Did anybody have an inspection where you barely passed?
Our robot was 119lbs and fit the square space perfectly. |
Re: Close Inspection
At first we barely DIDN'T pass. We weighed 120.8 lbs. and were 1/16th of an inch to tall. Didn't take much to fix though and ended up short enough and 119.3 lbs.
BTW does anyone know why lbs. is an abbreviation for pounds? |
At Philly, we were around a pound over the limit, so we cut off a few inches of the middle support of our ramp (taking away 30% of its support, but it still worked out), and landed exactly at 120 lbs.
Interesting question... Quote:
We design to be 1" shy on all dimensions and it is amazing how things always seem to grow during build season and we end up being close to max size.
This year we had zero problems with dimension or weight for the first time ever. Having a weight budget spreadsheet is a must! |
Weight budget: with us everything goes on it individually, and we use it for our BOM. Hey, it works, and it needs less work. |
I remember last year (06) our robot was weighing in at a tenth of a pound or so overweight. We let the air out of the pneumatics and it put us *just* under 120
And here's a question to which I don't really want to know the answer: do you need to weigh the robot with or without its compressed air? *This assumes an air temperature of 21°C; in reality, the air is probably hotter than this due to being mechanically compressed. And that lowers the density even more. Last edited by Tristan Lall : 05-04-2007 at 12:04. |
We have to have our tanks filled because we use the air to back fill our cylinders to keep the gas struts compressed We also always build 1" short of the width and length dimensions. We have never been too big but we have removed plexiglas from the box due to bolt heads ![]() |
Ours was painless--102ish pounds, in by a good half-inch all around. I don't know of anyone who had size or weight problems at Palmetto, though I did inspect size issues at UCF and Chesapeake. (Some Palmetto teams did get burned on other issues, like not having the Rockwell block.)
#10
In Spanish libra means pound, originating from Latin as mentioned before.
#11
One hint for everyone who builds a robot that fits "perfectly": build it one inch smaller in all directions next time. Ask yourself how much of an advantage you gain by keeping that inch, and consider what happens if your frame gets twisted, or you want to add something, or the inspection box is undersized (and nobody notices). Also remember that you can't be pushing on the walls of the bounding box (or the virtual walls, in the case of this year's sizing box); you must fit inside unconstrained.
There are probably cases where you need to build your robot almost exactly to the maximum size, but realistically, most maximum-sized robots aren't examples of this. Also, as we're on the topic, remember to keep track of weight. There was one team at GTR which arrived something like 37 pounds overweight (due to their own malfunctioning scale). Don't let that happen to you! Quote:
| Inspection | willross | General Forum | 4 | 25-02-2004 18:28 |
| Streamlining Inspection | sevisehda | General Forum | 7 | 09-09-2003 22:53 |
| Inspection Sheet | Mike Norton | Rules/Strategy | 3 | 12-02-2003 15:55 |
| So close, but not close enough | archiver | 2001 | 1 | 23-06-2002 23:45 |
| Inspection | Mike Martus | OCCRA | 0 | 29-10-2001 21:45 |
