Go to Post I didn't feel like reading this whole thread, which, as I understand, is talking about people not wanting to read long threads. - Mike [more]
Unread 19-05-2007, 17:51
PhilBot's Avatar
PhilBot PhilBot is offline
Get a life? This IS my life!
AKA: Phil Malone
FRC #1629 (GaCo: The Garrett Coalition)
PhilBot has a reputation beyond reputePhilBot has a reputation beyond reputePhilBot has a reputation beyond reputePhilBot has a reputation beyond reputePhilBot has a reputation beyond reputePhilBot has a reputation beyond reputePhilBot has a reputation beyond reputePhilBot has a reputation beyond reputePhilBot has a reputation beyond reputePhilBot has a reputation beyond reputePhilBot has a reputation beyond repute
Team 1629 goes to the far side of the rack at PARCX
The clip below shows the auto mode that we never got to try at regionals.
In this match, 5 of the 6 robots had an autonomous mode. In this clip "Sticky" the Garrett Coalition (1629) bot makes a highspeed run to the far end of the field, sideswiping a blocking robot and then turns back to the rack and rings a keeper on the middle level.
A gyro is used to hold the heading in the straight run and initial turn, then the camera is used to get a range and bearing on the target.
YouTube here:
http://www.youtube.com/watch?v=D2kuUp9Rvw8
The hi-res clip is here:
http://www.gearsinc.org/images/1629_full_auto.wmv
The raw video is here:
http://www.gearsinc.org/images/1629_raw_fullauto.wmv
Phil.
Phil Malone
Garrett Engineering And Robotics Society (GEARS) founder.
http://www.GEARSinc.org
FRC1629 Mentor, FTC2818 Coach, FTC4240 Mentor, FLL NeXTGEN Mentor
Unread 03-05-2007, 15:31
Doug Leppard's Avatar
Doug Leppard Doug Leppard is offline
FRC #1902 (Exploding Bacon)
Doug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond repute
Send a message via AIM to Doug Leppard
Re: Post URL to your autonomous mode
Originally Posted by The Lucas View Post
Team 365
Curie Q56 http://www.thebluealliance.net/tbatv...7/cur_qm56.wmv
This match is my favorite because 716 shakes the rack with its dead reckoning auto attempt but MOEzilla hits it anyway on a slightly offset spider. Also, with 4 teams attempting keepers there is a lot of movement.
We use the camera, gyro, wheel encoders and occasionally sonar and IR sensors. If I get some time I will writeup something about the decision making and step based nature of the code. Also I will try to lookup our stats later but I wanted to get a video to you in time.
Got it. That was good. It will be used. You don't have to send more info at this point.
Doug Leppard
Autonomous mode HellBoy Programming 4 07-02-2007 18:22
autonomous mode seanl Programming 6 31-01-2007 15:59
Is there a way to read your Team Colour during autonomous mode? Firestorm Programming 2 19-02-2005 18:57
Autonomous Mode Yellow Eyes Programming 2 18-02-2004 21:16
autonomous mode Stephanie Programming 2 25-01-2003 19:57
