Go to Post note: spelling, punctuation and good grammar are your friends - use them and enjoy the benefits of legible, understandable prose - dlavery [more]
Unread 05-09-2007, 08:16 AM
Pelicano234's Avatar
Pelicano234 Pelicano234 is offline
"Glish"
FRC #2077 (Lasers)
Team Role: Student
Rookie Year: 2007
Pelicano234 is just really nicePelicano234 is just really nicePelicano234 is just really nicePelicano234 is just really nicePelicano234 is just really nice
Swerve Drivetrain
I have been playing around with the idea of using a swerve drive next year. However, my coach doesn't want to do it because of the extra weight. so, I have two questions: how light can you make a swerve drive and is it worth the extra wieght?
Unread 05-09-2007, 08:45 AM
Cowmankoza's Avatar
Cowmankoza Cowmankoza is offline
KoZa
AKA: Matthew Koza
FRC #1251 (The Tech Tigers)
Team Role: Operator
Cowmankoza has a spectacular aura aboutCowmankoza has a spectacular aura about
Send a message via AIM to Cowmankoza
Re: Swerve Drivetrain
while it depends on the materials that are available to you, it will default be higher than a normal drive setup of the same material. you also gotta ask yourself if the programming is worth it as well. As for the success of it, ask 118
Team 1251 The Techtigers
2008 UCF Regional Champs thanks to 233 and 86
2008 UCF Regional GM Industrial Design Award
2007 Palmetto Regional finalists thanks to 1626 and 1758
2007 Palmetto Regional Motorola Quality Award
2007 UCF Regional Champs thanks to 1270 and 86
2007 UCF Regional GM Industrial Design Award
2006 Palmetto Regional Champs thanks to 11 and 247
2006 UCF Regional Semifinalist thanks to 86 and 710
2005 Palmetto Regional finalist thanks to 25 and 301
2005 Palmetto Regional Xerox Creativity Award
2005 UCF Regional finalists thanks to 845 and 1270
2005 UCF Regional Judges Award
2004 UCF Regional Rookie All-star Award (The real winner)
Unread 05-09-2007, 09:10 PM
Matt Reiland's Avatar
Matt Reiland Matt Reiland is offline
'The' drive behind the drive
None #0226 (TEC CReW Hammerheads)
Rookie Year: 1999
Matt Reiland has a reputation beyond reputeMatt Reiland has a reputation beyond reputeMatt Reiland has a reputation beyond reputeMatt Reiland has a reputation beyond reputeMatt Reiland has a reputation beyond reputeMatt Reiland has a reputation beyond reputeMatt Reiland has a reputation beyond reputeMatt Reiland has a reputation beyond reputeMatt Reiland has a reputation beyond reputeMatt Reiland has a reputation beyond reputeMatt Reiland has a reputation beyond repute
Forget about weight, you better have have a LOT of resources available to design and build it. After seeing the 118 machine up close, this isn't something you think up overnight. The weight also is greatly affected by the types of wheels, motors, chain etc that you choose to use. Try to look at the pictures from 111,118, 71 and others to pick up the tricks from each for weight savings and efficient design. Just be ready for the complexity and hope that the playing field is flat if you choose to develop it in the off season!
Robonaut Next Generation Control System Development
2003 GLR Champions (302,67,226)
2003 Buckeye Semi-Finalists(902,494,226)
2002 Nationals QuarterFinalists
2001 West MI QuarterFinalists
2000 GLR Semi-Finalists
Unread 05-09-2007, 09:28 PM
=Martin=Taylor= =Martin=Taylor= is offline
run the trap!!!
FRC #0100 (The Wild Hat Society)
Team Role: Human Player
=Martin=Taylor= has a reputation beyond repute=Martin=Taylor= has a reputation beyond repute=Martin=Taylor= has a reputation beyond repute=Martin=Taylor= has a reputation beyond repute=Martin=Taylor= has a reputation beyond repute=Martin=Taylor= has a reputation beyond repute=Martin=Taylor= has a reputation beyond repute=Martin=Taylor= has a reputation beyond repute=Martin=Taylor= has a reputation beyond repute=Martin=Taylor= has a reputation beyond repute=Martin=Taylor= has a reputation beyond repute
There's always a simpler & lighter way to do things...
Its not that swerve drives are "heavy" or "complex," its that no one has been clever enough to design one that is lighter and less complex. (Although some have gotten pretty darn close)
My advice is to go for it. Who knows? Perhaps with enough work and research you'll hit on an idea that will revolutionize the swerve as we know it.
Team 16 had a nice chapter on swerves in FIRST Robotics: Behind the Design.
"Cooperation; because life is a team sport"
-Philip J. Fry
Unread 05-09-2007, 09:55 PM
CraigHickman
Posts: n/a
Complexity and resources are the most taxing when doing a Swerve system. However, weight can always be designed around. I have one designed that weighs only 35, and that includes the whole base frame.
Machine resources are the most taxing, as any sufficiently advanced Swerve will need a lot of advanced machining.
Unread 05-10-2007, 02:50 AM
Don Wright's Avatar
Don Wright Don Wright is offline
FRC #0469
Don Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond repute
Send a message via MSN to Don Wright Send a message via Yahoo to Don Wright
I see you are from WI. Are you going to IRI?
If you are seriously thinking about doing swerve in the near future, you should make a point of attending. I know that 71, 111, and 469 will all be their with their different methods of swerve and I know 469 would be happy to share with you anything and everything about ours...
Donald F. Wright Jr.
Product Manager
AVL Instrumentation & Test Systems, Inc.
