pic: 25 Base Bot Climbs 1089
Re: pic: 25 Base Bot Climbs 1089
Intersting wheels on 1089... what are they?
Also, can we get more pics of 25's practice base? |
You want more pictures of their practice base? Go take photos of their robot...
It's the same base (obviously rebuilt in the spirit of the FIRST competition). And we use 7" lawnmower wheels from Home Depot on each side (I think). We filed down the tread that came with them and glued & fastened on our own strip of tread. I'm not sure of the details, but come check it out in the pits! Someone there will be able to explain it better! |
We used 4 wheels last year on each side (2 groups of two) with the tread that came with them. They did work wonderfully!
Are those AndyMark two speeds? If so, I have a hard time believing that's all the reduction you need for those large wheels. Does it turn in high gear? What is the diameter of the wheels and how many teeth do the sprockets have?
EDIT: I guess I mistook the wheels as being larger. Now that I think about it, that does seem right. Nice work, and good luck! Last edited by sanddrag : 09-04-2007 at 15:55. |
Yes, they are Andy Mark 2-speeds servo shifter gear boxes.
The wheels are 7 inch in diameter after our modifications to them. Yes, it turns in high gear. I do not recall what the gear ratio on the chain and sprocket to the wheels is, but it is less than 3:1. I remember the discussion about the ratio, but I don't remember the final number. |
Is 1089's chassis made from 80/20 Quickframe or similar? If so, how has that held up? I've been looking at it for 2008, but I've been a little unsure of its durability if subjected to multiple competitions. (Wierd, this is my 1089th post)
We haven't had any major dents in it this year. The addition of the bumpers has significantly reduced the impact of other robots smashing into us. Comparatively, we used a frame almost identical to this in 2003 (Quicksilver), and that one got bent and bruised a LOT more.
#10
The wheels are 6 or 7 inch plastic lawnmower wheels found in Home Depot.
We machined off the plastic lawnmower tire tread and placed on it raised/ridged conveyor belting, which is glued with a silicone based adhesive(don't quote me on that, but they are indeed glued) and screwed to the wheels so they will not slip or slide. They are for certain now 7inch wheels. This provides excellent traction, and greatly increased resistance and friction when in a pushing shoving match. Last edited by Phalanx : 09-04-2007 at 15:38. |
#12
Adam- visit our pits in Galileo- we have 1/2 of that practice base sitting on a table for all to look at
WC |
#13
... I will definitely stop by, I have been a fan of the evil machines since I joined FIRST. |
#14
there is no need to sell it. The plans are in the new book- for the most part. With a little luck we will be helping a lot of teams make them over the coming summer......... WC ![]() |
#15
heh...we took a page out of your books and tried the 6 wheel drive again...i dont think we used any of the plans, we just tried our own 6 wheel after seeing and running with you guys for the past few years....after winning NJ last year, we realized that those caster had to go! with that said, i know 25 has been a big help to other teams and their drivetrains, but 103 is also available for questions...check us out in galileo! |
| How & where do you build the bot when it snows and your robo-base (school) is closed? | Elgin Clock | General Forum | 28 | 03-03-2008 00:12 |
| pic: 1089 and 237 Battle It Out | BandChick | Extra Discussion | 4 | 22-05-2006 23:29 |
| pic: Team 1089 | BandChick | Extra Discussion | 3 | 03-05-2005 01:36 |
| pic: Rachel climbs a tree... 1018 | Bob Steele | Robot Showcase | 8 | 23-02-2005 09:51 |
| Segway climbs a mountain | Katie Reynolds | Dean Kamen's Inventions | 1 | 28-08-2003 13:41 |
