| View Poll Results: What is the likelyhood that this software will be used? | |||
| It would most likely be used by rookie teams |
10 | 58.82% |
| It would serve as a guide tool to both rookie and veteran teams. |
4 | 23.53% |
| It wouldn't get used at all |
1 | 5.88% |
It would totally rock the competition! When will it have AI?
2 | 11.76% |
| Voters: 17. You may not vote on this poll | |||
I have been working on an all-around beginner's type code that should require very little re-compiling for a general robot.
As yet, it is version 0.36 and thus incomplete, but I think it is promising. It will feature the following:
Anyone wishing to see the (not) fabulous code, please e-mail me (I'm not on chiefdelphi enough to read PMs often) at tsaukpaetra-at-cox.net What do you think? Am I going off on some incredibly complex project that noone will ever run or think about? See my (rudimentary) website at http://tsaukpaetra.com !!! Attached is a snapshot (today) of the current build (with .o files and everything, sorry!) if you want to take a peek. |
Re: New Terminal Interface and Autonomous code
I think its a great piece of software for rookie teams... Great work!
Often the challenge of hardware is a little intense for rookie programmers, especially if they have no one who's knowlidgeable on their team to help them get started. -q |
I totally agree. That is a great idea.
Well... I'm not a programmer so I didn't really understand parts of it, but from what I did understand it sounds pretty cool. I'll definately check it out with the team programmers once you've gotten it to a "finished" state.
stupid school server won't let me see it...
but it sounds like a good idea from what i read above ![]() |
Basically it is robot code that will allow any general user (driver) to change specific properties of the code without the programmer needing to constantly re-compile. For example, if there were two drive wheels (left and right) the driver would tell the robot which PWMs each was on and then specify how the joysticks controlled them, (direct drive tank, single joystick, car, etc).Also, various other peripherals will (eventually) be supported like the camera, where all that the user needs to do is specify where each data connection is (which pwms are for tilt and pan for the camera) and enable it. Quote:
![]() Quote:
![]() I didn't expect there to be replies already. This encourages me to keep working . |
actually our team got chiefdelphi unblocked, but i can'd download the zip file.
Try downloading it from my home server here: ftp://tsaukpaetra.is-a-geek.net/main...OG/TI_0_36.zip
thank you
#10
I think veteran and rookie teams can use it as a guide as well as people like me who don't program but are trying to/ want to learn. It will definately be used by many rookie times, but as for veteran teams it will potentially be used for quick coding for quick tests.
Good work. |
| CMUCam and autonomous code | Demothesis | Programming | 19 | 19-12-2007 10:41 |
| New IFI Default/User and Master Code | Alex698 | Programming | 6 | 28-02-2006 23:04 |
| Anybody have a code for an autonomous mode to go to the 50 point bar???? and... | chaoticprout | Programming | 9 | 06-11-2004 12:22 |
| Operator Interface code | RiotingNerd | Programming | 5 | 07-02-2004 21:13 |
