I was wondering if anyone knew of a way to hook a fax machine up to a cellphone and use the cell number as the Fax number. This way we could get scouting sheets into the pits in no time flat. i was thinking if maybe there was a way to use the headset jack to transfer the data to the fax machine, but im not sure how id go about doing that.
any ideas? |
Re: Fax Through A Cellphone
FAX??!?!?!??!?!?!
As in, like, paper, and non-editable analog format? ZOMG!! Why don't you just hook up your cell phone to your laptop as a BT-DUN device, and use email. Or if you don't want to use the internet (some people don't feel comfortable doing this due to the FIRST rule), you can BT-DUN to your laptop an using a Fax program an recieve a real *ugh* fax. [/FAXrant] Jacob |
ok i know this has nothing to do with faxing through a cellphone but i've heard that if you forget your car keys for the car and have another pair (with the little remote thing) at home, you can call someone at home with your cellphone to theirs and they can unlock the car with the remote through the cellphone.
Any one know if this is true? |
Jacob |
^ seriously doubt it. unless your cellphone can transmit that certain "message" to make it unlock, in which case you wouldnt need the extra key at home in the first place.
Eventually you'll probably see cell phones which are able to replace your key entirely. |
Nope, doesn't work.
I had a friend locked out of his truck after a concert one night, and had heard about the cell phone trick. We called his house, and after about 20 minutes of calling, his wife finally woke up. We went through all of that trouble to find out that the truck was still in fact locked, the trick didn't work. |
#10
Our team uses cell phones for scouting, something like this: During the matches, team members sit in the stands filling out scouting sheets. They hand the scouting sheets to someone with a laptop for data entry. About the middle of Saturday morning, we stop scouting, the data is tabulated, and we decide which teams would make our best partners. The team captain gets the list. Cell phones are only used to discuss any last-minute changes. The only other equipment we may need would be extra batteries for the laptop. |
#11
The CellDock will work, although at almost $300 for the pair and cables it's not a cheap solution. There are other similar devices on the market, search for "cell" and "pots adapter" (POTS is the acronym for the public switched wired telephone system). They are most commonly used by people that need to hook up a credit card reader at some sort of portable event.
And cell service in the GA Dome and World Congress Center can be questionable... Personally I'd try to work on a solution that used a couple of laptops and cell phones as modems, insead of hardcopy fax. |
#12
BT-DUN.......
Free and easy... set up in minutes! Jacob |
#13
I still can't believe we were able to do it, as I still cannot figure out how it was possible. But regardless of how it was possible, we were able to do it repeatedly with the same results when using cell phones, so there has to be a scientific explanation or phenomenon at work here. (Either that, or we were extremely lucky with our results!) Where's Grant? This sounds like a good case for Mythbusters! ![]() |
#14
For the fax thing... how about an audio link like they used in the 80s where you put your telephone into a microphone/speaker thing hooked up to the computer... maybe you can do the same with your fax machine? granted this only runs about 4800 baud....
-q |
#15
| A journey through FIRST | Ian Curtis | General Forum | 2 | 11-10-2005 09:02 PM |
| Scrolling through strings in a stringgrid | Peter Kiers | Programming | 3 | 03-07-2005 01:28 PM |
| Cellphone Virus | Raven_Writer | Chit-Chat | 10 | 11-30-2004 01:47 PM |
| Power to RC through Tether | zdude255 | Control System | 4 | 02-04-2004 07:40 PM |
| Limboing through Galileo | Kris Verdeyen | Scouting | 7 | 04-08-2003 06:39 PM |
