Go to Post "The only constant is change" is a hint that probably applies to every season of FIRST. - Chris is me [more]
Unread 26-03-2007, 17:03
yoyodyne yoyodyne is offline
AKA: Greg Smith
FRC #0116 (Epsilon Delta)
yoyodyne is a splendid one to beholdyoyodyne is a splendid one to beholdyoyodyne is a splendid one to beholdyoyodyne is a splendid one to beholdyoyodyne is a splendid one to beholdyoyodyne is a splendid one to beholdyoyodyne is a splendid one to behold
Some 2007 KOP Gyro Performance Data
Some test results to measure the performance of the 2007 KOP gyro are attached. Basically it works well up to about 148 deg/sec but the output is delayed from 100 to 250ms depending on the rate and the duration of the rotation. These measurements were taken because of robot rotation control problems - see
http://www.chiefdelphi.com/forums/sh...ghlight=VICTOR
for more background on the software and analog setup and additional data/results.
Hope this is helpful to others.
Greg
Unread 26-03-2007, 17:18
Joel J's Avatar
Joel J Joel J is offline
do you..
Rookie Year: 2000
Joel J has a reputation beyond reputeJoel J has a reputation beyond reputeJoel J has a reputation beyond reputeJoel J has a reputation beyond reputeJoel J has a reputation beyond reputeJoel J has a reputation beyond reputeJoel J has a reputation beyond reputeJoel J has a reputation beyond reputeJoel J has a reputation beyond reputeJoel J has a reputation beyond reputeJoel J has a reputation beyond repute
Re: Some 2007 KOP Gyro Performance Data
Greg
You know.. I think the impedance on the analog devices's sensors are too high for the PIC's ADC. I've never seen the kit gyro-- does it include an op-amp, or some other means of lowering its output impedance, to allow the ADC to quickly get the gyro reading?
Joel Johnson
Division By Zero (229) Alumni, 2003-2007
RAGE (173) Alumni, 1999-2003
Unread 26-03-2007, 18:13
AKA: Greg Smith
Joel,
There is an op-amp on the module. We did some analysis on the A/D input impedance to try to figure out why a 100K pot we were using looked more log than linear. Turned out that it wasn't a problem charging the A/D 25pf cap it was the pot. IFI did slap a .047uf cap with a 1K series resistor which has a time constant of 47us. Even with a 100K source impedance the time constant is still under 5ms. The A/D data sheet shows about a 40ms delay for the gyro output to come up to full rate. Our 100Hz sample rate adds up to an additional 10ms of delay. If I have some time I'll monitor the response of the analog output on a scope and see if it does have anything to do with driving the RC input pin.
Greg
Unread 02-04-2007, 20:07
Jared Russell's Avatar
Jared Russell Jared Russell is offline
Taking a year (mostly) off
FRC #0254 (The Cheesy Poofs), FRC #0341 (Miss Daisy)
Jared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond repute
Does the KOP gyro have some sort of filter attached? Our Analog Devices 300 deg/sec gyro has very, very little lag.
I Would Like Some Data JamesBrown Scouting 13 15-03-2007 22:31
KOP Gyro seems to run-on after turn stops PhilBot Control System 8 05-03-2007 12:43
KOP Gyro John Gutmann Programming 12 12-12-2005 21:59
Gyro Output Data Venkatesh Technical Discussion 1 03-02-2003 21:34
