Go to Post Maybe LabView needs to have a watchdog for goofy programmers... - johncap100 [more]
View Poll Results: FP transmission adapter interface option
KOP Lead Screw Nut 2 18.18%
1 inch hex shaft 1 9.09%
0.625 inch round shaft /w keyway 1 9.09%
0.500 inch round shaft /w keyway 7 63.64%
Other (Please describe in a post to this thread) 2 18.18%
Multiple Choice Poll. Voters: 11. You may not vote on this poll
Unread 04-02-2007, 06:08 PM
Andrew Schuetze's Avatar
Andrew Schuetze Andrew Schuetze is offline
499 Founder / Alamo FTC & FLL AP
Team Role: Leadership
Andrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond repute
Question FP transmission adapter
How many teams would use the FP motor plus transmission if they had an COTS item that they could order that would interface with the FP transmission hub?
One of our mentors, worked up a solid model to interface with this transmission that accepted the '07 KOP triangular lead screw nut. We first attempted to mill it out of aluminum round stock but that was going to too complicated for our new mill and novice user status.
We then just printed the model out of ABS plastic using a Dimension 3D printer. In just 3 hours we had the first prototype and a day later a refined part that fit snug. If ABS plastic is not up to the material strength requirements then I am thinking that the plastic model could be used to make an injection mold. The Dimension representative did tell me that they have a new model that prints a higher strength plastic.
If we were to go forward with this as a project then we would need to know what the market demands for common interaces with the transmission. So take the poll
APS
Founder FRC 499
Parent alumni FRC 2745 & 4219
Co-Coach FTC 4549 & 6407
Alamo FTC Affiliate Partner
Alamo FLL Affiliate Partner
Unread 04-02-2007, 07:31 PM
Billfred's Avatar
Billfred Billfred is offline
Re: FP transmission adapter
I actually kicked around this very notion a few weeks ago. The FP gearboxes never seemed particularly easy to interface with, at least without scrounging around obscure websites for the right adapter for it. If you can get it to interface a half-inch keyed shaft, like the window motors (as I recall) in the kit of parts, it'd be awesome.
Perhaps as a bonus, some holes could be made for mounting directly to the output adapter?
Unread 04-02-2007, 07:36 PM
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Team Role: Teacher
I think it's a good idea, but am I the only one that takes issue with this notion that seems to be going around that the FRC KOP ought to fit perfectly together right from the box? I mean, back in "the good ol' days" FIRST seemed harder than it is now, and I feel like I learned more as a student back then than students are learning now.
Unread 04-02-2007, 08:05 PM
EricH's Avatar
EricH EricH is offline
New year, new team
FRC #1197 (Torbots)
The inside of the output gear on the FP transmission is an octagon. We just made some octagons of the appropriate size, put a hole for the shaft in, and added a keyway. (We also put hose clamps around the outside of the output to make sure it stays together.) Makes it really easy to put two of them together. Also can be adapted to any size of shaft that fits through the hole at that end of the gearbox.
This use can be seen here. Look at the base area of the mast and take a close look at the FP. The metal is an octogon with a shaft collar on this side of it.
Past teams:
2003-2007: FRC0330 BeachBots
2008: FRC1135 Shmoebotics
Unread 04-02-2007, 08:11 PM
Jared Russell's Avatar
Jared Russell Jared Russell is online now
Taking a year (mostly) off
FRC #0254 (The Cheesy Poofs), FRC #0341 (Miss Daisy)
Jared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond repute
I would LOVE it. It's a nice, light gearbox that gets the speed down to a reasonable rate, but it's IMPOSSIBLE (at least it seems that way to me - the programming guy) to mount to a lot of things on our robots. We've used the AM Planetary a lot the past few years, but that only gets it down to CIM speed.
We use 1/2" shaft on most of our machines, and that's what we have most of our spare parts in.
Unread 04-02-2007, 08:20 PM
Bill_Hancoc's Avatar
Bill_Hancoc Bill_Hancoc is offline
Volkswagen Enthusiast
AKA: Bill Hancock
FRC #0573 (MechWarriors)
Team Role: Mechanical
Bill_Hancoc has much to be proud ofBill_Hancoc has much to be proud ofBill_Hancoc has much to be proud ofBill_Hancoc has much to be proud ofBill_Hancoc has much to be proud ofBill_Hancoc has much to be proud ofBill_Hancoc has much to be proud ofBill_Hancoc has much to be proud ofBill_Hancoc has much to be proud of
Send a message via AIM to Bill_Hancoc
The ABS plastic could be used to make a aluminum casting. PM me for more info
MechWarriors 573
Unread 04-02-2007, 11:03 PM
jskene jskene is offline
None #0612
jskene is a splendid one to beholdjskene is a splendid one to beholdjskene is a splendid one to beholdjskene is a splendid one to beholdjskene is a splendid one to beholdjskene is a splendid one to beholdjskene is a splendid one to behold
We make a plastic, octagonal insert (see below) every year with a CNC mill. I'd be happy to post the G code if anyone wants it.
This year the insert is used as a winch drum.
Jerry Skene, mentor OOO OOO 2010 - Chairman's Award- DC OOOOOOOOOOOOOOOOOOOOOOOOOOO
Chantilly Academy, Team 612 - 2009 - Engineering Inspiration Award; Finalist - New Jersey
-----------------------------------2008 - Chairman's Award; Kleiner Perkins Award -Buckeye ---| ---Team Spirit Award - NASA/VCU
-----------------------------------2007 - Chairman's Award - NASA/VCU ---| ---Finalist; Kleiner Perkins Award - Chesapeake
-----------------------------------2006 - Chairman's Award - Chesapeake ---| --- Engineering Inspiration Award - NASA/VCU --
Unread 04-03-2007, 03:19 AM
ChrisH's Avatar Unsung FIRST Hero
ChrisH ChrisH is offline
Generally Useless
FRC #0330 (Beach 'Bots)
Rookie Year: 1998
ChrisH has a reputation beyond reputeChrisH has a reputation beyond reputeChrisH has a reputation beyond reputeChrisH has a reputation beyond reputeChrisH has a reputation beyond reputeChrisH has a reputation beyond reputeChrisH has a reputation beyond reputeChrisH has a reputation beyond reputeChrisH has a reputation beyond reputeChrisH has a reputation beyond reputeChrisH has a reputation beyond repute
In the interest of full disclosure, I believe we "borrowed" this idea from Team 60, hose clamp and all.
Christopher H Husmann, PE
"Who is John Galt?"
USB Joystick Adapter FRC1710 Control System 3 01-15-2007 05:06 PM
USB-Serial adapter Bill_Hancoc Chit-Chat 4 01-03-2006 07:18 AM
DB9 Adapter Vienny Nguyen Robotics Education and Curriculum 7 12-22-2003 04:08 PM
Adapter great_one411 General Forum 2 02-02-2003 12:39 PM
A/C adapter for OI Bill Gold Technical Discussion 5 10-23-2001 11:51 PM
