Go to Post If it's the loss of American lives that concerns the nation, why not campaign aggressively against smoking, or improve automobile safety? At least then, the benefits will be tangible, and substantially more significant to the well being of the locals. - Tristan Lall [more]
Unread 25-03-2007, 16:20
meatmanek meatmanek is offline
Programmer/physicist/mathematician
FRC #0868 (TechHounds)
meatmanek is a splendid one to beholdmeatmanek is a splendid one to beholdmeatmanek is a splendid one to beholdmeatmanek is a splendid one to beholdmeatmanek is a splendid one to beholdmeatmanek is a splendid one to beholdmeatmanek is a splendid one to behold
Victor light blinking quickly
At BMR we had an interesting electrical problem during one of the practice matches. One side of the drivetrain was getting very low power, in a sporadic fashion. (every once in a while, maybe 2 or 3 times per second it would get a small burst of low power)
Our drivetrain has 2 2.5" CIMs per side, each driven by their own Victor. Each side is controlled by a PWM Y-cable, so both of the victors were getting the exact same input.
When we took it back to the pits to investigate, we noticed these things:
1. When the motors were unplugged, the PWM lights worked as expected.
2. When we plugged the motors back in, one Victor's light would work as expected, but the other would blink quickly, roughly 2 Hz. This is faster than it blinks when it gets no signal. It would only blink when you tried to drive it - 127 would still yield an orange light.
3. We had arranged our quick disconnects improperly:
Victor side:
R1 R2
B1 B2
Motor side:
R1 R2
B2 B1
The improper wiring allowed both motors to work properly so long as both Victors worked properly. If both victors work, R1 and R2 will always be at the same voltage, and B1 and B2 will always be at the same voltage.
We rearranged the quick disconnects to correct it, and we haven't seen the fast blinking again. (Problem solved, so far as I'm concerned - we can replace the victor if necessary later on.)
However, I'm curious. What happened that made the Victor light blink quickly?
The quick blinking is not documented in the Victor 884 user's manual.
Real programmers use vim.
Unread 25-03-2007, 21:01
Eldarion's Avatar
Eldarion Eldarion is offline
Electrical Engineer / Computer Geek
AKA: Eldarion Telcontar
no team (Teamless Orphan)
Eldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond repute
Send a message via AIM to Eldarion Send a message via Yahoo to Eldarion
Re: Victor light blinking quickly
I believe this happens when the Victor senses that it cannot turn on properly in that particular direction. We had the same blinking light at Midwest, this was right after we smelled magic smoke and the Victor would not drive the motor in the direction that the light was blinking. The Victor worked fine in the other direction, though.
CMUCam not working? Tracks sporadically? Try this instead: http://www.falconir.com!
PM me for more information if you are interested (it's open source!).
Want the FIRST Email blasts? See here: http://www.chiefdelphi.com/forums/sh...ad.php?t=50809
"The harder the conflict, the more glorious the triumph. What we obtain too cheaply, we esteem too lightly; it is dearness only that gives everything its value."
-- Thomas Paine
If it's falling apart it's a mechanical problem. If it's spewing smoke it's a electrical problem.
If it's rampaging around destroying things it's a programming problem.
"All technology is run on 'Magic Smoke' contained within the device. As everyone knows, whenever the magic smoke is released, the device ceases to function."
-- Anonymous
I currently speak: English, some German, Verilog, x86 and 8051 Assembler, C, C++, VB, VB.NET, ASP, PHP, HTML, UNIX and SQL
Blinking Red Light teh_pwnerer795 Programming 8 21-12-2006 23:13
Program light is blinking red elsacr FIRST Tech Challenge 1 27-02-2006 10:23
Victor 884 light. ForgottenSalad Control System 3 01-02-2006 01:25
Blinking Program light on RC jgannon Programming 2 16-02-2005 22:45
Victor 884's not behaving the same as Victor 883's programmer1 Programming 13 10-03-2004 21:51