Unread 05-10-2007, 08:20 AM
"Glish"
FRC #2077 (Lasers)
Team Role: Student
Rookie Year: 2007
What is IRI and when is it. As for machining we have a company that can bend aluminum into somewhat complex shapes. And we have a guy that is quite impressive on the mill.
Another question, what keeps coaxil swerve drive modules from turning when you are driving them, aren't the drivetrain motors usually more powerful then the ones that turn the modules?
Unread 05-11-2007, 03:14 PM
Don Wright's Avatar
FRC #0469
IRI is an incredible off-season event...
http://www.chiefdelphi.com/forums/sh...&highlight=469
Even if you aren't going to compete, everyone who can should go because it's incredible!!!
Product Manager
Unread 05-11-2007, 03:19 PM
Lil' Lavery Lil' Lavery is offline
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
Lil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond repute
Send a message via AIM to Lil' Lavery
Don't forget 118.
118 will also be able to answer specific details about their coaxial swerve (the only one at IRI that I know of as 71, 111, and 469 each built other versions of swerves). The basic answer to your question is that the force follows the path of least resistance, and for the drive motors, that is spinning the wheels as it only has to overcome rolling resistance (and built in resistance).
Being correct doesn't mean you don't have to explain yourself.
Unread 05-11-2007, 03:36 PM
RogerR's Avatar
RogerR RogerR is offline
its spelled *ya'll*, not *y'all*
AKA: Roger Riquelme
FRC #3844 (Wildbots)
Team Role: Teacher
RogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond repute
Send a message via AIM to RogerR Send a message via MSN to RogerR
...Another question, what keeps coaxil swerve drive modules from turning when you are driving them, aren't the drivetrain motors usually more powerful then the ones that turn the modules?
if you do a search on 'torque steer', you should find some posts addressing this subject. usually, the motors are geared in such a way that while the drive motors are more powerful, the steering motors are outputting more torque. also, the width and diameter of the wheel, along with its CoF come into play as well.
this is one reason (the main one, acutally) that i prefer to mount my drive motors in the modules.
"But to say that the race is a metaphor for life is to miss the point. The race is everything. It obliterates whatever isn't racing. Life is a metaphor for the race." -- Donald Antrim
Unread 05-11-2007, 04:27 PM
Aren_Hill's Avatar
Aren_Hill Aren_Hill is offline
Build Nifty Things
Aren_Hill has a reputation beyond reputeAren_Hill has a reputation beyond reputeAren_Hill has a reputation beyond reputeAren_Hill has a reputation beyond reputeAren_Hill has a reputation beyond reputeAren_Hill has a reputation beyond reputeAren_Hill has a reputation beyond reputeAren_Hill has a reputation beyond reputeAren_Hill has a reputation beyond reputeAren_Hill has a reputation beyond reputeAren_Hill has a reputation beyond repute
at iri us(1625) will also have our 3speed coaxial swerve drive for you to look at.
the only downside i can think of is weight everything else makes it worth it.
also as far as torque steer goes i had 4 cims each one powering its own module and i just had a set of 2 diagonal modules spun 180deg so the 4 cims cancelled each other out torque steer wise.
A guy who likes robots.
1625->3928->148->1296->971 oh dear
Unread 05-11-2007, 06:43 PM
Don Wright's Avatar
FRC #0469
Sorry I missed 118... I'm glad I got to see it in person at Nats.
But, as you can see, if you are thinking about doing ANY kind of swerve drive, IRI will be the place to check it out...
Product Manager
Unread 05-11-2007, 06:44 PM
Zoheb N Zoheb N is offline
Captain
FRC #0118 (Robonauts)
Zoheb N is just really niceZoheb N is just really niceZoheb N is just really niceZoheb N is just really nice
Send a message via AIM to Zoheb N
So we have done swerve drive for 4 years now on team 118. Every year our swerve drive changes a bit. This year was actually our lightest wheel box yet. It weighed a max of 3 pounds (this is not an exact measurement, but from carrying it this is what it feels like). With the extra weight we made the V6 this year. Otherwise we use to have it so each wheel box gets a CIM motor attached to it. There are many ways to make them it really depends on what you want your robot to look like. If you have any other questions feel free to PM me and I can try to get some pictures or answer any other questions that you have. For us the weight we put into it, it has been extremely helpful in being agile
2004 Lone Star Engineering Inspiration
2005 Denver Regional Winner
2005 Denver Radio Shack Innovation in Control Winner
2005 Lone Star General Motors Industrial Design Winner
2005 Lone Star Regional Winner
2005 Lone Star Regional Chairman's Winner
Unread 05-11-2007, 08:23 PM
Don Wright's Avatar
FRC #0469
It would be fun to have a "Swerve off" round at IRI with all the robots swerving all over the place...
Product Manager
  #15   Spotlight this post!
Unread 05-11-2007, 08:28 PM
Aren_Hill's Avatar
Build Nifty Things
that would be amazing. i'd feel sorry if one tank drive d bot ended up in there trying to stop somebody
pic: Vex Swerve Vince lau Extra Discussion 10 03-19-2007 10:08 AM
Swerve/Crab Rob2713g Technical Discussion 5 11-12-2006 10:05 PM
A Swerve Drive Question lndnny Technical Discussion 10 07-20-2006 08:09 AM
pic: Swerve! =Martin=Taylor= Extra Discussion 15 07-07-2006 01:58 AM
Swerve Drive Jeff Waegelin Technical Discussion 14 09-17-2001 08:06 AM
