Go to Post If all goes well (cross fingers) we'll have a joystick for driving and one - count it, one - button: FIRE - DonRotolo [more]
Unread 01-04-2007, 19:50
ALIBI's Avatar
ALIBI ALIBI is offline
FRC #0141
Team Role: Parent
ALIBI is a name known to allALIBI is a name known to allALIBI is a name known to allALIBI is a name known to allALIBI is a name known to allALIBI is a name known to all
YMTC: SUPPORT/NOT SUPPORT (ramping)
A robot deploys two ramps that when climbed elevate robots to 13 inches. It is clear that there are no game pieces beneath the robot, ramps or ramp supports. A six wheeled robot climbs on top of the ramp with all six wheels clearly being supported by the ramp. When the power is cut, the arm on the ramped robot settles down on top of a game piece that was in its original position on the floor against the alliance station wall. When the field has come to rest the referees remove the game piece and the arm settles down another inch or so, even after the game piece is removed the the arm remains well above 13 inches. The arm never made contact with the alliance station wall. Should the referees rule that the robot was supported by the game piece or that the robot was not supported by the game piece?
Unread 01-04-2007, 19:54
Don Wright's Avatar
Don Wright Don Wright is offline
FRC #0469
Don Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond repute
Send a message via MSN to Don Wright Send a message via Yahoo to Don Wright
Re: YMTC: SUPPORT/NOT SUPPORT (ramping)
It was supported...no bonus.
Donald F. Wright Jr.
Product Manager
AVL Instrumentation & Test Systems, Inc.
Unread 01-04-2007, 19:56
wingnut1705's Avatar
wingnut1705 wingnut1705 is offline
AKA: Kevin
FRC #0453 (Gears)
wingnut1705 is an unknown quantity at this point
Send a message via AIM to wingnut1705
If the arm settled after the game piece was removed, then it was supported.
No bonus
Unread 01-04-2007, 19:57
EricH's Avatar
EricH EricH is offline
New year, new team
FRC #1197 (Torbots)
Impossible situation. (13" ringers, the arm settles down an inch, and is well above 13 inches) The arm is below 12 inches, and "supported" is not defined in the manual. I see no call for removing the ringer to check, though that is one way. The only thing keeping this robot from being ramped is the arm. I believe the rules apply to anything on the robot--a piece of wire below 12" means the 4" bonus. The arm is supported by the tube (it sags when the tube is removed). No bonus for the ramped robot. If there is a second ramped robot, it would get the points.
Past teams:
2003-2007: FRC0330 BeachBots
2008: FRC1135 Shmoebotics
The Lucas's Avatar
The Lucas The Lucas is offline
CaMOElot, it is a silly place
AKA: My First Name is really "The" (or Brian)
FRC #0365 (The Miracle Workerz); FRC#1495 (AGR); FRC#4342 (Demon)
The Lucas has a reputation beyond reputeThe Lucas has a reputation beyond reputeThe Lucas has a reputation beyond reputeThe Lucas has a reputation beyond reputeThe Lucas has a reputation beyond reputeThe Lucas has a reputation beyond reputeThe Lucas has a reputation beyond reputeThe Lucas has a reputation beyond reputeThe Lucas has a reputation beyond reputeThe Lucas has a reputation beyond reputeThe Lucas has a reputation beyond repute
Send a message via AIM to The Lucas
Probably should add a poll
I would say the ramped robot was defiantly supported by the game piece since its arm moved after piece was removed. No points for that one ramped bot but another bot behind it could score if it is not supported by the first ramped bot (transitive).
Electrical & Programming Mentor ---Team #365 "The Miracle Workerz"
Programming Mentor ---Team #4342 "Demon Robotics"
Founding Mentor --- Team #1495 Avon Grove High School
2007 CMP Chairman's Award - Thanks to all MOE members (and others) past and present who made it a reality.
Robot Inspector
"I don't think I'm ever more ''aware'' than I am right after I burn my thumb with a soldering iron"
Unread 01-04-2007, 20:41
Daniel_LaFleur's Avatar
Daniel_LaFleur Daniel_LaFleur is offline
Mad Scientist
AKA: Me
FRC #2040 (DERT)
Daniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond repute
Send a message via MSN to Daniel_LaFleur
Ramped bot was supported.
No bonus points.
___________________
"We are not now that strength which in old days moved earth and heaven; that which we are, we are;
One equal temper of heroic hearts, Made weak by time and fate, but strong in will
To strive, to seek, to find, and not to yield. "
- Tennyson, Ulysses
Unread 01-04-2007, 21:50
whytheheckme's Avatar
whytheheckme whytheheckme is offline
AKA: Jacob Komar
whytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond repute
Send a message via ICQ to whytheheckme Send a message via AIM to whytheheckme Send a message via MSN to whytheheckme Send a message via Yahoo to whytheheckme
I don't know...
At BAE in NH, we were on a ramp bot. In the end, one of our bumpers wound up touching *touching* the alliance station wall. It was just the corner of the bumper, and it was obvious that this in no way affected the height of the robot. Had we driven a quarter of an inch short, this would not have happened. The ref called 0 points. Not even the 4" bonus. So this is not *supported*, but the rule clearly states that your bot can not be touching a game element... so I say no points.
