Instance relay
ok i got the latch relay working, but now i want an instance. whenever i put in the OI to relay command (in easyc) it goes from neutral to forward. if i put a default as reverse, it goes from reverse to off. is there anyway to program a relay in easy c so that you can go from reverse to forward? thanks in advance!
| Relay Commands | Matt Krass | Programming | 6 | 18-02-2006 23:03 |
| Relay Assignments | MulletFish | Programming | 9 | 27-01-2005 14:15 |
| Relay outputs on rc | jdawson | Electrical | 4 | 26-01-2003 12:51 |
| Relay fault | archiver | 2000 | 2 | 23-06-2002 23:36 |
| Relay Outputs | OddOne | Technical Discussion | 3 | 01-02-2002 19:52 |
