Go to Post FIRST doesn't end after high school, for some of us, it is only beginning. - David Kelly [more]
Unread 20-04-2007, 17:44
Alpha 997 Alpha 997 is offline
AKA: Yi Li
FRC #0997 (Spartans)
Team Role: Operator
Alpha 997 will become famous soon enough
Need help from turret experts
I'm also woking on researching and designing a big turret. Any thoughts, advise, examples or tips? I know that 25 has a really really nice one.
Ohhh... The EXIT sign is green so that robots can get out during a fire.
2007-Archimedes semi-finalist
2007-Davis Sacramento Regional champion
2007-Pacific Northwest Regional champion
2005-Archimedes semi-finalist
2005-Archimedes second seed
Unread 20-04-2007, 17:55
114Klutz 114Klutz is offline
AKA: Li Pi
FRC #2984 (Viking Robotics)
114Klutz is a jewel in the rough114Klutz is a jewel in the rough114Klutz is a jewel in the rough
Send a message via AIM to 114Klutz
Re: Need help from turret experts
114 has our old one from 2006 - It's rather well designed and very accurate - albeit perhaps on the heavy side.
Talk to a Rex114 about it.
Unread 20-04-2007, 18:07
lukevanoort lukevanoort is offline
in between teams
AKA: Luke Van Oort
lukevanoort has a reputation beyond reputelukevanoort has a reputation beyond reputelukevanoort has a reputation beyond reputelukevanoort has a reputation beyond reputelukevanoort has a reputation beyond reputelukevanoort has a reputation beyond reputelukevanoort has a reputation beyond reputelukevanoort has a reputation beyond reputelukevanoort has a reputation beyond reputelukevanoort has a reputation beyond reputelukevanoort has a reputation beyond repute
Send a message via AIM to lukevanoort
Check out this post by Wayne Cokeley about 25's turret design. In addition, depending on your application (ie, how much of an unbalanced load it has to hold, and how far out) large diameter lazy susan bearings from your local hardware store may work fine.
Team 1219: 2009 - Mentor
Team 587: 2005 - Animator, 2006-2008 - Team Captain
Unread 20-04-2007, 18:28
DonRotolo's Avatar
Back to humble
FRC #0832
Going in the opposite direction, radio amateurs often use novel mechanisms to rotate large or larger antenna arrays. A goodle search on "moonbounce" or "large antenna array rotator" should turn up some good info.
Some have even used army surplus tank turrets for that purpose.
Like Luke said, it depends on the load and unbalance you need to deal with.
Don
Unread 20-04-2007, 18:42
Qbranch Qbranch is offline
wow college goes fast.
AKA: Alex
FRC #1024 (Kil-A-Bytes)
Qbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond repute
Check out out 2006 AimHigh shooter... had a suspended shooter turret, great double-bearing system, was very light (less than 5lbs, can't remember exactly, know the whole superstructure of the robot weighed 15lbs), accuracy of +/-0.5deg.
If you want more info let me know.
-q
Electrical Engineer Illini
1024 | Programmer '06, '07, '08 | Driver '08
Unread 20-04-2007, 18:53
Rich Ross Rich Ross is offline
Let's get Desperate!!!
AKA: 830 Alumni
FRC #1504 (The Desperate Penguins)
Rich Ross has a reputation beyond reputeRich Ross has a reputation beyond reputeRich Ross has a reputation beyond reputeRich Ross has a reputation beyond reputeRich Ross has a reputation beyond reputeRich Ross has a reputation beyond reputeRich Ross has a reputation beyond reputeRich Ross has a reputation beyond reputeRich Ross has a reputation beyond reputeRich Ross has a reputation beyond reputeRich Ross has a reputation beyond repute
Send a message via AIM to Rich Ross
also, try talking to the martians. They've been building turreted arms for quite some time now.
1504, finalists WMR and judges award GLR
Let's get Desperate.
Unread 20-04-2007, 19:20
Ben Martin's Avatar
Ben Martin Ben Martin is offline
Long Distance Mentor
FRC #0225 (TechFire)
Ben Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond repute
Make sure your gears are strong, especially if your turret is going to take a lot of abuse. At one regional, we stripped off eight teeth on a fourteen tooth gear.
