Go to Post Does this mean the end of "Spin Around/Dance" autonomous modes? - Tom Bottiglieri [more]
Unread 29-03-2007, 22:50
Generalx5's Avatar
Generalx5 Generalx5 is offline
Hard Core Inventor
AKA: Jun(John) Zheng
FRC #1346 (Trobotics)
Team Role: Student
Generalx5 will become famous soon enough
Cool pulsing digital out pins, not as fast as pwms
Anyone know a code for pulsing digital out pins? sort of like pwm signals....when the on time is constant but the off time can be adjusted? I am inputing an anolog signal so it controls the length of the off pulses...
Unread 29-03-2007, 22:58
EHaskins EHaskins is offline
Needs to change his user title.
AKA: Eric Haskins
no team (CARD #6 (SCOE))
EHaskins has a reputation beyond reputeEHaskins has a reputation beyond reputeEHaskins has a reputation beyond reputeEHaskins has a reputation beyond reputeEHaskins has a reputation beyond reputeEHaskins has a reputation beyond reputeEHaskins has a reputation beyond reputeEHaskins has a reputation beyond reputeEHaskins has a reputation beyond reputeEHaskins has a reputation beyond reputeEHaskins has a reputation beyond repute
Send a message via MSN to EHaskins
Re: pulsing digital out pins, not as fast as pwms
You may want to look into Kevin Watson's PWM replacement code.
http://www.chiefdelphi.com/forums/sh...ad.php?t=51802
Eric Haskins KC9JVH
Unread 29-03-2007, 23:11
The Lucas's Avatar
The Lucas The Lucas is offline
CaMOElot, it is a silly place
AKA: My First Name is really "The" (or Brian)
FRC #0365 (The Miracle Workerz); FRC#1495 (AGR); FRC#4342 (Demon)
The Lucas has a reputation beyond reputeThe Lucas has a reputation beyond reputeThe Lucas has a reputation beyond reputeThe Lucas has a reputation beyond reputeThe Lucas has a reputation beyond reputeThe Lucas has a reputation beyond reputeThe Lucas has a reputation beyond reputeThe Lucas has a reputation beyond reputeThe Lucas has a reputation beyond reputeThe Lucas has a reputation beyond reputeThe Lucas has a reputation beyond repute
Send a message via AIM to The Lucas
what kind of time scale do you need (ie how long on and off)? There are really 2 methods I can think of:
Timers and interrupts (using this Kevin code as base)
User controlled custom PWMs (using this Kevin code as base)
There is always good code at Kevin's Repository.
Depending on your application one of these options is better. Can you explain your application more precisely?
NOTE: the interrupt code is old (last processor) but still decent for copying the the timers interrupt and initialization code
Electrical & Programming Mentor ---Team #365 "The Miracle Workerz"
Programming Mentor ---Team #4342 "Demon Robotics"
Founding Mentor --- Team #1495 Avon Grove High School
2007 CMP Chairman's Award - Thanks to all MOE members (and others) past and present who made it a reality.
Robot Inspector
"I don't think I'm ever more ''aware'' than I am right after I burn my thumb with a soldering iron"
Unread 01-04-2007, 17:26
Generalx5's Avatar
Hard Core Inventor
Team Role: Student
Those codes are complicated,..need more time to learn that stuff hahaa.
Unread 01-04-2007, 18:45
SgtMillhouse648's Avatar
SgtMillhouse648 SgtMillhouse648 is offline
AKA: Malhon Godwin
FRC #0648 (QC Elite)
SgtMillhouse648 has a spectacular aura aboutSgtMillhouse648 has a spectacular aura about
Send a message via MSN to SgtMillhouse648
i dont know if you could do it on a loop count basis, have it increment a counter each time through the loop, and then once it is within a certain range set a digout equal to one? something like
if(counter < 5)
counter = counter + 1;
rcdigout01 = 0;
elseif(5 <= counter <= 7)
rcdigout01 = 1;
else
counter = 0
rcdigout01 = 0
will this work? I know we did a thing like this when we were working on a delay in our camera search routine to make it pause in between movements
Malhon
Midwest Regional-
Regional Finalists with 1000 and 447
Rockwell Automation Inspiration in Control Award
Regional Woodie Flowers - Ed Wegscheid
Unread 02-04-2007, 18:52
ericand's Avatar
ericand ericand is offline
AKA: Eric Anderson
FRC #3765 (Terrabots)
ericand is a jewel in the roughericand is a jewel in the roughericand is a jewel in the rough
When are you reading the analog signal? How are you reading it?
If you are reading the analog signal using the default get_analog_value()
continuously as you try to pulse the digital I/O pins, you may be getting into trouble due to the delays that the get_analog... puts in while it waits for the A/D conversion. You can eliminate most of the delay by using Kevin's A/D converter which uses the A/D conversion interrupt and a timer to run the conversion continuously in the background.
If you are only checking the analog value once in a while, then using Kevin's A/D code would not be of as much benefit.
PWMs not outputting in Autonomous 937Programmers Programming 15 08-02-2007 21:25
pic: Pins Pins and more pins CD47-Bot Extra Discussion 26 04-09-2005 23:07
Inversion of the digital IO pins ConKbot of Doom Programming 5 25-02-2005 12:41
digital inputs not valid just after initialization? WizardOfAz Programming 2 26-01-2004 13:21
Drill Motors: Pins IN or Pins OUT Caleb Fulton Motors 28 03-02-2003 14:19
