pic: The Beast Box
Re: pic: The Beast Box
Is there any reason why you're only using (it seems) one motor per side? Or is there a second set of gearboxes on the other side of the chasis?
There's two motors there, you just can't see the other one, as it's directly below the one on top.
Sweet gearbox!
You might want to consider using one pneumatic cylinder instead of 2. If you put one in the middle and hook both shift bars to it, you get the same effect as two, but use half the air. (unless of course you're planning to use a compressor or utilizing the space between the two cylinders) Just a thought; our team did that with our pneumatic shifter this past year and it worked great. It helped us with weight by eliminating the extra cylinder and potential air tanks. ![]() |
I notice that you are using 0.25" face width gears in the transmission. Did you already do the calculations for this and it will work? I am currently thinking on a single speed transmission that is small and light weight, and using smaller face width definately would save weight.
Sorry, I noticed that you appear to have quarter inch face width gears in your transmission. I woud like to know if you did any gear strength calculations with this decision, or if you are just making an educated guess. Hope that was clearer.
Why 7075 plates? And why only 1/8"?
Also, you may want to run some lewis bending numbers on those 24dp gears... you may have already, but at first glance it looks iffy. Depends entirely on the material, though. Otherwise looks good! Edit: Also, you said you used 20 DP on the initial reduction off the CIMs, and jump down to 24 on the other stages? That is counter intuitive to me, as you are gearing it down each stage you move away from the motor, putting more torque through the teeth of those gears. Last edited by Travis Covington : 02-05-2007 at 00:39. |
#10
I think because it's strong enough. We had the tracks this year and 1/8" is plenty enough to hold everything together. No point making them thicker if it's not needed.
#11
Those two support beams running through the center, are those 3/4" L's? or are they squares?
#12
Instead of lining up the motors perpendicular to the transmission, why not put worm gears on them and line them up parallel to the transmission? This way, it’ll give you more usable space and the tracks would be self-locking. No more rolling down the ramps after the power is cut. A robot with self-locking tracks from Outback would not be moved by anything at anytime unless it wants to.
#13
Why dont you integrate the tracks into the total length of the frame? Make them removeable but you could extend them the entire length & have them detach as a single unit for easy working while the rest of the team works on whatever mechanism is on top of the bot. In the drawing the plates just get welded onto the 2x1 (guessing) at the ends but I think you might run into issues with that.
#14
| pic: Pink Swamp Beast in action | Joe Matt | Extra Discussion | 0 | 27-04-2007 15:23 |
| pic: Greg And The Beast | jade_team_73 | Extra Discussion | 24 | 27-02-2007 20:25 |
| Gas prices drop because of the BEAST (71)? | Greg Needel | Chit-Chat | 14 | 25-05-2006 05:05 |
| Anyone got a video of the Beast in 2002? | George A. | General Forum | 10 | 17-01-2005 10:34 |
| pic: The BEAST Goes Down! | CD47-Bot | Extra Discussion | 5 | 22-04-2004 11:14 |
