Go to Post What has happened has happened. Humans were involved, mistakes made. Clarification will come... - Wetzel [more]
Go Back   Chief Delphi > Technical > CAD > Inventor
Unread 26-03-2007, 01:38
[527]phil's Avatar
[527]phil [527]phil is offline
Alumni
AKA: Phil
FRC #0527 (red dragons)
[527]phil is a glorious beacon of light[527]phil is a glorious beacon of light[527]phil is a glorious beacon of light[527]phil is a glorious beacon of light[527]phil is a glorious beacon of light
Send a message via AIM to [527]phil
Inventor 11 and vista
As many of you know, Windows Vista does not like to play nice with many important applications. Tonight i went to install Autodesk Inventor 11 which i need desperately. And of course, in true windows fashion, it was not compatible. After about 7 failed attempts i finally stumbled upon a thread on the Autodesk forums that helped. I don't know how many people here use Vista, but if you do in the future and need to install inventor try this:
1) Skip using Media Browser. Go directly to the Inventor Setup.exe and set compatibility to XP SP2.
2) Install as Administrator
3) Set Inventor.exe to run in XP SP2 compatibility mode
4) Right click, run as Administrator.
Hopefully Autodesk makes their software compatible, but I just wanted to post this to save people the aggravation.
Whats the difference between mechanical engineers and civil engineers?
Mechanical engineers build weapons, civil engineers build targets
Vista compatibility? EHaskins Programming 29 19-03-2007 11:22
Trouble Loading vista?? BobC Chit-Chat 12 22-02-2007 00:51
Windows Vista ThomasP Chit-Chat 15 01-02-2007 07:16
Windows Vista RC1 Tom Bottiglieri Chit-Chat 7 06-10-2006 13:44
Windows vista!!! [527]phil General Forum 27 25-07-2005 17:01
