Go to Post If you don't KNOW something as fact, please do not state it as fact. - dlavery [more]
Go Back   Chief Delphi > Technical > Kit & Additional Hardware
Unread 08-04-2007, 21:22
The GarbageMan's Avatar
The GarbageMan The GarbageMan is offline
FRC #0545
The GarbageMan will become famous soon enough
Help with Omni-wheels
My team has a turning problem and we are looking for a quick fix that we can do before the championship rounds begin. We have four wheel drive, one kit CIM and transmission per side, a very wide wheel base (all most as wide as the frame which is the max 46"); we are using four of the kit of parts wheels. We have geared the motors down considerable so that the robot moves at the same speed as a quick walk at full speed. We have decided that replacing two wheels with Omni wheels will be the easiest way to go so we ordered two 6" Omni-wheels rush delivery.
What I am wondering is if I can replace the two wheels that are in opposite corners. This way we will rotate around the center of mass and if we get hit from the side we won't slide as much as two Omni wheels on the front or back.
If anyone has tried to do this or knows if it will solve my turning problem I would love to know.
Thanks
You reap what you sow.
And look we have a working arm
It is the simplest arm you will ever see, but it works
can bots with omni wheels capable of going up robots? Tri_Lam Technical Discussion 12 13-01-2007 16:15
Friction coefficients for Omni wheels and Mecanum wheels from AndyMark Andy Baker Technical Discussion 11 16-12-2006 19:40
Motors with Omni-Wheels jlewellen Motors 5 11-01-2006 23:24
Omni Wheels edomus General Forum 6 06-02-2004 13:35
Omni Wheels! jrgrim12 Technical Discussion 5 04-02-2003 16:07