Titanium?
Unread 20-04-2007, 19:31
Joe Ross Joe Ross is offline
FRC #0330 (Beachbots)
Rookie Year: 1997
You can read about a lot of great turret designs in FIRST Robots: Behind the Design. Not only are the descriptions more in depth then you would normally find in a chiefdelphi discussion, there are a lot of great pictures as well.
Unread 20-04-2007, 21:10
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Team Role: Teacher
696 did a nice one in 06. Won them the Innovation in Control Award. Here's a pic. http://www.chiefdelphi.com/media/photos/23631. It was comprised of 4 rings. Inner and outer, and then an upper and lower of each. Each ring had a 45 degree chamfer milled around it. When placed together, inner, outer, upper, and lower, these chamfers would form a diamond shape. In this groove rode alternating steel and delrin balls. This groove gave us 4 points of contact on the balls, so that the turret could be loaded in any direction (axial, radial) and still rotate buttery smooth. It's large diameter made it quite stable.
Unread 21-04-2007, 02:41
Jeremiah Johnson's Avatar
Jeremiah Johnson Jeremiah Johnson is offline
Go VOLS!!
AKA: Budda648
no team (QC Elite)
Jeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond repute
Send a message via AIM to Jeremiah Johnson Send a message via MSN to Jeremiah Johnson
Especially check out 111's turret design. I've read that write up at least 4 times and my mouth keeps watering.
Do The Tyler!
XBOX Live Gamertag = theVelvetLie
Unread 21-04-2007, 02:51
pstrapp's Avatar
pstrapp pstrapp is offline
FRC #2016 (MuMuPsi)
Rookie Year: 2000
pstrapp will become famous soon enoughpstrapp will become famous soon enough
I would suggest checking out 75's Turret
http://www.roboraiders.com/showcase/...turret_idw.PNG
http://www.roboraiders.com/showcase/?page=assy&type=sub
Unread 24-04-2007, 18:09
AKA: Yi Li
Team Role: Operator
Originally Posted by pstrapp View Post
Wow that's insanely complicated.
Unread 25-04-2007, 23:15
Scott Morgan Scott Morgan is offline
None #1138
Scott Morgan has a spectacular aura aboutScott Morgan has a spectacular aura aboutScott Morgan has a spectacular aura about
probably my favorite robot this year
But for turrets I'm interested in Bishop-Wiscarver's rotary systems, I was impressed by their display at nationals
Unread 21-04-2007, 03:04
Bharat Nain's Avatar
Bharat Nain Bharat Nain is offline
Bharat Nain has a reputation beyond reputeBharat Nain has a reputation beyond reputeBharat Nain has a reputation beyond reputeBharat Nain has a reputation beyond reputeBharat Nain has a reputation beyond reputeBharat Nain has a reputation beyond reputeBharat Nain has a reputation beyond reputeBharat Nain has a reputation beyond reputeBharat Nain has a reputation beyond reputeBharat Nain has a reputation beyond reputeBharat Nain has a reputation beyond repute
Send a message via AIM to Bharat Nain Send a message via MSN to Bharat Nain
Titanium?
Yes, they do take a lot of abuse so make sure they are well-supported/mounted. Our 2006 turret took a lot of abuse and finally snapped at Monty Madness final match. It did not work for a couple matches at IRI also because it had been beaten down so much. The 2004 turret which used a chain was a bit stronger. I'll see if I can dig up a few pictures and post them.
-= Bharat Nain =-
Whatever you do, you need courage. Whatever course you decide upon, there is always someone to tell you that you are wrong. There are always difficulties arising that tempt you to believe your critics are right. To map out a course of action and follow it to an end requires some of the same courage that a soldier needs. Peace has its victories, but it takes brave men and women to win them. - Ralph Waldo Emerson
Need Help Making Part from Spec Goaliexam Inventor 10 26-07-2006 11:34
need a general opinion from all you experts... archiver 2001 3 23-06-2002 23:09
Need Help, from Mentors for Research Steve Shade General Forum 1 25-02-2002 15:49
I need Help from you all. nick reynolds Chit-Chat 18 02-11-2001 23:39
