pic: VEX Mecanum Concept Wheel
Re: pic: VEX Mecanum Concept Wheel
) you can file the curve into them. |
mostly everything from vexlabs is completely legal for competition unless it says that it is not on the website or in the rules
Well that's nice to know. Even though it's part of a spacer "set" it's still cheaper to get them through vexlabs than home depot, lowes, Ace, Target, or Walmart. They're also softer, easier to file, and get better traction than those at the places above.
methinks you will have a really long (if not hard) time making 64 perfect rollers (2 per roller, 8 rollers per wheel, 4 wheels on the bot).vivek |
By hand would be much harder. Is that how you made them? When can we expect to see a working chassis? |
when i made my vex meccanum wheels those were the most time consuming part by drilling them out and to assemble them
Yes, I used a variable-speed drill and a file that has 4 different surfaces to file them down. They're not perfect, but to file 10 of them it took ~45 minutes.
To drill through the metal pieces it took 10 minutes since I came up with a way to do them all at once. I bent the metal by hand so it's not exactly 45 degree, and the spacing on the rollers isn't exact either. It's a concept though, to show that it can be done. |
#10
Another Vex Mecanum Wheel:
http://www.chiefdelphi.com/media/photos/25957 |
#11
Unfortunately, IFI will not break up the $8 kit that comprises of the plastic (and adjustable) lock bars. To complete a single set of wheels with this design, one would have to spend $48 for these parts alone. Before those, the price per wheel would be $14 per wheel with 8 rollers.
#13
Well since many people are showing their vex mecanums, I might as well show what I am up to...
![]() The wheels are roughly the same size as the 4" wheels. Uses eight 2" lengths of vex shaft and 16 shaft collars per wheel. I hope to have these wheels done soon. |
#15
Kit ($8): ![]() http://www.vexlabs.com/vex-robotics-...it-parts.shtml |
| pic: 1683 Concept 8 Wheel Drive | sdcantrell56 | Extra Discussion | 16 | 16-04-2007 14:22 |
| pic: 114 wheel concept....again. | CraigHickman | Extra Discussion | 5 | 21-10-2006 14:53 |
| pic: 114 wheel concept | CraigHickman | Technical Discussion | 8 | 22-06-2006 14:24 |
| pic: 2" Mecanum Wheel | Tytus Gerrish | Technical Discussion | 17 | 22-04-2006 12:22 |
| pic: Micro Mecanum wheel | Tytus Gerrish | Extra Discussion | 6 | 12-05-2005 23:20 |
