Programming 2004 RC
What do I need in order to program the 2004 Robot Controller and where do I get it?
Thanks. |
Re: Programming 2004 RC
You can use the same compiler as the 2006/2007 RC. You can get the 2004 default code from here: http://www.ifirobotics.com/first-legacy.shtml or you can use this year's default code by following the instructions in Using_a_2005_FRC.txt included in the default code.
Thanks for the help, but are you sure? I found this on the bottom of this page: http://ifirobotics.com/rc.shtml
Add 2007 to that list. They all can use the same v2.40 compiler, but nothing newer.
ya man, the MPLAB that was goven out this year (i forget which version) will work fine. i'm practicing my programming on a 2005 RC and OI, and it's all the same as the newer stuff. just make sure you follow the instructions from that .txt file mentioned above...i really got burned for not following them.
if you want to compile for the 05 RC, make sure you select the 8520 from Configure->Select Device and use the 8520 lib and linker files
| Programming Analog Input from 2004 Controller | Danny Diaz | Programming | 8 | 30-01-2007 22:44 |
| programming motors with programming kit | BorisTheBlade | FIRST Tech Challenge | 4 | 01-11-2005 19:03 |
| Mechanical Desktop 2004 DX/AutoCAD 2004 and AutoCAD 2005 | coastertux | Inventor | 4 | 14-06-2005 09:27 |
| White Paper Discuss: Official 2004 Introduction to Programming Guide | CD47-Bot | Extra Discussion | 4 | 26-01-2004 20:59 |
| 2004 Programming Quick Reference | Jeremy_Mc | Programming | 5 | 22-10-2003 17:01 |
