Go to Post There should be no teams yelling "robot". - RoboMom [more]
Unread 18-04-2007, 13:39
Molten's Avatar
Molten Molten is offline
AKA: Jason
FRC #1766 (Temper Metal)
Molten has a reputation beyond reputeMolten has a reputation beyond reputeMolten has a reputation beyond reputeMolten has a reputation beyond reputeMolten has a reputation beyond reputeMolten has a reputation beyond reputeMolten has a reputation beyond reputeMolten has a reputation beyond reputeMolten has a reputation beyond reputeMolten has a reputation beyond reputeMolten has a reputation beyond repute
Chain Strength Formula
I have a chain and need to know how strong it is. I just don't know how to check without loading 100+pounds onto it. For those with a machinary handbook the W is .735 in., the L is .668 in., The P is1.322 in.
I do not know wwhere to begin with this problem. I tried several handbooks and none of them had the right size. Anyone that knows anything of help please let me know. I can use the formula myself if you just don't have time to solve it. I am hoping that the FIRST community can help me as this is a big project for me.
"Curiosity. Not good for cats, great for scientists."- Numb3rs
"They can break your cookie, but... you'll always have your fortune."-T.W. Turtle, Cats Don't Dance
"Tell my tale to those who ask. Tell it truly - the ill deeds along with the good, and let me be judged accordingly. The rest... is silence."-Dinobot, Beast Wars
"Though the first step is the hardest and the last step ends the quest, the long steps in between are certainly the best."
–Gruffi Gummi, Disney's Adventures of the Gummi Bears
Unread 18-04-2007, 13:43
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Team Role: Teacher
Re: Chain Strength Formula
Is it ANSI roller chain, like, #35 or something like that? If so, you can use the specs on the McMaster catalog page for that chain for a rough estimate of maximum working load and breaking strength.
Unread 18-04-2007, 13:46
Molten's Avatar
AKA: Jason
How would I know if it was ANSI or what Number it is?
Unread 18-04-2007, 14:32
John Gutmann John Gutmann is offline
I'm right here
AKA: sparksandtabs
FRC #0340 (GRR)
Team Role: Mechanical
John Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant future
Send a message via AIM to John Gutmann Send a message via MSN to John Gutmann Send a message via Yahoo to John Gutmann
You can measure the pitch of the chain then look on McMaster, or any other chain provider.
-John
Unread 18-04-2007, 14:39
dlavery's Avatar
dlavery dlavery is offline
Curmudgeon
FRC #0116 (Epsilon Delta)
Rookie Year: 1996
dlavery has a reputation beyond reputedlavery has a reputation beyond reputedlavery has a reputation beyond reputedlavery has a reputation beyond reputedlavery has a reputation beyond reputedlavery has a reputation beyond reputedlavery has a reputation beyond reputedlavery has a reputation beyond reputedlavery has a reputation beyond reputedlavery has a reputation beyond reputedlavery has a reputation beyond repute
You are going to have to provide a little more information. Just the size of the chain is insufficient - what material is it made from (plastic? aluminum? steel? and what alloy?) and what is the condition of the chain (pristine fresh-from-the-manufacturer, or covered with corrosion after being buried under a tractor for 10 years)? Is it single- or double-course (or triple-course)? Are the side plates on each link pressed into place, or welded? Has the chain been significantly stressed before? Etc.
All of these factors, and many others, will contribute to the overall strength rating of the chain. If this is just a length of chain that you had on hand, and you don't know the history of it's use (or abuse), then it may be impossible to accurately predict the actual strength of the chain. The only reliable way to determine it will be to use a short length of the chain and conduct a destructive loading test to see when the chain actually fails.
-dave
"I know what you're thinking, punk," hissed Wordy Harry to his new editor, "you're thinking, 'Did he use six superfluous adjectives or only five?' - and to tell the truth, I forgot myself in all this excitement; but being as this is English, the most powerful language in the world, whose subtle nuances will blow your head clean off, you've got to ask yourself one question: 'Do I feel loquacious?' - well do you, punk?"
- Stuart Vasepuru, 2006 Bulwer-Lytton Fiction Contest
My OTHER CAR is still on Mars!!!
Unread 18-04-2007, 15:01
kramarczyk's Avatar
kramarczyk kramarczyk is offline
is getting his kicks.
AKA: Mark Kramarczyk
FRC #3096 (Highlanders)
kramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond repute
Based upon your description, assuming it is actually a standard ANSI roller chain, it sounds like a #100 (1.25" pitch, .75" wide, link plates thickness of .156"). That's a bit beefy for a bot. If this assumption is true then the following exerpt from the Machinery Handbook (26th Ed, p2424) applies:
Minimum Ultimate Tensile Strength: For single-strand chain, equal to or greater than 12,500 × (pitch in inches)2 pounds. The minimum tensile strength or breaking strength of a multiple-strand chain is equal to that of a single-strand chain multiplied by the number of strands. Minimum ultimate tensile strength is indicative only of the tensile strength quality of the chain, not the maximum load that can be applied.
Soooooo..... 19.5 kip per strand
yowza
'course Dave's test is the only way to know for sure.
Mark
Mark
Brick walls are for other people. - Randy Pausch
Need Help: Formula Needed Wilson Motors 21 30-12-2005 18:09
Help: a good, free formula writing software. suneel112 IT / Communications 4 13-08-2004 21:06
PSI formula for pneumatic pistons Ryan Pneumatics 10 13-01-2004 12:56
Chain and chain breaker source? kmcclary Off-Season Events 4 22-10-2001 22:51
