Go to Post Who doesn't love a good Finger Lakes Regional?! - LeelandS [more]
Unread 27-03-2007, 23:55
Guru's Avatar
Guru Guru is offline
Executive Programmer
FRC #0912 (Iron Lyons)
Guru is an unknown quantity at this point
Exclamation MPLinkTrouble
I've just installed MPLab (7.50) and the C18 Compiler (3.1 Student Edition) onto a new computer. Now, whenever i try to compile, i get these two errors:
Code:
MPLINK 4.1, Linker
Copyright (c) 2006 Microchip Technology Inc.
Error - Coff file format for 'ifi_library.o' is out of date.
Error - Could not build member 'ifi_library.o' in library file 'C:\Documents and Settings\CFS\My Documents\Iron Lyons 2007\Code\Code 2007 1.8\frc_camera_s_21\FRC_alltimers_8722.lib'.
Errors    : 2
Any help would be greatly appreciated.
\/\__Under Construction__/\/
Unread 28-03-2007, 00:09
Bharat Nain's Avatar
Bharat Nain Bharat Nain is offline
Bharat Nain has a reputation beyond reputeBharat Nain has a reputation beyond reputeBharat Nain has a reputation beyond reputeBharat Nain has a reputation beyond reputeBharat Nain has a reputation beyond reputeBharat Nain has a reputation beyond reputeBharat Nain has a reputation beyond reputeBharat Nain has a reputation beyond reputeBharat Nain has a reputation beyond reputeBharat Nain has a reputation beyond reputeBharat Nain has a reputation beyond repute
Send a message via AIM to Bharat Nain Send a message via MSN to Bharat Nain
Re: MPLinkTrouble
You have to use compiler version 2.4(I think). The newer versions are not compatible with IFI's code and maybe the processor. Installing version 2.4 should solve this problem.
-= Bharat Nain =-
Whatever you do, you need courage. Whatever course you decide upon, there is always someone to tell you that you are wrong. There are always difficulties arising that tempt you to believe your critics are right. To map out a course of action and follow it to an end requires some of the same courage that a soldier needs. Peace has its victories, but it takes brave men and women to win them. - Ralph Waldo Emerson
Unread 28-03-2007, 08:51
EHaskins EHaskins is offline
Needs to change his user title.
AKA: Eric Haskins
no team (CARD #6 (SCOE))
EHaskins has a reputation beyond reputeEHaskins has a reputation beyond reputeEHaskins has a reputation beyond reputeEHaskins has a reputation beyond reputeEHaskins has a reputation beyond reputeEHaskins has a reputation beyond reputeEHaskins has a reputation beyond reputeEHaskins has a reputation beyond reputeEHaskins has a reputation beyond reputeEHaskins has a reputation beyond reputeEHaskins has a reputation beyond repute
Send a message via MSN to EHaskins
Re: MPLinkTrouble
IFI's library files are not compatible with v2.4 of C18. the processor IS supported by the compiler v3.1.
Eric Haskins KC9JVH
Unread 28-03-2007, 10:19
Shinigami2057 Shinigami2057 is offline
Slackware Is Your New God (Mentor)
AKA: Harry Bock
FRC #1350 (Rambots)
Shinigami2057 is just really niceShinigami2057 is just really niceShinigami2057 is just really niceShinigami2057 is just really niceShinigami2057 is just really nice
Re: MPLinkTrouble
I never understood why IFI doesn't just recompile their libraries for 3.1... it should take all of 10 seconds.
One of the main causes of the fall of the Roman Empire was that, lacking zero, they had no way to indicate successful termination of their C programs.
Unread 28-03-2007, 10:48
Joe Ross Joe Ross is offline
FRC #0330 (Beachbots)
Rookie Year: 1997
Re: MPLinkTrouble
If all it took was 10 seconds, I'm sure it would have been done by now. Unfortunately, things like that aren't always so easy, especially with embedded processors. See this post: http://www.chiefdelphi.com/forums/sh...99&postcount=8
