Go to Post You mean how many Edible Data Analysis Metrics and Aggregated Measurable Entities (EDAMAME)? - Andrew Schreiber [more]
Unread 27-03-2007, 22:07
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Rookie Year: 1998
REQUEST: Banebots 42mm 256:1 at LoneStar
If anyone coming to the Lonestar regional has a BB 256:1 tranny that they're no longer using, 57 would like to trade for it or otherwise acquire it.
57 has been repairing and strengthening our Banebots transmissions, and in the process, I have made a slight slip-up. The ring gear as purchased is about .055 too long. This results in very poor engagement of the double-D joint. In machining down the ring gear on a transmission, I managed to take off a bit too much, and now the tranny binds slightly if I leave the rear thrust washer in. I can work around this in various ways, but I'd rather start fresh with one more ring gear if anyone has one to spare.
Banebots 42mm gearbox: Recommendations for use Joe Johnson Motors 61 01-04-2007 15:28
Banebots 42mm grease? Kevin Sevcik Motors 2 23-03-2007 19:23
42 mm, 256-1 Banebots Available yet? JB987 General Forum 2 09-02-2007 22:45
BaneBots 42mm Gearbox Pinion Gary Bonner Motors 1 31-01-2007 13:44
Thanks teams 256, 60, 359, 636 archiver 2001 0 24-06-2002 02:46