Jacob
Unread 01-04-2007, 22:08
smurfgirl smurfgirl is offline
Still a New Englander on the inside
AKA: Ellen McIsaac
FRC #5012 (Gryffingear)
smurfgirl has a reputation beyond reputesmurfgirl has a reputation beyond reputesmurfgirl has a reputation beyond reputesmurfgirl has a reputation beyond reputesmurfgirl has a reputation beyond reputesmurfgirl has a reputation beyond reputesmurfgirl has a reputation beyond reputesmurfgirl has a reputation beyond reputesmurfgirl has a reputation beyond reputesmurfgirl has a reputation beyond reputesmurfgirl has a reputation beyond repute
The rules say that a robot cannot be supported by the field or a field object/gamepiece. This is a use of the transitive property to say that a robot supported by a robot supported by a gamepiece violates this aspect of the rules. But take away the tube and use the transitive property the same way: a robot is supported by a robot supported by the carpet, part of the field. This, again, would be a rules violation... but we know that it is not, so for consistency's sake the tube should not be, either. I suppose the refs can remove/deflate the tube to check the height without it, if they need to verify that aspect of it.
The reason why I don't like this call is because it's inconsistent from match to match, from regional to regional. I wouldn't mind so much if FIRST could just standardize this rule and get it in print so the refs and the drivers know how to interpret it and can act accordingly. This way there won't be any surprises or confusion at the end of any given match.
Ellen McIsaac
Team 1124 ÜberBots 2005-2015
Team 5012 Gryffingear 2015+
Unread 01-04-2007, 22:46
LightWaves1636's Avatar
LightWaves1636 LightWaves1636 is offline
is all over it.
AKA: Sarah Le
LightWaves1636 is a splendid one to beholdLightWaves1636 is a splendid one to beholdLightWaves1636 is a splendid one to beholdLightWaves1636 is a splendid one to beholdLightWaves1636 is a splendid one to beholdLightWaves1636 is a splendid one to beholdLightWaves1636 is a splendid one to behold
Send a message via AIM to LightWaves1636 Send a message via Yahoo to LightWaves1636
something like that happened to us. We couldn't believe they wouldn't give us the points. Our arm was down but the extension was still out and we couldn't see it until we went to the side. We ended up tying the match. The extension wasn't supported by the ground or anything, it was below four inches, so they didn't give us the points.
FLL Team - Hackberry Hill Elementary - Arvada, CO ('08 - '10 Coach)
FRC Team 1636 - Reds Robotics - Arvada High School - Arvada, CO ('05 - '07 Alumni)
FRC Team 1583 - Rambotics - Ridgeview Academy - Watkins, CO (Volunteer/Supporter)
FRC Team 2859 - Blasterbots - CSM Robotics Outreach - Golden, CO ('09 - '10 Coach)
FRC Team 3320 - Miracles & Machines - Eastside Memorial High School - Austin, TX ('10 - '12 Mentor)
Unread 01-04-2007, 23:59
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
You're misstating (or misunderstanding) the rules. <G56> says that in order to receive the bonus, a robot must be "...not in contact with any element of the field (carpet, alliance station, goal, etc.), not supported by a GAME PIECE,..." There's no restriction on being supported by the field, only on being supported by a tube.
Unread 02-04-2007, 00:56
Alex Golec Alex Golec is offline
FRC Advocate
no team (FiM Volunteer)
Alex Golec has a reputation beyond reputeAlex Golec has a reputation beyond reputeAlex Golec has a reputation beyond reputeAlex Golec has a reputation beyond reputeAlex Golec has a reputation beyond reputeAlex Golec has a reputation beyond reputeAlex Golec has a reputation beyond reputeAlex Golec has a reputation beyond reputeAlex Golec has a reputation beyond reputeAlex Golec has a reputation beyond reputeAlex Golec has a reputation beyond repute
To keep the calls consistent with what I have seen at three regionals this year (though they were all Michigan regionals) - there is no bonus. The robot's arm is supported by the tube at the end of the match, and by <G56>, there is no bonus for that robot.
I know it may seem asinine, but that is how it is written and how it has been enforced.
If that were my team, I would learn to get the arm out of the way and tucked back within the robot before the end of the match.
[end of two cent write-up]
_Alex
Unread 02-04-2007, 07:36
mtaman02's Avatar
mtaman02 mtaman02 is offline
FIRST's Spare, Queuer &amp; Tech guy =)
AKA: Mike M. / Mouse =)
no team (FRC Volunteer)
mtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant future
Send a message via AIM to mtaman02 Send a message via Yahoo to mtaman02
0 Points awarded, The robot is considered to be supported by the game element. I personally don't like that rule but eh what can you do. =(
Past FIRST Robotics Events that I proudly volunteered at:
FLL: NY State Competition '03
FRC: NYC Remote Kickoff '04 & NYC Regionals '04-'15 ,'10-'13 & NJ Regionals '06-'10, Finger Lakes Regional '09 & SBPLI Regional '08-'15 and the World Championship in '05 (Galileo Field) '07 (Newton Field) '09 (Practice Fields Attendant / FTA(A)), CeBIT Convention in '04 & NextFEST in '06 both held @ the Javitts Center, Monty Madness '07-'10, Panda-monium '08, B.Eruption '08 & '09, Ramp Riot '08, PARC '09 & '10, BR^2 '09 & Wol. Inv. '09 -'15
2015 FIRST Robotics Off Season Events that I hope to volunteer at:
Where is Wolcott Invitational
2015 FIRST Robotics Events that I will be volunteering at:
SBPLI Reg. & Championships
Volunteer Resume:
Alt & Lead Team Queuer, Field Repair/Reset, Field Setup/Breakdown, Spare Parts Attendant, Field Power Controller/Score Keeper, Co-Emcee & Official Scorer, Control System Advisor, FIRST Tech Advisor Assistant & recently Practice Field Attendant.
School support dziurdar General Forum 6 21-03-2005 09:53
school support narenr Chit-Chat 14 14-04-2003 16:53
support group Allie Chit-Chat 5 01-05-2002 19:02
support Tyler Olds 3D Animation and Competition 2 07-02-2002 16:32
