detroit was pretty bad as it usually is. I hope West Michigan is a little bit more spacious than it was last year.
#11
The place with the most room is the championships.
Compared to the regionals it's like a highway down there. |
#12
PNW had tons of space. The aisles between the pits were big enough to fit another row of pits
We also had a complete practice field, which helps when its everyone's first regional. |
| pic: Israel regional - working in the pits | David55 | Regional Competitions | 3 | 29-03-2006 15:06 |
| pic: Great Lakes Regional Pits | Joe J. | Regional Competitions | 12 | 14-03-2006 19:04 |
| Field in Pits at Lonestart Regional | raphael | Regional Competitions | 0 | 22-02-2005 19:28 |
| pic: Very Last Match At The Buckeye Regional | CD47-Bot | Extra Discussion | 4 | 12-03-2003 17:16 |
| Buckeye Regional | Shelley_delphi chick | Regional Competitions | 37 | 03-03-2003 14:57 |
