Go to Post There are two types of team members and mentors: Those who want to be FIRST, and those who want to be first. - Tetraman [more]
Unread 02-05-2007, 22:12
JBotAlan's Avatar
JBotAlan JBotAlan is offline
Forever chasing the 'bot around
AKA: Jacob Rau
FRC #5263
JBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond repute
Send a message via AIM to JBotAlan Send a message via Yahoo to JBotAlan
Re: Voltage regulator--how to mount?
Originally Posted by Dave Flowerday View Post
Oh, I know that I had a discussion for awhile during the season here on CD, but I didn't know there had been an official response. Thanks for the link.
JBot
Aren't signatures a bit outdated?
Unread 10-05-2007, 09:40
ntroup's Avatar
ntroup ntroup is offline
WildStang!
None #0111 (Wildstang)
ntroup has much to be proud ofntroup has much to be proud ofntroup has much to be proud ofntroup has much to be proud ofntroup has much to be proud ofntroup has much to be proud ofntroup has much to be proud ofntroup has much to be proud ofntroup has much to be proud ofntroup has much to be proud of
Originally Posted by JBotAlan View Post
[offtopic] Al, did you guys get your faulty pot wiring figured out yet? It looked like someone had cannibalized those PWM y-cables for pot wiring--every single one of those I've used has turned out defective, so I don't use them anymore. Had you seen that before Atlanta? And was that the problem you were having at Atl?[/offtopic]
Not to de-rail this topic again too much, but I wanted to add an update. After further investigation, the wiring was not at fault at all. We do not use 'cannibalized PWM y-cables', but actually create our own out of bulk PWM wire. The wiring was stressed a bit, but not defective or faulty. The digital pots, however, were where the problem was. Both the elbow and the shoulder pots are the MA2s from usdigital.com, and both died, either due to static shock or strong magnetic field too near them (as they work off change in magnetic fields to determine rotation). We are still investigating the root cause.
Either way, we are fixed, and ready to rumble at IRI now
-Nate
Unread 02-05-2007, 22:43
David Brinza's Avatar
David Brinza David Brinza is offline
Lead Mentor, Lead Robot Inspector
FRC #0980 (ThunderBots)
David Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond repute
Originally Posted by Al Skierkiewicz View Post
Jbot,
The 7805 series regulators have the center pin and the tab at the same potential, i.e. power supply common.
As Al points out, the 7805 case (and mounting tab) is tied to the center pin (power supply common). For some applications, you might need to isolate the regulator from the chassis. (In FIRST, for example, the robot chassis is required to be isolated from the +12VDC AND return/ground). There are thin mica insulators available for the TO-220 package that will provide electrical isolation with minimal thermal resistance. If you use your chassis as a heat sink and wish to keep it isolated from the power supply, you should use one of these mica insulators - with some thermal compound to improve the thermal conductivity between the regulator and heat sink.
"There's never enough time to do it right, but always time to do it over."
2003 AZ: Semifinals, Motorola Quality; SoCal: Q-finals, Xerox Creativity; IRI: Q-finals
2004 AZ: Semifinals, GM Industrial Design; SoCal: Winners, Leadership in Controls; Championship: Galileo #2 seed, Q-finals; IRI: Champions
2005 AZ: #1 Seed, Xerox Creativity; SoCal: Finalist, RadioShack Controls; SVR: Winners, Delphi "Driving Tomorrow's Technologies"; Championship: Archimedes Semifinals; IRI: Finalist
2007 LA: Finalist; San Diego: Q-finals; CalGames: Finalist || 2008 San Diego: Q-finals; LA: Winners; CalGames: Finalist || 2009 LA: Semifinals; Las Vegas: Q-finals; IRI: #1 Seed, Finalist
2010 AZ: Motorola Quality; LA: Finalist || 2011 SD: Q-finals; LA: Q-finals || 2013 LA: Xerox Creativity, WFFA, Dean's List Finalist || 2014 IE: Q-finals, LA: Finalist, Dean's List Finalist
2016 Ventura: Q-finals, WFFA, Engineering Inspiration
How to obtain battery voltage from within EasyC DavidSJohnson Programming 2 14-02-2006 00:05
how to mount a lcd display onto a robot mechanicalbrain Electrical 9 07-09-2005 20:57
how do you mount the accelerometer? team 507 Control System 4 10-02-2005 07:54
Voltage Regulator Robby Electrical 5 18-01-2005 07:50
How can i mount a pneumatic piston to a pvc pipe!?!?! archiver 2001 4 24-06-2002 01:11
